Old 11-02-2012, 12:46 PM   #43
ooharloo
Drives: 2012 Scion FR-S Asphalt 6 sp M/T
Originally Posted by Hanakuso View Post
Can't you measure it yourself with measuring tape?
indeed i could...lol. I have yet to get the wheels and just wanted to see if anyone would know.
ooharloo is offline   Reply With Quote
Old 11-02-2012, 12:51 PM   #44
#87
I usually post drunk
#87's Avatar
Should put the hub bore for our cars in the OP since im sure people will be clicking this thread looking for it.
#87 is offline   Reply With Quote
Old 11-02-2012, 12:53 PM   #45
Rayme
The Answer
Rayme's Avatar
Drives: Mazda 2
I once had a 94 celica with aftermarket wheels with heavy vibration at highway speed. It was going on and off and would start / stop when hitting certain bumps.
They were properly torqued/balanced, and hubcentric rings were the only thing that fixed the problem.
However that's the only car I ever owned that really "needed" these rings to fix an issue.
Rayme is offline   Reply With Quote
Old 11-02-2012, 12:53 PM   #46
Hanakuso
I just looked at both the Japan and US websites and didnt find anything. Maybe it's best to email them
Hanakuso is offline   Reply With Quote
Old 11-02-2012, 01:25 PM   #47
Innova
Drives: 2013 BRZ Limited
Question guys-
I put some hubcentric rings on my BRZ - however since the rings have the small lip on them, when the wheels are mounted, there is now a slight gap (maybe 1mm) between the wheel and the hub.
Is this okay? I don't see any way around this since most of these rings have the lip on them.
Innova is offline   Reply With Quote
Old 11-02-2012, 02:17 PM   #48
gmookher
I got rid of my gorillas for mcgard and will never buy gorilla again...soft metal, mcgard design is superior
Old 11-08-2012, 04:56 PM   #49
Tt3Sheppard
Tt3Sheppard's Avatar
Drives: Whiteout FR-S
I've been having issues finding these rings for my snow rims. Sport Editions that I bought off of craigs list. They came from a Volkswagen Jetta
Tt3Sheppard is offline   Reply With Quote
Old 11-11-2012, 04:33 AM   #50
NYC BRZ
AutoX Addict
NYC BRZ's Avatar
Drives: 08 Pontiac G8 GT,13 GBS BRZ Limited
If I bought steelies from TireRack would hub rings still be required? I'm picking up some used TR steelies with snow tires today from a 2010 WRX. Forgive my ignorance.
Sent from my Galaxy S3 using Tapatalk 2
2013 BRZ Limited- GBS - 6MT -VIN #0937
~~NYR SCCA # 18 C Street R (CSR)~~
"But there’s no mistaking the noise. This car is loud, and not in a particularly nice way. There’s no crisp exhaust note, no induction wheezing. It’s just the sound of petrol exploding in a metal box." - Jeremy Clarkson
NYC BRZ is offline   Reply With Quote
Old 11-11-2012, 04:34 AM   #51
NYC BRZ
AutoX Addict
NYC BRZ's Avatar
Justforwheels.com
Old 11-11-2012, 12:27 PM   #52
smbrm
smbrm's Avatar
Drives: Scion FRS Ht Lva(AT)
Hubcentric rings have two dimensions: inside diameter and outside diameter. The inside diameter has to be correct for the hub and the outside correct for the particular wheel. I think if you had to force(hammer) fit rings in the wheel they may not have been the correct OD.
Having measured my hubs and OE wheels, I got these results: Hub centre bore outside diameter actually measured at about 55.98mm, stock wheel inside bore diameter at 56.2mm. Based on this, and other references the standard wheel bore size appears to be listed as 56.1mm.
If you are forcing a large circle into a small bore on the wheel you also run the risk of reducing the ID of the ring as well, so it may not fit the hub??
So hubcentric rings need to be properly sized for both the wheel and the hub. The rings allow alloy wheels to be made in one size but can also fit many hub sizes with the correct rings.
Steel wheels tend not to use rings as they appear to not have space for them. The steel wheels that close but not hubcentric appear to be about 57.1mm. You would need to have a hubcentric ring with a radial thickess of 0.5mm which would probably be way to delicate no matter the material?
There is lots of discussion on steel wheels in the threads on snow tires, and particularly in the CANADA subforum.
smbrm is offline   Reply With Quote
Old 11-12-2012, 12:23 AM   #53
Phaedrus29
Phaedrus29's Avatar
Drives: 2013 Subaru BRZ
I got some hubcentric rings for my Volks...the rings have a 56.1mm inner diameter and 65.1mm outer diameter. The 56.1mm inner diameter does appear perfect for our hubs. However, the outer diameter of 65.1mm was not exactly right for my particular wheels. I really should have gotten 65mm rather than 65.1mm. Since they were very close, I was able to hammer in the rings (although you aren't supposed to have to do this with properly fitting rings). For me, the hammering seems to have worked, and it did not affect the inner diameter at all.
Phaedrus29 is offline   Reply With Quote
Old 01-17-2013, 06:18 PM   #54
thatWESguy
Power Ranger
thatWESguy's Avatar
Drives: 86
to the OP, where did you order your 65mm to 56.1mm hub rings?
Autofashion | FIVEaxis | Enkei
thatWESguy is offline   Reply With Quote
Old 01-18-2013, 08:21 AM   #55
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
I've always got mine from the same place I get a set of wheels. They should have hubcentric rings for any wheels they sell.
Old 01-19-2013, 03:06 PM   #56
seeclass
Drives: WRX
I have a bunch of Volk/RAYS 65mm to 56.1mm hub rings if anyone needs them...
Btw, when I use plastic hub rings, I always put some electrial tape on the inside of the ring and then install them on the car first. This makes them fit tighter and sometimes fills the gap if the hub ring is not 100% accurate in size.
seeclass is offline   Reply With Quote
5mm spacers and hub rings. zooki Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 04-05-2013 10:57 PM
Buying OZ Superleggera 17x7 - Do I need hub rings? NYC BRZ Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 06-10-2012 03:56 PM
