View Poll Results: More bang for the buck, Supercharger or Turbo?
Supercharger 17 27.87%
Turbo 44 72.13%
Voters: 61. You may not vote on this poll
Old 11-02-2012, 12:37 PM   #43
Toyota fr-s
Yes, Toyota fr-s
Drives: 1991 MR2 Turbo T-Top, Gen3 3SGTE
If I were you, I'd wait and see what the manufacturers come up with and see which is more reliable before you make a decision. Your question is too broad and too many factors involved. At the end of the day, there are supercharger and turbocharger guys who will pick one because they are used to them and that's what they want.
Now days, turbos can respond quickly, be more efficient and safe if sized correctly and run low boost. On the other had, there maybe superchargers that could also be problematic. Just wait and let the companies compete. Plus don't forget costumer support is also very important. The good kits and manufacturers will stand out for sure.
Toyota fr-s is offline   Reply With Quote
Old 11-02-2012, 01:01 PM   #44
VADER
Regional Moderator
VADER's Avatar
Drives: VADER 86
suggestions for good companies to watch?
VADER is offline   Reply With Quote
Old 11-02-2012, 06:23 PM   #45
VADER
Regional Moderator
VADER's Avatar
Drives: VADER 86
btw.. Perrin posted a good explanation as to why to choose SC over Turbo with this car specifically..
So Why No Turbo?
We are known for making turbo kits for the WRX's and STI's and you better believe that we thought about a kit for the BRZ/FR-S platform. In early planning stages there were a lot of things that we had to consider. Performance of the turbo, placement of the turbo, thermal related issues, installation, tuning, boost control, safety, proper oil drain, a huge parts list, actual customer demand and cost. Everything about a turbo kit is easy except two major issues, cost and thermal related issues. The thermal related issues are things like melted engine components from headers and downpipes routing next to items that wouldn't take the heat. This would require a properly built thermal blanket for the headers and downpipe which is a huge expense. Cost is a huge factor for us as this is what would scare people away. If properly built with all things considered, we could be pushing to the $7000 range which is a huge amount to swallow, then add custom tuning and installation, you could easily push to $8000 plus range. The price and the actual number of customers that might buy this over the next couple years is what really steered us away.
The other thing is this car is a drivers car. Adding a turbo like power band could ruin the way the car acts. Currently the power band is rather flat and a smooth increasing HP curve to 7000-ish. Adding a turbo and the HIT from the onset of boost is going to change a lot of things about how the car drives and acts under power in a corner. What would be perfect is a power curve like stock but with 30-50 HP across the whole range. That provides the same basic characteristics as it has now, but with the power the car should have come with. This isn't an AWD car that can absorb some of that hit in the onset of boost from a turbo through the additional traction it has. This is a RWD with limited traction, so power modulation and smoothness of power is key to keeping this car a "drivers". The way to get this smooth powerband is with a supercharger!
Superchargers provide a very linear power band because of the boost curves they provide. This is a very desirable kind of power band for an application like this and Vortech has the answer we feel most customers will be looking for.
Old 11-03-2012, 08:41 AM   #46
VADER
Regional Moderator
VADER's Avatar
Drives: VADER 86
Originally Posted by FreshFRS View Post
Audi also uses the R1320 on their 3.0 v-6 which gets best in class fuel economy vs. 2 turbo cars and some bigger N/a motors.
hmmmm interesting
Old 11-03-2012, 12:10 PM   #47
FreshFRS
KCCO From Canada
Drives: Asphalt FRS
Originally Posted by FR-S Dan View Post
hmmmm interesting
eaton did prototyping on the 2009 cobalt SS turbo. they found that from a 30kph roll in 3rd gear (~1100rpm) the supercharger got 90% boost in .5 seconds v.s almost 5 seconds for the turbo. they compared this to a bigger n/a motor (2.8L v6). the v6 has 29kw of reserve power in .5 seconds from 2000rpm cruising (thats the baseline for the test).
the 2.0l turbo produces only 15kw in .5 seconds at 2000rpm cruising therefore must be up speeded to ~2500rpm to make the same power. while the fuel economy is still better than the bigger motor gotta be faster to get the response of the bigger motor. save ~9% fuel economy wise
the supercharger in comparison makes 34kw in .5 seconds allowing the engine to be downspeeded to ~1800rpm to make 26kw in .5 seconds therefore it increases fuel economy on the cobalt platform by 14%
For reference audi's A6 3.0SC manages 11.3L/100km vs. BMW 535xi 3.0TT at 11.8L/100km
Reference: http://www.engine-expo.com/forum_200...rt_walling.pdf
FreshFRS is offline   Reply With Quote
Old 11-03-2012, 01:10 PM   #48
VADER
Regional Moderator
VADER's Avatar
Drives: VADER 86
Ok, TRD is said to be making a SC. If it is reasonably priced. Consider me SOLD!!
Old 11-03-2012, 01:37 PM   #49
Dimman
Kuruma Otaku
Dimman's Avatar
The 3rd gear 1100rpm example shows that they were pretty desperate to make their SC look good. Because of how biased that article is, and how hard small TVS chargers are to find, I don't have a tremendous amount of faith in Eaton. I want to see an unbiased TVS vs Lysholm comparo, same engine, same boost, properly sized to see how they do in the real world.
Seriously, 1100rpm in 3rd...
Because titanium.
Old 11-03-2012, 03:05 PM   #50
FreshFRS
KCCO From Canada
Drives: Asphalt FRS
3rd gear at 30khp is in reality about 1300, but i get your point. the thing is thats like a 90km/h roll on in 5th. its only done in lower gears to be able to test effectively on the street. the test illustrates transient response. a much lower powered N/A car would out accelerate a turbo in the same test (not to mention the in first .5 sec it would out accelerate the supercharged car too). i already proved lysholm are achieving about 65% thermal efficiency go to the site and look at a performance maps. under some conditions that is 10% less than current TVS technology. your point is moot.
EDIT: you could use a 1320 on our car without much of a problem and you can order the charger from harrop out of australia pretty easily.
Old 11-03-2012, 03:44 PM   #51
Dimman
Kuruma Otaku
Dimman's Avatar
Eaton is also very tight about their drive HP requirements and volumetric efficiency. Compare a TVS map to a Lysholm map, and you see that the Lysholm ones are complete, Eaton's aren't. There just seems to be a lot of 'you have to ask Eaton directly' to get data. Not transparent at all. Plus in the Cobalt demo, they use theoretical numbers on the high power SC version.
I think I sized out a 900 or 1050 as being really good for this motor. But after like 5 years of tease, they STILL aren't ready...
I want to see a real Eaton vs Lysholm test, because I don't like how Eaton is presenting its numbers. Why did GM ditch them on the Cobalt, BTW?
Side note: once I get my BRZ, I'm pretty sure I want to try a positive displacement SC, as I have my turbo fix now.
Because titanium.
Old 11-03-2012, 04:04 PM   #52
FreshFRS
KCCO From Canada
Drives: Asphalt FRS
R1050 would be the best choice it what i want to use. should be capable of 350whp 250ish torque. which would be perfect.
Chevrolet went away from eaton because the were using m62 twin screw style. and that could not match the turbo for efficiency. TVS would have matched the turbo (ish) but at the time the R900/R1050 were not even in the works just the 1320. which was a bit too big.
i did however get the complete picture. mechanical efficiency is 95% for the 1320 so i would suspect it shouldn't be much different. i also confirmed that eaton's maps do take all considerations (power requirements, VE, Mechanical Efficiency ) into the thermal efficiency maps they put out. the numbers on the maps are the NET product of all the different factors taken together.
Old 11-07-2012, 09:45 PM   #53
raul
Lap time enthusiast
raul's Avatar
Drives: Asphalt '13 FR-S 6MT
It would be nice to see how smooth the power curve is on AVO's kit.
raul is offline   Reply With Quote
Old 11-07-2012, 09:48 PM   #54
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Here:
Very smooth!
The Following User Says Thank You to Sportsguy83 For This Useful Post:
raul (11-07-2012)
Old 11-07-2012, 09:50 PM   #55
raul
Lap time enthusiast
raul's Avatar
Eat your heart out, Perrin! :P
Old 11-07-2012, 09:56 PM   #56
Sportsguy83
Drives: Limited BRZ
LMAO!
Supercharger or Turbo ? #87 Forced Induction 192 01-25-2013 10:20 AM
supercharger or turbo? RussellRockets Forced Induction 137 11-28-2012 06:54 AM
Looking for a Frs for R&D on a turbo and supercharger Toxic Forced Induction 38 10-23-2012 03:13 PM
Noob to this. Style Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 08-09-2012 08:10 PM
Induction Poll - NA, Supercharger, or Turbo cloud9 Engine, Exhaust, Transmission 45 02-21-2012 12:41 PM
