Old 11-01-2012, 10:18 PM   #1
F1point4
Photo Specialist
F1point4's Avatar
Drives: 2013 Toyota 86 DGM 6MT
DIY - Master Cylinder Brace - Grimmspeed
Hey all. Houston86.com back with another DIY. Here is how to install most Brake Master Cylinder Braces. Most of the designs I've seen use these mounting points.
Normally, the firewall supporting the brake booster and master cylinder flexes while braking. You have to waste a certain amount of energy in that flex before energy is used for braking. This brace removes the flex improving response.
Feedback
+ Definitely does its job - firms up the pedal, brakes respond sooner. From feel, I think the pedal travels 40% less than before. Good bit of kit
+ Mechanically simple, does not interfere with strut tower braces.
+ looks the part. I like the powder coated mild steel
+ Always good feeling to know its made in the USA
Thanks @GrimmSpeed for making this and providing excellent support. Matt was very professional when I called him questions about the instructions. Definitely categorize as a high quality human.
Product Shots
20121101-GrimmspeedMCB-01 by VictorN07, on Flickr
20121101-GrimmspeedMCB-02 by VictorN07, on Flickr
20121101-GrimmspeedMCB-03 by VictorN07, on Flickr
20121101-GrimmspeedMCB-04 by VictorN07, on Flickr
DIY
It is an easy install, just wanted to make sure all doubt is removed with some good pictures. It took longer to setup and take pictures than to do the actual mechanical work. This guide is intended to supplement the official instructions. As always we are not responsible for damage to you or your vehicle. Be safe.
20121101-GrimmspeedM***IY-01 by VictorN07, on Flickr
20121101-GrimmspeedM***IY-02 by VictorN07, on Flickr
20121101-GrimmspeedM***IY-03 by VictorN07, on Flickr
20121101-GrimmspeedM***IY-04 by VictorN07, on Flickr
20121101-GrimmspeedM***IY-05 by VictorN07, on Flickr
20121101-GrimmspeedM***IY-06 by VictorN07, on Flickr
20121101-GrimmspeedM***IY-07 by VictorN07, on Flickr
20121101-GrimmspeedM***IY-08 by VictorN07, on Flickr
20121101-GrimmspeedM***IY-09 by VictorN07, on Flickr
20121101-GrimmspeedM***IY-10 by VictorN07, on Flickr
20121101-GrimmspeedM***IY-11 by VictorN07, on Flickr
F1point4 is offline   Reply With Quote
The Following 19 Users Say Thank You to F1point4 For This Useful Post:
amram (03-28-2014), cbryant514 (06-09-2017), DocWalt (11-10-2014), Firestorm_86 (09-09-2014), Flow (08-09-2014), FriedRicr (04-08-2014), gmookher (11-02-2012), GrimmSpeed (11-02-2012), GT86_PRAGUE (01-23-2015), Hanakuso (11-02-2012), jimmy4thenguyen (09-13-2013), kwood9000 (11-01-2012), MasonL1997 (07-21-2016), mezdup (04-13-2013), normancw (03-24-2013), RazBRZ (11-02-2012), RehabJeff86 (09-25-2013), rookie (09-17-2016), Tristor (02-22-2018)
Old 11-01-2012, 10:28 PM   #2
post_break
Professional Smartass
post_break's Avatar
Drives: White Out FRS
That was fast. Looking good!
post_break is offline   Reply With Quote
The Following User Says Thank You to post_break For This Useful Post:
F1point4 (11-01-2012)
Old 11-01-2012, 11:41 PM   #3
xn7485
Drives: 1995 Acura Integra GS-R
I like how you guys come out with a DIY of all the stuff I've got planned to do.
xn7485 is offline   Reply With Quote
The Following User Says Thank You to xn7485 For This Useful Post:
Old 11-02-2012, 01:21 AM   #4
Chee-Hu
Chee-Hu's Avatar
Nice write-up. I just got mine today and will be installing this weekend.
Chee-Hu is offline   Reply With Quote
Old 11-02-2012, 10:22 AM   #5
GrimmSpeed
GrimmSpeed's Avatar
Drives: '13 BRZ, '12 WRX
Send a message via AIM to GrimmSpeed Send a message via MSN to GrimmSpeed
Very, very nice write-up! Thanks for your support; hope the brace treats you well!
Mind if we link to it as a resource on our website?
Matt Beenen
Engineering
GrimmSpeed is offline   Reply With Quote
The Following User Says Thank You to GrimmSpeed For This Useful Post:
F1point4 (11-02-2012)
Old 11-02-2012, 10:49 AM   #6
F1point4
Photo Specialist
F1point4's Avatar
Matt Beenen
Engineering
Absolutely you may. Appreciate you asking first
Old 11-02-2012, 11:46 AM   #7
gmookher
yeah great write up
Old 08-15-2013, 11:37 AM   #8
2thdoc
2thdoc's Avatar
Drives: Scion FR-S
on my frs there is a bracket holding electrical wires where you say there is only a sticker. what do I do with that bracket?
2thdoc is offline   Reply With Quote
Old 08-15-2013, 12:18 PM   #9
GrimmSpeed
GrimmSpeed's Avatar
Hey! If your car is an automatic, you'll have that harness. I believe that most people have been ditching the bracket and securing the harness with a ziptie if needed. I'm sure somebody will chime in with possible solutions. In the mean time, I'll try to track down photos of what others have done. Cheers!
Matt Beenen
Engineering
The Following 3 Users Say Thank You to GrimmSpeed For This Useful Post:
amram (03-28-2014), Rosticles (01-27-2015), Tristor (02-22-2018)
Old 08-18-2013, 02:10 PM   #10
Efferalgan
Drives: 2025 BRZ, ex-2012 GT86
Just installed it today on the AT car. Was also puzzled initially when found some "odd" harness which is not mentioned in the manual but installed the brace anyway - the "additional" harness just rests quite comfortably on top of the MC brace body. Doesn't looks as it even requires any additional bracket. Whould be nice mentioning this point in the manual for AT users though so that they are not puzzled as me today
Efferalgan is offline   Reply With Quote
The Following 3 Users Say Thank You to Efferalgan For This Useful Post:
Old 08-19-2013, 02:26 PM   #11
Efferalgan
Here is how the place for installation looks on AT cars, the bracket and after installation.
The Following 4 Users Say Thank You to Efferalgan For This Useful Post:
amram (03-28-2014), KalbiCool88 (07-13-2016), Rosticles (01-27-2015), Tristor (02-22-2018)
Old 09-13-2013, 06:29 PM   #12
jimmy4thenguyen
Drives: Whiteout FRS
just installed mine, Thanks for the write up!
jimmy4thenguyen is offline   Reply With Quote
Old 09-20-2013, 09:00 PM   #13
Salgts86
Drives: tornado Grey Manuel
do you have them in RH drive?,,, otherwise I'll be making it from scratch which will be costly in regards to time and resources! and wont look as sweet as yours
Salgts86 is offline   Reply With Quote
Old 09-23-2013, 10:26 AM   #14
GrimmSpeed
GrimmSpeed's Avatar
The unofficial word is that we're working on it. Unfortunately, I can't give details just yet. It's a longer process than normal, being that we don't have easy access to a RHD vehicle.
Matt Beenen
Engineering
brakes, diy, grimmspeed, master cylinder brace, stopper
Cusco FSB with master cylinder brace - A heads up for AT owners CircuitJerk Suspension | Chassis | Brakes -- Sponsored by 949 Racing 33 03-15-2014 07:25 AM
Master Cylinder Brace Development - Any Interest? GrimmSpeed Brakes, Suspension, Chassis 411 05-14-2013 05:04 PM
