Old 10-30-2012, 06:47 PM   #3431
DSTL
Drives: 2013 BRZ Limited 6MT
John, re E85 cold start fix map. Leaving work this AM was 39* and took two tries but started just as normal on the second try, no sputtering at all etc (push button start). Couldn't do a log but will tomorrow am with video. Seems to fare better in this temp range than it does in upper 40*s. Subjective without logs I know, but was hands down a cleaner start when a bit colder out on the current map.
DSTL is offline
Old 10-30-2012, 06:48 PM   #3432
xjohnx
Grip>Slip
xjohnx's Avatar
b13 or b14?
xjohnx is offline
Old 10-30-2012, 06:54 PM   #3433
DSTL
Originally Posted by xjohnx View Post
b13 or b14?
b13
RR-10895-ZA1J700C-STG1 STOCK INTAKE PUMP & E85 v1.07b13 FED-A
DSTL is offline
Old 10-30-2012, 06:55 PM   #3434
xjohnx
Grip>Slip
xjohnx's Avatar
b13
ahh, i wasn't having much luck with that one here, low of 38 was taking quite a bit more than the 2 starts it took you. i'll be trying out b14 late tonight/early tomorrow, but then i'm out of e85 for a couple weeks.
xjohnx is offline
DSTL (10-30-2012)
Old 10-30-2012, 07:08 PM   #3435
DSTL
I really missed it when the weather got colder and switched back over, but will still prob run gas most of the winter. Still have 3/4 tank of E85 for testing.. so at least a week. Hopefully we'll see some good results--sure John will get it nailed down.
DSTL is offline
The Following User Says Thank You to DSTL For This Useful Post:
xjohnx (10-30-2012)
Old 10-30-2012, 09:02 PM   #3436
xjohnx
Grip>Slip
xjohnx's Avatar
I'm making the woman drive to dinner tonight so the BRZ can continue to cool down for a cold start test. Coolant temp at 32c right now, going to let it sit until midnight, should be about 40f outside then and see what happens, then again at 6:30am.
xjohnx is offline
Old 10-30-2012, 09:08 PM   #3437
ish20
ish20's Avatar
Drives: 2008 Scion tC & 2013 Scion FR-S
Originally Posted by Opposed View Post
Heres a picture of my ave MPG after about 150 miles.
Alright I am having this same issue as well, I was wondering if anyone has solved this yet?
If anyone could enlighten me as how I am supposed to read the fuel% while on map 4.
Is it supposed to be located under the mpg or the avg mpg (I see numbers that bounce between 85-95 while on the mpg screen, is this the fuel level just bouncing around because the gas sloshes around while driving?)
Also is the fuel level supposed to show up while the car is not moving? same goes for the air/fuel on map 3.
Any information would be greatly appreciated as this is not a highly covered topic and not much info on this.
This is the tune I am running
RR-10895-ZA1J700C-STG1 STOCK INTAKE v1.07 FED-A
Thanks
ish20 is offline
Old 10-30-2012, 09:10 PM   #3438
xjohnx
Grip>Slip
xjohnx's Avatar
Mpg
Yep
Yep.
xjohnx is offline
ish20 (10-30-2012)
Old 10-30-2012, 09:16 PM   #3439
ish20
ish20's Avatar
Thanks very much John!!
It Seems like everything is working correctly except when my car is stationary the mpg screen shows --- no matter what map I am on, any suggestions? Also When I flashed my latest tune file was I supposed to flash back to stock before I flashed the update or does it matter?
ish20 is offline
Old 10-30-2012, 09:17 PM   #3440
nquillen
Drives: SWP BRZ
Does anyone know if the E85 tune would meet emmision standards for Low-emitting vehicle (LEV) or Ultra-low-emitting vehicle or Inherently-low-emitting vehicle (ULEV or ILEV)?
nquillen is offline
Old 10-30-2012, 09:17 PM   #3441
xjohnx
Grip>Slip
xjohnx's Avatar
That's just how it works. The stock mpg gauge does the same thing.
xjohnx is offline
ish20 (10-30-2012)
Old 10-30-2012, 10:25 PM   #3442
BAE
BAE's Avatar
Drives: BRZ Ltd WRB
Do not use 10826 !
My car is running on the 10826 file. It is not locked up, but the fuel gauge is wrong etc. What shall I do? Re-flash to the stock file? Fill in a form? Why is not the improved file sent to everyone? I am getting tired of this mess. I thought I bought a tested product.
Enkei RPF1/K&N/Perrin crank pulley/Visconti Stg1/Perrin catback and overpipe/KW V3
BAE is offline
Old 10-30-2012, 10:50 PM   #3443
dawgchow33
Drives: 13 BRZ WR Blue
Is anyone still waiting on their ProECU Kit?
Let me know here
Thanks
John
I have about 2 hours of work and you'll have a file
Still waiting on my group buy cable/dongle kit - purchased 8/22, emailed 10/14 and then was told it was going into the mail 10/15. I'd rather not post more specific details here but let me know if you need the paypal transaction numbers again.
dawgchow33 is offline
Old 10-30-2012, 11:12 PM   #3444
jpit
Drives: Subaru BRZ
If your oem fuel gauge is not working, disconnect the battery for a couple of minutes. This has worked for a few who also had that problem.
jpit is offline
LED Front Signals with Resistor Flash Correctors DarrenDriven Cosmetic Modification (Interior/Exterior/Lighting) 38 09-20-2012 03:05 PM
Brz Info/Specs (helpful info for questions asked often) Gaen BRZ First-Gen (2012+) — General Topics 0 05-24-2012 11:09 PM
How to embed a flash gallery? DarrenDriven Site Announcements / Questions / Issues 2 04-24-2012 08:43 PM
Production Spec Subaru BRZ Previewed at National Conference & Latest Info/Rumors blur BRZ First-Gen (2012+) — General Topics 130 09-01-2011 02:42 PM
