Old 10-25-2012, 11:19 PM   #141
Silverdub
Boostin'
Silverdub's Avatar
Drives: FRS-T
I hope Paul, I hope! I decided to use my 14" chop saw to cut the hoses and it went really well so i got the all done but the oil return, i need to drain the pan and weld a fitting.
First water line
Oops forgot the heat shield... Better now although not looking as good
Water feed and return
All in place!
Silverdub is offline   Reply With Quote
Old 10-27-2012, 02:30 PM   #142
Silverdub
Boostin'
Silverdub's Avatar
Drives: FRS-T
This morning i modified the oil return flange that came with the turbo by cutting the pupe and tacking my AN8 fitting then i made my oil return hose. Below is all 4 hoses. The top 2 are water feeds and bottoms are oil.
Now i just need to weld my other AN8 fitting to the pan and im all done for this part!
Old 10-27-2012, 03:32 PM   #143
*KID*
86-er
*KID*'s Avatar
Drives: BRZ tS
looks great man
2018 Subaru BRZ ts 020/500 - My Daily, work car, and track car
*KID* is offline   Reply With Quote
The Following User Says Thank You to *KID* For This Useful Post:
Silverdub (10-27-2012)
Old 10-27-2012, 06:15 PM   #144
Silverdub
Boostin'
Silverdub's Avatar
Drives: FRS-T
I just clocked the turbo, reinstalled an intercooler pipe and drilled the oil pan/tacked the AN8 fitting. Im now working on the o2 sensor bungs on the downpipe.
Old 10-27-2012, 06:22 PM   #145
Luke.Cariveau
"Fast Looking Slow Car"
Luke.Cariveau's Avatar
Drives: 13' BRZ
Wow, Your craftsmanship and ingenuity is amazing! Can't wait to see the end result of all this work!
Luke.Cariveau is offline   Reply With Quote
The Following User Says Thank You to Luke.Cariveau For This Useful Post:
Old 10-27-2012, 07:19 PM   #146
SnapOv3st3r
Drives: 400whp Scion tC
Looking good man. Was curious though, the fitting on the oil pan seems low. Is the oil level really lower than your mounting point?
SnapOv3st3r is offline   Reply With Quote
Old 10-27-2012, 09:03 PM   #147
Silverdub
Boostin'
Silverdub's Avatar
Drives: FRS-T
No but the fitting is sealed so it doesnt matter at all
Old 10-27-2012, 09:39 PM   #148
SnapOv3st3r
? What do you mean the fitting is sealed. I'm referring to the gravity feed setup you have. If the fitting is below the oil level when full, then it will cause an oil blockage and back up into the turbo and kill the turbo seals.
Old 10-27-2012, 11:04 PM   #149
Silverdub
Boostin'
Silverdub's Avatar
Drives: FRS-T
No it wont, that exactly how a vw oil return is built. Its bolted to the lowest point inthe oil pan.
Edit:
Vw 1.8t oil pan with return at the bottom
The Following User Says Thank You to Silverdub For This Useful Post:
1strwdcar (12-03-2012)
Old 10-28-2012, 12:47 AM   #150
alexmotrix
rookie drifter
Drives: 1987 ae86, 1985 celica gts
Anyway, a good friend built a S2000 turbo a long time ago and the turbo's return was trough the drain plug and he never got any problem with it
alexmotrix is offline   Reply With Quote
Old 10-28-2012, 11:24 AM   #151
SnapOv3st3r
Not sure how that applies to this car, but good luck anyway. With my setups the return had to be above the oil level, cause oil would flow were least resistance (back up the friend line and out the seals). Look forward to seeing your numbers.
Old 10-28-2012, 04:58 PM   #152
trueno86power
[||•]=(86)=[•||]
trueno86power's Avatar
Drives: 2017 Toyota 86
Nice job, can't wait to see it run !
trueno86power
GR | TOM'S | TRD
2017 Toyota 86
trueno86power is offline   Reply With Quote
The Following User Says Thank You to trueno86power For This Useful Post:
Silverdub (10-29-2012)
Old 10-29-2012, 12:53 PM   #153
ScionFamily
ScionFamily's Avatar
Drives: Magnetic Gray tC, Silver FR-S
Dude I am so jealous of this car! Subscribed, make a video of it running!!!
ScionFamily is offline   Reply With Quote
The Following User Says Thank You to ScionFamily For This Useful Post:
Old 10-29-2012, 11:37 PM   #154
soros151
SorosMotorsports
soros151's Avatar
Drives: Whiteout Pearl
Em... just read all 7 pages.... Awesome, awesome, awesome! Keep it up man!
soros151 is offline   Reply With Quote
The Following User Says Thank You to soros151 For This Useful Post:
Silverdub (10-30-2012)
Silverdub firestorm 6mt Silverdub Member's Car Journals 26 07-23-2012 06:13 PM
86-X project phenom86 Scion FR-S / Toyota 86 GT86 General Forum 1 07-11-2012 03:57 PM
Project continue 4agze Other Vehicles & General Automotive Discussions 37 11-15-2011 03:55 AM
New Project x2 S2KtoFT86 Other Vehicles & General Automotive Discussions 9 10-25-2009 12:17 PM
