Old 10-18-2012, 09:09 AM   #2773
Foobar
SLO NO MO
Foobar's Avatar
Anyone else's fuel gauge (the needle one) staying put regardless of actual fuel level? I've been staying on map 1, played around with map 2, but stayed out of map 3 and 4 which are the ones John mentioned causing problems with the gauge.
Also, under map 1, after I filled up, the MPG display showed values exceeding 100.0 - is this normal? I think it went up as high as 105 or so. Interestingly enough, the AVG MPG is still doing an average, but of the fuel level value now. So it looks like the averaging functionality isn't overridden, it continues to calculate the average of whatever value is being shown in the MPG field.
Will there be any opportunity in the future for us to request which values we would like to choose from for maps 1-4? I have no need for 0-60 or quarter mile ET - I would rely on the track's gear for that.
If we were able to request a customization of this, my ideal map loadout would be something like:
Map 1 - Stock ECU Settings - normal display
Map 2 - Visconti tuned - normal display - FF/AB/LC features turned OFF
Map 3 - Visconti tuned - Fuel % overriding MPG - FF/AB/LC features turned OFF
Map 4 - Visconti tuned - A/F Ratio - FF/AB/LC features turned ON
Foobar is offline
The Following 2 Users Say Thank You to Foobar For This Useful Post:
jpit (10-18-2012), Lee358 (10-18-2012)
Old 10-18-2012, 09:10 AM   #2774
2forme
Good night lol
I need a half day to sort out the e85 mapping.. A bunch of stuff changed so I have to redo a few things.. Need a car in person to do this.. Can't be guessing
You know, John. Mass is nice this time of year ... Just saying...
2forme is offline
The Following 2 Users Say Thank You to 2forme For This Useful Post:
ngabdala (10-18-2012), xjohnx (10-18-2012)
Old 10-18-2012, 09:17 AM   #2775
Foobar
SLO NO MO
Foobar's Avatar
Originally Posted by sportsguy83 View Post
Ok, then make a new thread and post it there. It would help A LOT of people
I don't mean to sound like one of those condescending LMGTFY guys, but in this case, I think this is actually helpful.
Google "BRZ how-to install ecutek"
Foobar is offline
The Following User Says Thank You to Foobar For This Useful Post:
JPxM0Dz (10-18-2012)
Old 10-18-2012, 09:20 AM   #2776
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
I am not trying to flash my ECU nor do I have a problem. I just responded specifically to the comment "it's not tasteful to post it here" and offering an alternative to that for the benefit of people having difficulty flashing their car.
IF I was having problems, google is my best friend but I don't have ECUTek....
Oh and also, I'm usually one of those LMGTFY guys hahaha
Sportsguy83 is offline
The Following 2 Users Say Thank You to Sportsguy83 For This Useful Post:
Foobar (10-18-2012), ngabdala (10-18-2012)
Old 10-18-2012, 09:22 AM   #2777
Visconti
Drives: 05 STi
There is also a help file included in the software guys... Under help
Visconti is offline
Old 10-18-2012, 09:24 AM   #2778
Visconti
Drives: 05 STi
Originally Posted by Mr.Jay View Post
Are you still awake John?
Geuss we might have to do this tomorrow morning then or after work.
I'll call you when I get up in 5 hours but I'll check this thread 1st just in case dont want to wake you for no reason
I'm up again
Visconti is offline
Old 10-18-2012, 10:02 AM   #2779
djliquidsteele
Drives: Scion FR-S
Yet another reason ill be going with John when I can get a tune...his sarcastic, no bullshit humorous. Love it!
Sent from my Kindle Fire using Tapatalk 2
djliquidsteele is offline
Old 10-18-2012, 10:27 AM   #2780
JPxM0Dz
F Z1LLA
JPxM0Dz's Avatar
Drives: Lexus IS-F Series 2
Just to note in regards to Jays flashing experience and most others. You all viewed a percentage notification during flash. I did not, I clicked flash ecu, then light on cable went from green to flashing red. Mouse cursor went to busy status and no pop up notification showing percentage complete.
The only way I knew it flashed successfully is I got the pop up notification to turn off ignition and then one to turn back on. After that, a successful flash notification. Done.
Could be that ecutek software is still a little buggy.
Sent from my GT-I9300 using Tapatalk 2
2URGSE
JPxM0Dz is offline
Old 10-18-2012, 10:29 AM   #2781
xjohnx
Grip>Slip
xjohnx's Avatar
The percentage indicator is hard to see unless you're looking for it. it's in the status bar at the very bottom of the window.
xjohnx is offline
Old 10-18-2012, 10:33 AM   #2782
JPxM0Dz
F Z1LLA
JPxM0Dz's Avatar
Oh ok, good to know and I didn't see that, not to mention I didn't have my glasses on either
2URGSE
JPxM0Dz is offline
Old 10-18-2012, 10:53 AM   #2783
Visconti
Drives: 05 STi
This is the update I'm pushing out today.
Thoughts?
Map 1 - Tune + 8000RPM Rev Limiter in 2nd Gear ONLY
Map 2 - Tune + 8000RPM Rev Limiter in 2nd Gear + Launch Control
Map 3 - Tune + 8000RPM Rev Limiter in 2nd Gear + Launch Control + Flat Foot Shifting + A/F Reading
Map 4 - Tune + 8000RPM Rev Limiter in 2nd Gear + Launch Control + Flat Foot Shifting + Fuel Tank % +AutoBlip
Let me know if you have any problems
Visconti is offline
The Following 2 Users Say Thank You to Visconti For This Useful Post:
arkybrz (10-18-2012), cobrabyte (10-18-2012)
Old 10-18-2012, 10:56 AM   #2784
xjohnx
Grip>Slip
xjohnx's Avatar
Thoughts?
Looks good, however if I may make one suggestion. On Map 1 & 2 (or Map 1 at the least) i would suggest leaving the stock rev limiter in all gears. This seems to be more of a "hardcore" option that only benefits 0-60 testing and leaving it stock would help give some people (Or me, at least) a little more peace of mind. Then again, at the end of the day it probably doesn't make a huge difference.
Just my opinion.
xjohnx is offline
jpit (10-18-2012)
Old 10-18-2012, 11:03 AM   #2785
Jidonsu
Drives: Scion FR-S | 6MT | Ultramarine
Thoughts?
I like it.
Jidonsu is offline
Old 10-18-2012, 11:09 AM   #2786
cobrabyte
cobrabyte's Avatar
Drives: 2013 BRZ, 2002 WRX
Thoughts?
This set is perfect.
cobrabyte is offline
LED Front Signals with Resistor Flash Correctors DarrenDriven Cosmetic Modification (Interior/Exterior/Lighting) 38 09-20-2012 03:05 PM
Brz Info/Specs (helpful info for questions asked often) Gaen BRZ First-Gen (2012+) — General Topics 0 05-24-2012 11:09 PM
How to embed a flash gallery? DarrenDriven Site Announcements / Questions / Issues 2 04-24-2012 08:43 PM
Production Spec Subaru BRZ Previewed at National Conference & Latest Info/Rumors blur BRZ First-Gen (2012+) — General Topics 130 09-01-2011 02:42 PM
