Old 10-17-2012, 01:19 AM   #57
WheelDude.com
Drives: 2013 FRS
Send a message via AIM to WheelDude.com
Originally Posted by markmatley View Post
Did you email the advancedkeys guys? or that ebay link seller?
ebay
WheelDude.com is offline   Reply With Quote
Old 10-17-2012, 01:21 AM   #58
WheelDude.com
Drives: 2013 FRS
Originally Posted by Synack View Post
It would be stuck in the ON position permanently and all your shit would still be running lol
Sent from my Nexus 7
nope, he said disconnect the ignition, so
the lock cylinder is actually only there to unlock the the wheel, the key position would do nothing if he ignition is disconnected and retorted to the keyless go system
The Following User Says Thank You to WheelDude.com For This Useful Post:
SkAsphalt (10-17-2012)
Old 10-17-2012, 03:21 AM   #59
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
I wonder how similar this would be to installing remote start? I know most remote start kits have to have a key placed in some sort of module that stays in the car at all times. I don't know much about it but just throwing it out there.
Old 10-17-2012, 10:11 AM   #60
Synack
Boosted
Synack's Avatar
Drives: Sideways
Minus the fact that your accessories including radio, headlights, etc would all still be running.
Your engine might shut off but all that other stuff wouldn't, unless I'm missing something here.
Nismo 370Z 300whp -> FR-S Turbo 450whp on E85 -> Z06 Corvette 500whp
Synack is offline   Reply With Quote
Old 10-17-2012, 11:08 AM   #61
Z0rr0
Drives: 2013 Raven 6MT FR-S
you unplug the loom from the ignition switch. therefore it's dead and does nothing when switched on. it is just there to unlock the column.
to turn the car on you use the push button. (as long as you have the RFID fob around)
Z0rr0 is offline   Reply With Quote
The Following User Says Thank You to Z0rr0 For This Useful Post:
WheelDude.com (10-17-2012)
Old 10-17-2012, 11:23 AM   #62
MattQ-WP
MattQ-WP's Avatar
Drives: Pearl White
Hmm...
Awesome link and bloody hilarious.. these guys really hit the stupidity of start buttons right on the head
An opinion is like a bad smell, every A$$HOLE has one!
INITIAL DRIVING CLIP
MattQ-WP is offline   Reply With Quote
The Following 2 Users Say Thank You to MattQ-WP For This Useful Post:
alrashwa (12-09-2012), Guff (01-31-2013)
Old 10-17-2012, 11:25 AM   #63
Synack
Boosted
Synack's Avatar
Drives: Sideways
Seems simple enough
Old 10-17-2012, 03:54 PM   #64
lordtakuban
lordtakuban's Avatar
Drives: 2013 FRS - Whiteout
Yeah. Unless it's a system that does not require a key at all, it's kinda pointless and an additional step.
2013 FRS - Whiteout - Slightly modified
2001 MR2 Spyder - Super White - Heavily modified
lordtakuban is offline   Reply With Quote
Old 10-19-2012, 11:06 AM   #65
Z0rr0
Here's the older version of the advanced keys system, installed in my wife's Baja (i traded it for the FR-S) i still have the kit, and may install it in the FR-S
[ame="http://www.youtube.com/watch?v=qqPgFlOM0NY&feature=g-upl"]RFID Keyless Entry and Push Button Start - YouTube[/ame]
Old 11-02-2012, 10:19 PM   #66
086A
086A's Avatar
Drives: Whiteout FR-S MT
Finally had time to work on this. I still havent got the power door locks going. I just ordered the iDatalink for the FRS. That should help me out a bit.....
Here is a list of what I installed.
Advanced Keys 104B Push start/Smart Keyless system
BRZ start switch panel
BRZ trunk request switch (love this one!)
The part numbers are in my previous post...
Soon to be iDatalink FRS/BRZ module. This module will take care of my power door lock issue and the imobilizer code and also give me a solid tach signal for the remote start. I tapped into the port injector wire, but it was a little to weak for the Advanced key system input specs. It worked anyway once I programmed the tach input on module. Since the idatalink has a tach output I will probably switch it over.
My review so far? It does what it says..... For now I just leave my key in the ignition in the on position. This is for the imobilizer and steering lock. Later with the iDatalink this wont be needed anymore and i will likely remove the ignition cylinder completely and place the BRZ ign. cyl. cover over the hole.
What is super cool is our cars have a nuetral switch on the manual trans. Remote start is good to go!
Things I don't like?
Holding the start switch down for 2 sec. with the brake pedal pushed to shut down. Still doing research to see if this can be changed to single push shut down.
I will get more videos up once I get the iDatalink installed and working. This is a quick vid I did to show you my progress....
-Aloha-
[ame="http://www.youtube.com/watch?v=KP9S5nG-Gms"]2013 Scion FRS push start installed! - YouTube[/ame]
086A is offline   Reply With Quote
The Following 4 Users Say Thank You to 086A For This Useful Post:
calis5nest (12-23-2012), civicdrivr (11-20-2012), TRD_07 (04-10-2013), xpicer (11-02-2012)
Old 11-06-2012, 09:17 AM   #67
Razing
Razing's Avatar
Drives: 2013 Subaru BRZ WR Blue Pearl
Originally Posted by 086A View Post
Had a hope at first that this would be an installation video.
Looks nice though, good job
Razing is offline   Reply With Quote
The Following User Says Thank You to Razing For This Useful Post:
086A (11-06-2012)
Old 11-06-2012, 12:32 PM   #68
WheelDude.com
Drives: 2013 FRS
-Aloha-
Are the ignition wires at the key lock cylinder disconnected? So if you take a key in there and turn it, will it do nothing?
What do you plan on doing in order to disable the power steering lock?
Old 11-06-2012, 08:22 PM   #69
juny3
Drives: FRS
More IMG
https://www.dropbox.com/s/0l3br08ti2...2013.19.52.jpg
Simple manual
https://dl.dropbox.com/u/68618847/FR-S%20Alarm.pdf
Alarm's name is EASYCAR E8-B
I DID IT ^^
juny3 is offline   Reply With Quote
The Following User Says Thank You to juny3 For This Useful Post:
chimmay (11-06-2012)
Old 11-06-2012, 08:54 PM   #70
086A
086A's Avatar
So if you take a key in there and turn it, will it do nothing? The wires are completly disconnected from the switch. So it will do nothing.
The steering lock is mechanical and is activated by the lock cyl. I plan on removing the cyl. once my Bypass module comes in. Should be here Friday! I will try to make a better DIY once I confirm it does what i want it to do.
The Following 2 Users Say Thank You to 086A For This Useful Post:
civicdrivr (11-20-2012), WheelDude.com (11-07-2012)
STI Push Button Start Proud of BOXER Cosmetic Modification (Interior/Exterior/Lighting) 117 08-05-2019 05:19 PM
for sale: OEM - RED STI push button start, brand new. notFRS Interior Parts (Incl. Lighting) 3 08-02-2012 02:16 AM
Push button start Symbiont Cosmetic Modification (Interior/Exterior/Lighting) 5 06-17-2012 01:45 PM
push button start standard? sparrowhawk BRZ First-Gen (2012+) — General Topics 2 03-04-2012 03:52 PM
Push button start general question maxeveland Other Vehicles & General Automotive Discussions 9 02-14-2012 10:13 AM
