Old 10-16-2012, 01:11 PM   #1
Cowbun
Drives: Scion FRS Whiteout
Need help figuring our how to remove these pieces. !!
Can someone please explain how to remove these pieces!!
http://i49.tinypic.com/311uquu.jpg
Cowbun is offline   Reply With Quote
Old 10-16-2012, 01:56 PM   #2
CaptainSlow
CaptainSlow's Avatar
My guess is a lot of work. For example, you'll probably have to remove the airbag to get to that piece on the steering wheel.
Ultramarine 2013 Scion FR-S 6MT
CaptainSlow is offline   Reply With Quote
Old 10-16-2012, 02:12 PM   #3
Hardrock4445
Hardrock4445's Avatar
Hardrock4445 is offline   Reply With Quote
Old 10-16-2012, 02:14 PM   #4
Cowbun
I want to search for it but I don't know what the pieces are called. Hence not getting any results.
Old 10-16-2012, 02:16 PM   #5
TemeCal
Drives: 86
Search for "plastidip". I could have sworn someone removed all of those pieces, and plastidipped them. You may have better luck searching for this term. I'll see if I can find the thread also...
Edit: It was actually Hardrock4445 that did it! Here is the thread
TemeCal is offline   Reply With Quote
The Following User Says Thank You to TemeCal For This Useful Post:
CaptainSlow (10-17-2012)
Old 10-16-2012, 02:21 PM   #6
Cowbun
Ah, thanks. I was actually planning to plasti dip those parts too.
Old 10-16-2012, 11:26 PM   #7
PrinzJ
Drives: White Fr-S and Black 9thgen Corolla
Search JDM knee pad for the middle columns
Perrin Ebrake button for the gear box ring
Steering wheel silver piece comes right out, two tabs right in the middle of it.
vent rings: pull the vent housing out use a flat head trim remover.
PrinzJ is offline   Reply With Quote
The Following User Says Thank You to PrinzJ For This Useful Post:
Old 10-17-2012, 08:20 AM   #8
CaptainSlow
Well, I take my comment back then! I was thinking it would be as difficult as the GTO metal hub inserts (which do require the removal of the airbag to remove)
Old 10-17-2012, 08:56 AM   #9
Jonwi5
Drives: None For Now
This guy remove the center console see the video it really easy.
[ame="http://www.youtube.com/watch?v=GzbAtqc_5dQ&list=FL53wMKRAwcFgnPGGgF6UFjw& index=4&feature=plpp_video"]Scion Fr-s/Toyota 86/Subaru Brz-Hvac Led Swap - YouTube[/ame]
Jonwi5 is offline   Reply With Quote
The Following User Says Thank You to Jonwi5 For This Useful Post:
mezdup (10-17-2012)
Old 10-17-2012, 08:57 AM   #10
Jonwi5
About the other part not sure for now.
Old 10-17-2012, 01:51 PM   #11
phenom86
phenom86's Avatar
Drives: Scion FRS Asphalt
Here you go...
http://www.ft86club.com/forums/showp...7&postcount=66
phenom86 is offline   Reply With Quote
Old 10-17-2012, 02:25 PM   #12
Hardrock4445
You do have to remove air bag to remove steering wheel piece. There are 3 holes around the steering wheel there is a metal tab in each one you need to push that metal tab in slightly while pulling out on airbag assy. You will feel each one click as it pops out. Then there are 2 screws holding that trim piece on. One painted put screws back on and just "pop" tge air bag back into place
Old 10-17-2012, 06:44 PM   #13
ph0en1xtk
ph0en1xtk's Avatar
Drives: Raven MT Scion FR-S
i did the same thing to all of those trim pieces recently and i was shocked at how easy it was to remove all of them.
Shifter trim - grab up under the edge of the shift boot and just pull up, its held in with a few tabs. just give a little pressure on the first one and the rest come up very easily.
ac vents - reach a finger inside of each vent and hook the side and pull towards you, they slide right out, then the silver trim piece actually snaps off the vent itself
steering wheel - if you look behind the wheel on the hub, there are three small holes. take something small like a flathead screwdriver and push it in those holes, it will release a clip of some sort and youll feel the air bag come forward a bit. Release all three and you can lift the air bag piece out of the way enough to remove the two screws that hold in the trim
climate control trim - this one is the most difficult in my opinion because it requires the removal of quite a few other pieces. best bet is to look up in the DIY section - JDM knee pad install
also if you were curious at all, the silver trim on the door panels also pops right off. there is a small slot underneath each side where you can fit a flathead screwdriver, just pop it up and gently remove each clip from the bottom upward until you get to the top where there is a tab that slides in vertically. make sure not to bend that tab up top and it comes out easily.
hope that was helpful, and good luck with the plastidip. it makes the interior looks much cleaner in the end!
ph0en1xtk is offline   Reply With Quote
The Following 3 Users Say Thank You to ph0en1xtk For This Useful Post:
LXXXV1 (11-02-2014), Tr1huynh (04-29-2015), turbocat (03-26-2013)
Leather wrapped interior pieces (including dash trim) pics Gen Cosmetic Modification (Interior/Exterior/Lighting) 36 11-18-2012 04:08 PM
Remove dry wax? lbroskee Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 12 10-14-2012 09:54 PM
86 GTS Dash Pieces - a word of warning Sutty AUSTRALIA 4 09-18-2012 11:17 AM
Coating for fake carbon fiber dash pieces? FRSowner Scion FR-S / Toyota 86 GT86 General Forum 13 08-08-2012 01:56 AM
WTT: BRZ(mine) trim pieces for FRS(yours) trim pieces Flat Black VW Interior Parts (Incl. Lighting) 14 07-27-2012 11:01 PM
