#57 |
#58 | |
the lock cylinder is actually only there to unlock the the wheel, the key position would do nothing if he ignition is disconnected and retorted to the keyless go system |
| The Following User Says Thank You to WheelDude.com For This Useful Post: | SkAsphalt (10-17-2012) |
#59 |
Drives: Whiteout FR-S
I wonder how similar this would be to installing remote start? I know most remote start kits have to have a key placed in some sort of module that stays in the car at all times. I don't know much about it but just throwing it out there.
#60 | |
Boosted
Drives: Sideways
Your engine might shut off but all that other stuff wouldn't, unless I'm missing something here.
Nismo 370Z 300whp -> FR-S Turbo 450whp on E85 -> Z06 Corvette 500whp
#61 | |
Drives: 2013 Raven 6MT FR-S
to turn the car on you use the push button. (as long as you have the RFID fob around) |
| The Following User Says Thank You to Z0rr0 For This Useful Post: | WheelDude.com (10-17-2012) |
#62 |
Drives: Pearl White
Awesome link and bloody hilarious.. these guys really hit the stupidity of start buttons right on the head
#63 |
Boosted
Drives: Sideways
Seems simple enough
#64 |
Drives: 2013 FRS - Whiteout
Yeah. Unless it's a system that does not require a key at all, it's kinda pointless and an additional step.
2013 FRS - Whiteout - Slightly modified
2001 MR2 Spyder - Super White - Heavily modified |
#65 |
Here's the older version of the advanced keys system, installed in my wife's Baja (i traded it for the FR-S) i still have the kit, and may install it in the FR-S
[ame="http://www.youtube.com/watch?v=qqPgFlOM0NY&feature=g-upl"]RFID Keyless Entry and Push Button Start - YouTube[/ame] |
#66 |
Drives: Whiteout FR-S MT
Finally had time to work on this. I still havent got the power door locks going. I just ordered the iDatalink for the FRS. That should help me out a bit.....
![]() Here is a list of what I installed. Advanced Keys 104B Push start/Smart Keyless system BRZ start switch panel BRZ trunk request switch (love this one!) The part numbers are in my previous post... Soon to be iDatalink FRS/BRZ module. This module will take care of my power door lock issue and the imobilizer code and also give me a solid tach signal for the remote start. I tapped into the port injector wire, but it was a little to weak for the Advanced key system input specs. It worked anyway once I programmed the tach input on module. Since the idatalink has a tach output I will probably switch it over. My review so far? It does what it says..... For now I just leave my key in the ignition in the on position. This is for the imobilizer and steering lock. Later with the iDatalink this wont be needed anymore and i will likely remove the ignition cylinder completely and place the BRZ ign. cyl. cover over the hole. What is super cool is our cars have a nuetral switch on the manual trans. Remote start is good to go! Things I don't like? Holding the start switch down for 2 sec. with the brake pedal pushed to shut down. Still doing research to see if this can be changed to single push shut down. I will get more videos up once I get the iDatalink installed and working. This is a quick vid I did to show you my progress.... -Aloha- [ame="http://www.youtube.com/watch?v=KP9S5nG-Gms"]2013 Scion FRS push start installed! - YouTube[/ame] |
| The Following 4 Users Say Thank You to 086A For This Useful Post: |
#68 | |
What do you plan on doing in order to disable the power steering lock? |
#69 |
Drives: FRS
![]() More IMG https://www.dropbox.com/s/0l3br08ti2...2013.19.52.jpg Simple manual https://dl.dropbox.com/u/68618847/FR-S%20Alarm.pdf Alarm's name is EASYCAR E8-B I DID IT ^^ Last edited by juny3; 11-07-2012 at 04:25 PM. |
| The Following User Says Thank You to juny3 For This Useful Post: | chimmay (11-06-2012) |
#70 | |
| The Following 2 Users Say Thank You to 086A For This Useful Post: | civicdrivr (11-20-2012), WheelDude.com (11-07-2012) |
| STI Push Button Start | Proud of BOXER | Cosmetic Modification (Interior/Exterior/Lighting) | 117 | 08-05-2019 06:19 PM |
| for sale: OEM - RED STI push button start, brand new. | notFRS | Interior Parts (Incl. Lighting) | 3 | 08-02-2012 03:16 AM |
| Push button start | Symbiont | Cosmetic Modification (Interior/Exterior/Lighting) | 5 | 06-17-2012 02:45 PM |
| push button start standard? | sparrowhawk | BRZ First-Gen (2012+) — General Topics | 2 | 03-04-2012 04:52 PM |
| Push button start general question | maxeveland | Other Vehicles & General Automotive Discussions | 9 | 02-14-2012 11:13 AM |
