Old 10-11-2012, 04:40 PM   #29
Flat Black VW
Flat Black VW's Avatar
Drives: 2013 Subaru BRZ
I was doing a bit more research and found these:
http://www.brandsport.com/excl-793.html
Not sure how I feel like running something like this although if they are torqued down properly they should be fine I would think. Anyone have any experience with these?
Flat Black VW is offline   Reply With Quote
Old 10-11-2012, 04:58 PM   #30
seven
Tells it like it is
seven's Avatar
Drives: SS1LE | F150 Diesel | Civic | S3
Originally Posted by Turbo Den View Post
please update this thread as you put all 4 wheels on.
I also want to use 15 inch wheels.
with a slightly different purpose.... i want 15x8 wheels with 225/45/15 Toyo R1R ... for better gearing ratio.
I like your style sir!
Originally Posted by Flat Black VW View Post
I will definitely update when I put these on for winter, as long as we can figure out if the lug nuts will work.
Not sure how well 15x8 will work, you will probably need a pretty crazy offset as some people were saying they had rubbing on the inside with the steering knuckle IIRC. Either way if you do it before me let us all know how they go!
ditto!
Since they're not going to be on track wheels... I'd run em. I never do more than 65-70 on the street/highway anyway. I'd just check em week to week to make sure they're tight (which I have a feeling they will be). I'm gonna pick up the Avus' this weekend and order tires and the lugs I posted. Flat Black VW and/or myself will post our findings.
seven is offline   Reply With Quote
Old 10-11-2012, 05:00 PM   #31
Flat Black VW
Yeah I think im going to give these washers a shot, these will be my snow winter wheels and I have a chevy S10 that I plan to drive in the winter most of the time So im not too concerned, ill just check them whenever I go out for a drive.
Old 10-11-2012, 05:03 PM   #32
seven
Tells it like it is
seven's Avatar
Keep a tq wrench/breaker bar with a lug socket in the trunk... Not hard haha.
Old 10-11-2012, 05:18 PM   #33
Spartan65
USMC Veteran Semper Fi
Spartan65's Avatar
Drives: 2010 WR Blue STi
These should work, the only thing I would do if I was using them is count how many turns the lug has with out them and then count how many with them. If you lose more than seven turns that's close to 1/2 inch of stud loss. My experience with spacers would say to at this max variable I would personally worry too much about the safety.
Spartan65 is offline   Reply With Quote
Old 10-12-2012, 11:09 PM   #34
dareo
Drives: 1987 MR2
I now want an FRS even more knowing it can share VW wheels. I have the 16" bbs on my TDI and they are sweet wheels. Very light and strong. Kinda sucks having good running paid off older cars...no justifiable reason to get an FRS yet!
dareo is offline   Reply With Quote
Old 10-12-2012, 11:48 PM   #35
dsgerbc
Drives: BRZ(sold), STI
Interesting washers. Hm. Makes me want to try to test-fit some VW wheels for sale locally.
Radius still seems to be off VW spec.
Would still prefer proper lugs, but couldn't find any.
Old 10-16-2012, 03:53 AM   #36
seven
Tells it like it is
seven's Avatar
Picked these up this weekend Ready for paint/plasti dip...
Old 11-05-2012, 04:22 AM   #37
seven
Tells it like it is
seven's Avatar
Update.... Bought the adaptors for the lugs and the wheels/tires (as previously) mentioned...
It all works fine
The Following User Says Thank You to seven For This Useful Post:
Flat Black VW (11-05-2012)
Old 11-05-2012, 01:28 PM   #38
seven
Tells it like it is
seven's Avatar
Pic of mine installed, they were plasti-dipped black with silver metalizer. Sadly its to overcast to see it very well. They look like a dark charcoal metallic. Camera phone quality too :-/
The Following 2 Users Say Thank You to seven For This Useful Post:
chaoskaze (12-29-2015), Flat Black VW (11-05-2012)
Old 11-05-2012, 02:03 PM   #39
Turbo Den
Drives: FRS, IS300, 911sc
Like !
Turbo Den is offline   Reply With Quote
Old 11-05-2012, 03:11 PM   #40
Flat Black VW
glad to see it worked for you! Looking forward to getting mine on there.
Any rubbing issues while driving?
Old 11-05-2012, 03:36 PM   #41
dsgerbc
Yeah, a close-up of clearance between the wheel and brake caliper and between the inner lip and a steering joint would be awesome.
Old 11-05-2012, 03:44 PM   #42
Ingen
Drives: Ultramarine FR-S 6MT
So if 15x6 fits, we can maybe run Konig Heliums?
11 lb wheels for autocross here I come!
On second thought, maybe I'll let someone else do it first and see how it goes
Car Received: 10/18. Break in ended: 10/28
Goal: Openflash UEL headers, Stage II 93 oct, TRD intake, arm rest :P
Ingen is offline   Reply With Quote
Which 18" wheels will weigh the same or less than the stock wheels? mickey177 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 32 05-16-2013 03:07 PM
Got some new wheels for my DGM BRZ / "DATBRZ" DookDookDGM BRZ Photos, Videos, Wallpapers, Gallery Forum 11 09-11-2012 12:06 PM
>>> MOTEGI WHEELS 17"/18" - INCLUDING MR121/MR125 ROTARY FORGED @ 17 LBS/19 LBS BestWheelDeals Wheels and Tires 2 09-07-2012 09:26 PM
"What kind of wheels are these?" MEGATHREAD switchlanez Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 08-03-2012 11:03 PM
How harsh is the ride on 18" vs 17" wheels? mickey177 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 07-18-2012 03:08 PM
