#1471 | |
Drives: 2013 Scion FR-S-white out
| The Following User Says Thank You to Plxdjake89 For This Useful Post: | ftc~brz (10-10-2012) |
#1472 | |
Drives: several
![]() That's the spirit! So you're saying the field guy was in fact there and did the reflash? Really hope you get to go on a nice autumn twisties drive for your birthday! <3 |
| The Following User Says Thank You to einzlr For This Useful Post: | ftc~brz (10-10-2012) |
#1473 | |
Done
Drives: WRB BRZ
as for getting old, It's not that bad...I will be a cool cougar with great taste in cars one day...as for now I don't look my age so it doesn't sting as bad yet. |
#1474 | |
Long Distance Driver
Tempting, although my service adviser did say that if they had the machine to do that, they wouldn't have ordered an ECU.
#1475 |
And Happy Birthday ftc!
| The Following User Says Thank You to Sargy For This Useful Post: | ftc~brz (10-10-2012) |
#1476 |
Drives: 2013 Scion FRS
That's my POINT. They don't need a machine. But whatever, it seems this thread has just become a chat room while we wait for our cars.
Scionara to you
#1477 |
Drives: 92 lexus sc300 > whiteout MT FRS
#1478 |
Drives: FR-S 6MT Argento, 2012 Golf R
Add me to the list, I think... My FR-S, bought June 15th, vin. 7008xx PA, 6MT, careful 1000 mile break in, threw a cel blink first at 1300 miles when I hit 7100 rpms then went out. Came on again, at redline or close, shortly after that. Next time it blinked and stayed on with sl and cruise light. I don't like idiot lights on in a new car, so I pulled batt. terminal and reset light. I never got the idle hunt but it was in a safe mode whenever the cel was on. I hate dealers so I just pulled the batt. terminals and shorted + to - each time that happened and everything went back to perfect for another couple hundred miles or so. I put Amsoil in at 7000 and have over 7500 on the car now. Car runs perfect, idles well, pulls stronger the more miles I put on it, and I zip up to redline every time I drive it.... Last cel was well before oil change.
Makes me think the comment I read about possible oil passage issues in the head castings might be lessened with the Amsoil product?? |
| The Following 4 Users Say Thank You to F1shTa1l5 For This Useful Post: |
#1479 |
New Toyota Fix???
Ok, let me try this one more time:
I got a call from my service Adviser (SA). He said he got a call from Toyota with a fix. According to my Invoice this is what they did: "Toyota called and advised RECAL for ECM Available. PERFORMED RECAL WITH NEW ID. Test drove 50 miles. No MIL returned and VEH runs good." My car had 600 miles on it. My interpretation is this: NO new ECU. No REFLASH. No Special dealer hardware needed, it's a different way to fix the ECU. My car runs great with a rock solid 650 RPM. Understood?
Scionara to you
#1480 |
Done
Drives: WRB BRZ
Update #81
10/10 call from service advisor: Subaru field tech flashed ecu. Shop forman is going to drive car for a few days to monitor cel/idle issue. I can call Friday am to see if car is ready for me to take home.
![]() Also as per tsb for crickets: will be correcting this as well as the chirping was rampant and not a figment of my imagination, or a "cute characteristic" as I last called it. Last edited by ftc~brz; 10-10-2012 at 05:08 PM. |
#1481 | |
Drives: GT86
#1482 |
Drives: Scion FR-S Asphalt
So...I dropped my car off at the dealership today to have the fuel pump replaced, to correct the chirping under the hood. As I pull in, the idling issue that has been plaguing our cars starts happening; car idles extremely rough and threatens to stall. As soon as I park it in their service lane, the CEL comes on and starts flashing. Talk about good timing?
FR-S/Nevada/3144 Miles (though it has been idling odd for about 1500 miles now, the CEL/Rough Idle just occurred today)
#1483 | |
No dealer tools needed, no special factory tech needed, like in a "re-flash" So, IMHO, a RECALabration is not the same as a reflash.
Scionara to you
#1484 |
Drives: Asphalt Grey FR-S
my idle is around 650, which is kinda low considering my previous car mazda 3. it was around 750~850.. the idle went up & down for a while then I found out the maf sensor was damaged while changing to aftermarket air intake kit.
when the a/c pump kicks in it has the tendency to lower the engine rpm unless the ecm/ecu is programmed to run on higher rpm when a/c is on to overcome this. just my $0.02
2013 Asphalt Grey FR-S MT VIN: 7086XX
| NW Owner List & Event Archive | DarrenDriven | Northwest | 1643 | 08-05-2016 07:48 PM |
| Idle issue? | yayforaddison | Issues | Warranty | Recalls / TSB | 891 | 07-14-2016 11:42 AM |
| Idle issue | scioneric | CANADA | 23 | 08-24-2012 02:40 AM |
| Idle issue poll/role call | Hawaiian | Scion FR-S / Toyota 86 GT86 General Forum | 8 | 06-13-2012 01:00 PM |
| An unofficial message from TMCA | Courtz1074 | AUSTRALIA | 25 | 05-17-2012 11:00 AM |
