AVOturboworld
Old 10-06-2012, 06:42 PM   #813
Bomb3r
Bomb3r's Avatar
Drives: Australian GT86
I know Perrin Performance has done some research into power loss in relation to Oil Temps, so they are working on a cooler kit currently. Given they are doing the R&D in relation to this discovery and not just pumping our run of the mill "type s" or "type R" cooler kit, i would lay my dollars down with them...
Providing there is fresh airflow and no influence of other heat sources, placement isn't too much of an issue.
Bomb3r is offline   Reply With Quote
Old 10-06-2012, 07:21 PM   #814
Gen
Drives: Scion FR-S
MAF sensor is be good for more than 250whp / 5psi on pump.
Strange.
Time to go SD
While you're here, if you give me a free tune I'll buy ya a beer. :happy0180:
Gen is offline   Reply With Quote
Old 10-06-2012, 07:30 PM   #815
JP
Backyard Fabricator
Drives: JZX83, SF5 GT, ZZE82 turbo
Originally Posted by diss7 View Post
That is an excellent dyno plot, well done! It amazing what can be achieved with a bit of R&D.
Directed to AVO and others who are serious about this kit. What are you considering for an oil cooler kit?
The Greddy kit mounts onto the bar that is now where the intercooler to TB pipe is. I wouldn't be surprised if this pipe could be pulled back and the oil cooler put in front of it, but this isn't ideal, and neither is having a large pipe behind the cooler, that would block air flow.
Don't get me wrong, I'm not having a dig at the turbo kit design. I would much rather it be designed the way that it has, and and oil cooler solution be an after thought. But I think enough pictures have been released now that we have reached the point of considering the oil cooler location.
I'm not sure why you'd try and go with an off-the-shelf oil cooler kit when turbocharging the car.
I'll be putting my own kit together with a Mocal or Setrab core,thermostatic sandwich plate and -10 lines to fit the car perfectly.
JP is offline   Reply With Quote
Old 10-06-2012, 07:55 PM   #816
diss7
Drives: AE86, 2x GT86, TE27
I'd get an off the shelf oil cooler kit, the same reason I would get an off the shelf turbo kit; because someone else has already designed it.
I hear what you're saying, that it might be best to build a custom one, but anyone designing a turbo kit should also consider an oil cooler kit for their product as an up-sell. Seeing NA FA20's getting unacceptable oil temps means that it's going to be a definite for any turbo setup.
diss7 is offline   Reply With Quote
Old 10-06-2012, 08:13 PM   #817
JP
Backyard Fabricator
putting together an oil cooler kit isn't rocket science... But I can't see the majority of "kits" out there being best fit for a FMIC setup
The Following User Says Thank You to JP For This Useful Post:
No Limit Motorsport (10-07-2012)
Old 10-06-2012, 09:17 PM   #818
RedRocket
RedRocket's Avatar
Drives: Firestorm Red FR-S
5k installed I would buy.
RedRocket is offline   Reply With Quote
Old 10-06-2012, 10:17 PM   #819
Ravenlokk
Ravenlokk's Avatar
Drives: 2013 Raven FR-S
I think thats what AVO is betting on with their est pricing structure .
Ravenlokk is offline   Reply With Quote
Old 10-06-2012, 10:30 PM   #820
drifter
Drives: truck and old car
these kits cost around $1500 to install?
drifter is offline   Reply With Quote
Old 10-06-2012, 10:49 PM   #821
Ravenlokk
Ravenlokk's Avatar
I'm sure theres a wide range of prices depending on where you take it. I wouldn't take it to just any shop to have it done, i'd want to be sure they're comfortable with boxer engines, and/or doing performance turbo installs.
Also, the estimated price was ~3600-3800 + shipping + taxes? (depending on state i'd imagine). So it should all be doable for < or approximately 5k. Realisticly 6k with an ecuTek(or whatever else is available at the production launch) license and a proper tune.
Old 10-06-2012, 11:17 PM   #822
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
I fully intend to install this myself. Saves me some money for the tires Im inevitably going to roast!
Parting out HERE
civicdrivr is offline   Reply With Quote
Old 10-06-2012, 11:53 PM   #823
WolfsFang
Scrape Master
WolfsFang's Avatar
Drives: Goal: Oldest FRS State Side
Same here, if i buy this, taking taking 2 days off from work.
You do realize comparing the BRZ to the FR-S is like comparing which hand you love masterbating too right?
WolfsFang is offline   Reply With Quote
Old 10-07-2012, 02:18 AM   #824
Gen
Drives: Scion FR-S
I've heard repeatedly how simple these are to install. We'll see--swapping pads and bleeding brakes are about the limit of my mechanical experience.
Old 10-07-2012, 02:22 AM   #825
JimmyMac
JimmyMac's Avatar
Drives: 2013 FR-S, 2016 Miata Club
Weekend install for me.... I'll probably wait till spring though. No use for me in the winter. Plus I'll have some tax money!!
JimmyMac is offline   Reply With Quote
Old 10-07-2012, 02:45 AM   #826
WolfsFang
Scrape Master
WolfsFang's Avatar
i just installed my crank pulley, i feel like i can do a motor swap now lol.
The Following User Says Thank You to WolfsFang For This Useful Post:
Sportsguy83 (10-07-2012)
accelerated performance, avo turbo kit, avo turboworld, avoturboworld turbo kit, brz forum, brz forums, brz turbo, brz turbo kit, fr-s turbo, fr-s turbo kit, frs turbo, frs turbo kit, scion fr-s turbo, scion fr-s turbo kit, scion fr-s turbocharger, scion frs fi, scion frs turbo, scion frs turbo kit, scion frs turbocharger, subaru brz fi, subaru brz forum, subaru brz forums, subaru brz turbo, subaru brz turbo kit, subaru brz turbocharger
PC Build Thread WingsofWar Off-Topic Lounge [WARNING: NO POLITICS] 126 01-22-2017 09:59 PM
FT-86 SpeedFactory - Firestorm Red - Build Thread FT-86 SpeedFactory Member's Car Journals 38 02-26-2015 02:42 PM
JoeBoxer FR-S build thread JoeBoxer Member's Car Journals 112 04-08-2013 01:19 AM
Compression ratio 12.5:1. Bye-bye Super charger & Turbo build? fred_boosted Engine, Exhaust, Transmission 215 12-12-2011 07:23 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 10:13 AM
