Drives: 2013 Scion FRS
Gas needle not pointing to full
I just went to the gas station and topped off the gas tank.....But when I went to start the car....it wasn't showing full....Hmmm
#2 |
Drives: several
Gas gauges do that; they're not precision instruments. Don't even worry about it
#3 |
Drives: '13 Ultramarine
I think I know what you are talking about. This has happened to me a few times as well. Every once in a while, when I fill the car, the needle stops about a needle's width short of full. The first time it happened, I made it a few blocks, and thought WTF? I pulled into the next gas station and managed to pump about 30 cents worth into it.
#4 |
Drives: Supercharged Golf Cart
Several people have mentioned this for this car. I think I prefer the Honda method which is often erroneous too. In their case it reads full for the first 3 gallons of usage then drops off significantly. I remember in my older Si's that I would make it a game to get as many miles as possible before the needle moved. Just over 100 is my record which is almost 1/3rd of the tank.
#5 | |
You know you want it.
Drives: '13 FR-S
The next thing you know you're at half a tank.
The Following User _________ Stay_Puft(09-13-2014) Says Thank You to MmmHamSandwich For This Useful Post: |
#6 |
USMC Veteran Semper Fi
Drives: 2010 WR Blue STi
This is an issue I have quite frequently, I'll put a full tank and it only goes up to 3/4.
#7 |
Drives: Asphalt fr-s 6mt
I was thinking that too while i was driving around tonight. Drove over 100km and needle barely moved until i turned the car off lol
#8 |
Drives: FR-S Hot Lava (AT)
I had this happen to me also for about 6 fill ups would not go past 3/4 mark. then one day while driving around the gas gauge moved to full mark and knock on wood
, so far after 3 fill ups seems to be working fine now when I go and fuel up.
#9 |
Drives: 2013 BRZ Limited 6MT WR Blue Pearl
Call Subaru customer service instead. They'll tell you to go to the gas station. I don't know what I would do without those guys.
#10 |
Good to hear I'm not alone....
#11 |
Drives: 2017 Subaru BRZ PP
This is just how the Denso or the fuel tank manufacturer (I forgot their name) designed it. My current car is also like this. It takes a few minutes or so after refueling to get an accurate reading and sometimes when you're on a hill or something, it can be a little off. So yeah, annoying but I'm pretty sure that's just how it is so there's no sense demanding a fix.
Edit: I suppose this may not be the same issue if it never goes past 3/4 tank... In which case, that is a bit strange. All the more reason I wish it had a digital miles until empty display.
Toyota + Subaru =
#12 |
Drives: Scion FRS Ht Lva(AT)
I have seen this once when I only filled up to full with <10 litres!
| 0W-20 full synthetic oil for $3.49 a quart | terrypm | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 26 | 04-08-2014 04:51 PM |
| Help finding thread about startup rpm needle | Prava | Electronics | Audio | NAV | Infotainment | 2 | 07-01-2012 01:29 PM |
| 86 Full Throttle Video + another. | Aus86 | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 2 | 04-02-2012 07:07 AM |
| Autoexpress full review | Sport-Tech | BRZ First-Gen (2012+) — General Topics | 13 | 03-26-2012 08:56 PM |
| Anyone else paying in cash/full? | iff2mastamatt | Scion FR-S / Toyota 86 GT86 General Forum | 46 | 03-23-2012 03:14 PM |
