Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > AUSTRALIA
AUSTRALIA Australia and New Zealand
Old 09-25-2012, 12:35 AM   #15
nzer
nzer's Avatar
Drives: 2012 Grey TRD GT86, 2015 VW Golf R
Toyota NZ advise the TRD Brembo Brake Kit comes with Ferodo FM1000 street pads.
And from google they sound like a pretty good all round pad - "These are the standard Brembo street pads used for the Monobloc M caliper, made by Ferodo. These are an excellent street pad with many positive attributes for daily driving - low noise, excellent initial bite and modulation. Their only downside is the price and they can be more dusty than a Hawk HPS. This is the standard pad that Brembo equips for the M caliper when new."
nzer is offline   Reply With Quote
The Following 2 Users Say Thank You to nzer For This Useful Post:
Sargy (06-16-2016), yomchi1989 (09-25-2012)
Old 09-25-2012, 02:13 AM   #16
yomchi1989
n00b
Drives: Pfft... go by Kangaroo! STRAYA!
Originally Posted by Cappuccino View Post
I would be looking at 2nd Hand STI stuff then. Rumour has it the base of the 86 is actually the hatch/ sedan Imperza. So the STI stuff should bolt on. I have also seen pervious Gen WRX 4 Pots on an 86 as well.
Bare in mind you may need new wheels to clear the brakes. Which I'm sure your doing any way but just make sure the wheels your going for clears them
Just like Ran94a mentioned be very selective on your brake pads make sure they are more street based then track based especially since your not really using it as a hardcore track car.
Super helpful!! Thank you
yomchi1989 is offline   Reply With Quote
Old 09-25-2012, 02:14 AM   #17
RAN94A
Grand PooBah
RAN94A's Avatar
Drives: Toyota 86 GT MT
why would the TRD kit not use TRD pads...? Seems crazy
http://www.nengun.com/trd/black-series-brake-pads
RAN94A is offline   Reply With Quote
Old 09-25-2012, 02:21 AM   #18
Bomb3r
Bomb3r's Avatar
Drives: Australian GT86
MRT Australia can do the STI Brembo swaps for 2.5k will all new hardware. Capliers, Disks, Lines, Pads...
Also, as seen in Motor Magazine, they are running Alcon stuff with good results..
Bomb3r is offline   Reply With Quote
Old 09-25-2012, 02:53 AM   #19
Surok
Wise old man
Surok's Avatar
Drives: 86 GTS
wait... so i can drive into MRT with my 86.. pay 2.5K and then i have brand new front and rear brembos?
i assume i cant use stock wheels, but i can use a stock STI wheel? like a 18x7.5 +48?
Surok is offline   Reply With Quote
Old 09-25-2012, 03:45 AM   #20
czar07
czar07's Avatar
Drives: '97 RSP JZZ30 GT-T
Originally Posted by 86drift View Post
I'd rate AP and Alcon as the best you can buy. But they're more race setups than street. The hooked patterns do look cool. If you want something that looks good you could use DBA's new drilled and slotted rotors and STI brembos. I'll be doing Wilwood kits locally soon, which should be cheaper than any other kit out there.
In terms of using race brakes on the street, it all comes down to pad choice. You just need something that works well when cold. There's lots of choice out there for pads.
Very interested in this. I thought about buying some nice 6 pot Wilwood calipers and get some custom made caliper mounts, but if you will be doing a kit, that will be much better. Saves me all the hassle.
Germans>Japanese>Italians>Americans. Unless its a Corvette.
czar07 is offline   Reply With Quote
The Following User Says Thank You to czar07 For This Useful Post:
Neilus (09-25-2012)
Old 09-25-2012, 04:38 AM   #21
nix
nix's Avatar
Drives: AVO BRZ
I don't think the rear STI brembos fit our car?
nix is offline   Reply With Quote
Old 09-25-2012, 06:06 AM   #22
Cappuccino
Drives: 2012 Tornado Grey Toyota 86 GTS
I think the rears need to be off a peanut shape to fit don't quote me though as I don't remember 100% what I was told.
Cappuccino is offline   Reply With Quote
Old 09-25-2012, 06:21 AM   #23
MZ21
Drives: 86GT
Do you have a link to this mythical Brembo setup that MRT is selling. As I just can't see it happening for AUD 2,500. Maybe, just maybe the front only kit.
If they do in fact have this for 2.5K for a front a rear Brembo conversion I will be there immediately. But I just don't see it coming in at that price.
1. No way will you get a *BRAND NEW* (or even used set) of front and rear Brembo setup for 2.5K. I have been looking all over.
Here's an example of the *USED* setup.
Calipers front and rear $1200
Front and Rear Rotors $800
Pads front and $500
Braided lines front and rear $200
Dogbone for rear $250
DOT 6 fluid $50
2 hours labour (in case you're getting a w/s to fit) $150
$3150.
Now that's a pretty good price. Can't see MRT doing front and rear for 2.5K let alone 4K otherwise I wouldn't be bothering sourcing parts piece meal to upgrade mine (still need the rear dogbones)
1. STI wheels (other then MY02-MY04 17 7.5) *WILL NOT* fit. They 5x114.3 unless you go for a hub conversion or use a spacer with a PCD adaptor. I have 8 spare MY06 STi 17x8 wheels here ready for when a cheap 114.3 hub conversion becomes available. 4 for street and 4 for track.
The exception to the above maybe the STi wheels that shipped with Brembo equipped STi Liberty's (I think from MY06-MY07???). They had clearance for brembo's and were 5x100.
Yes they will. Either via a dog bone or using an 08+ rear calliper (this I haven't confirmed but it was mentioned by another user on another forum)
MZ21 is offline   Reply With Quote
Old 09-25-2012, 08:04 AM   #24
yomchi1989
n00b
or if you want big brakes.. just put a bigger disc on there and space the caliper out with a dogbone bracket.
Hey mate, what brand would you recommend for rotors? I want zinc-coated.
What pads would you recommend? I want the ones with the lowest dust.
Old 09-25-2012, 08:15 AM   #25
yomchi1989
n00b
Originally Posted by ModBargains.com View Post
Out of the grouping of AP Racing, Brembo, StopTech, usually StopTech is the best priced out of the three, very close to AP Racing at times. Of course most of these kits are still in R&D fazes so usually in this instance, pricing doesn't necessarily mean it has been confirmed. Regardless though, If you need more info I can look it up for you if you want to send me a PM
And yes, we ship internationally
Old 09-25-2012, 08:17 AM   #26
yomchi1989
n00b
Originally Posted by RAN94A View Post
go second hand brembos from the STI's on ebay... alternatively there's talk of WRX brakes fitting too...
whats your intended usage of them?? Pose or track?
As an FYI BBK's generally will negatively impact braking in normal road conditions dependent upon the type of pad you have in them as the hi-po brake pads dont function as well whilst the brakes are cool.. thus if you have to emergency stop after you've just gotten into the car or after you havent had to brake for quite a while (think freeway) you may find you have very little in the way of brakes.
Old 09-25-2012, 08:19 AM   #27
yomchi1989
n00b
Old 09-25-2012, 04:02 PM   #28
Bomb3r
Bomb3r's Avatar
Pads front and $500
DOT 6 fluid $50
Hi,
Thanks for your jump to conclusions and time spent...
Please call MRT to confirm, which you could have done in the time spent typing the above. Sorry, one mistake I made, it was actually $2450.
No link sorry, they take a bit of time to respond to emails too, I'm guessing they have a lot on.
When I spoke to them they had just returned from the Motor Magazine Modified challenge with their Alcon BBK upgraded car.
Just relaying the offer made to me only a few days ago when I approached them to work on my car in relation to their XA performance upgrade and Brake enhancements..
There probably isnt another workshop in the country with access to Subaru parts in the quantity that MRT has..
Edit: Ask for Quentin.
Cheers
The Following User Says Thank You to Bomb3r For This Useful Post:
Surok (09-25-2012)
bbk
