Old 09-24-2012, 08:01 PM   #15
Silverdub
Boostin'
Silverdub's Avatar
Drives: FRS-T
If i can get about 30,000 miles on the engine before a rebuild is needed, i'll be happy
Silverdub is offline   Reply With Quote
Old 09-24-2012, 08:04 PM   #16
mact
Drives: 13 GTI
The FA20 sort of reminds me of the Toyota 2JZ engine. The 2JZ was offered in both turbo and non-turbo applications. The turbo variant of course is built like a tank, but there are many "na-t" engines out there that produce respectable numbers; way more power than what it came with from the factory.
A turbo version of the FA20 is currently found in the JDM Legacy (2.0GT DIT) that produces 296hp or so. Seeing what the various shops have already done to this engine gives me a good feeling this motor is going to do just fine. But as previously mentioned, only time will tell.
mact is offline   Reply With Quote
Old 09-24-2012, 08:39 PM   #17
chulooz
Registered you sir
chulooz's Avatar
Drives: 99 impreza coupe
A turbo FB20 is currently found in the JDM Legacy (2.0GT DIT) that produces 296hp or so. Seeing what the various shops have already done to this engine gives me a good feeling this motor is going to do just fine. But as previously mentioned, only time will tell.
fixed
chulooz is offline   Reply With Quote
Old 09-24-2012, 08:42 PM   #18
subatoy
subatoy's Avatar
Drives: subatoy
100 dyno pulls with a brand new engine is not the same as 100 pulls on a car with a turbo with a 5 year old engine.
I'm sure 400whp is too much for this car but if it's doing so well with it I would say 250whp would last forever.
subatoy is offline   Reply With Quote
Old 09-24-2012, 08:48 PM   #19
mact
Drives: 13 GTI
Originally Posted by chulooz View Post
fixed
Subaru FA engine
(Japanese: Subaru FA engine) The FA was developed from the FB engine, however, efforts to reduce weight while maintaining durability were the main goals of the FA engine. While the FA and FB engine share a common platform, the FA shares very little in dedicated parts with the FB engine, with a different block, head, connecting rods, and pistons. The FA also features direct injection (from Toyota) and Subaru AVCS variable valve timing system. It is used in the Subaru BRZ, and is identified by a Toyota engine family code known as the 4U-GSE, which is installed in the Toyota 86 and the Scion FR-S.[6] According to Subaru, 0W-20 oil is recommended.
Bore: 86 mm
Stroke: 86 mm
Displacement: 1,998 cc
Compression Ratio: 12.5:1
Power: 200 PS (147 kW; 197 hp) at 7,000 RPM
Torque: 20.9 kg·m (205 N·m; 151 lb·ft) at 6,400-6,600 RPM
A version with direct fuel injection and twin-scroll turbocharger was introduced in 2012 to the Japanese market for the Legacy GT DIT (direct injection turbo) sedan, and the Legacy GT DIT Touring Wagon.
Bore: 86 mm
Stroke: 86 mm
Compression Ratio: 10.6:1
Power: 300 PS (221 kW; 296 hp) at 5,600 RPM
Torque: 40.8 kg·m (400 N·m; 295 lb·ft) at 2,000-4,800 RPM
source: wikipedia
Old 09-24-2012, 09:03 PM   #20
ahausheer
Re-member
Drives: Toyota camry
I thought this motor already has a turbo in another application. Someone should just compare the turboed motor to the BRZ/FR-S
Nothing decays like progress, and nothing preserves like neglect.
ahausheer is offline   Reply With Quote
Old 09-24-2012, 09:29 PM   #21
bimmerboy
Drives: 2009 135i
only time and experience will tell if these engines can safely hold boost.
bimmerboy is offline   Reply With Quote
Old 09-24-2012, 09:41 PM   #22
WolfsFang
Scrape Master
WolfsFang's Avatar
Drives: Goal: Oldest FRS State Side
If don's turbo brz can hold 200+ dyno runs, 1/4 runs, and DD at 450hp 15-20psi. Then i have good hopes for a normal persons FI engine to last 30k+ miles.
You do realize comparing the BRZ to the FR-S is like comparing which hand you love masterbating too right?
WolfsFang is offline   Reply With Quote
Old 09-24-2012, 09:42 PM   #23
WolfsFang
Scrape Master
WolfsFang's Avatar
Originally Posted by jmaryt View Post
man says no! period! pretty plain i would say!
chief engineer! he should know! guess that means ya put a "blower"
on it at your own peril!..kiss your warranty goodbye if it blows up!
just sayin'
why! do! you! use! so! many! exclamation! points!
Old 09-24-2012, 10:32 PM   #24
Synack
Boosted
Synack's Avatar
Drives: Sideways
Don's car would've blown up a long time ago with the way he's been pushing it.
6-10psi should get 100k+
Nismo 370Z 300whp -> FR-S Turbo 450whp on E85 -> Z06 Corvette 500whp
Synack is offline   Reply With Quote
Old 09-24-2012, 10:46 PM   #25
nix
nix's Avatar
Drives: AVO BRZ
E85 is the silver bullet on Don's and Dynostys cars though. Take that out of the equation and 10psi for 100k miles is by no means a certainty.
nix is offline   Reply With Quote
Old 09-24-2012, 11:05 PM   #26
WolfsFang
Scrape Master
WolfsFang's Avatar
he started with 93@6-8psi. Running around 350hp he made 100+ dyno runs on that psi.
The Following User Says Thank You to WolfsFang For This Useful Post:
Synack (09-25-2012)
Old 09-25-2012, 12:26 AM   #27
chulooz
Registered you sir
chulooz's Avatar
Subaru FA engine
Bore: 86 mm
Stroke: 86 mm
Bore: 86 mm
Stroke: 86 mm
source: wikipedia
You read this right? The FB is not the same as the FA, the designations are separate; the correction stands.
Old 09-25-2012, 12:40 AM   #28
mact
Drives: 13 GTI
Look on Wikipedia. The FB section is below the FA section of which I posted.
6AT (+) Forced Induction RYU Forced Induction 18 09-09-2012 11:14 PM
Forced Induction subforum? n2oinferno Site Announcements / Questions / Issues 4 09-01-2012 02:00 AM
Forced Induction Primo86 Engine, Exhaust, Transmission 11 05-29-2012 07:50 PM
Increasing torque with out forced induction BigFatFlip Engine, Exhaust, Transmission 54 05-17-2012 08:03 PM
Will you make your BRZ/FR-S Forced Induction? koyv90 Scion FR-S / Toyota 86 GT86 General Forum 12 12-04-2011 09:31 PM
