#43 | |
86 Member
Drives: 2013 Toyota 86 2.0T (Asphalt)
2760 lbs 55% is 1518 and 45% is 1242. What happens when you shift a 30+ lb battery from front to rear? 54% is 1490.4 and 46% is 1269.6 The balance is increase to 54/46 instead of 55/45. How much weight does the cable add? Like less than 5 lbs? |
| The Following User Says Thank You to SUB-FT86 For This Useful Post: | ML (09-22-2012) |
#44 | |
Drives: Scion FR-S/Toyota Yaris
No offense but calculating weight distribution is not this simple. The weight distribution change depends on how far the change is from cog which changes when you move the weight around , the constant is the wheelbase. I am sure someone has an excel spreadsheet on the web that will do it for you if you are this concerned about it. |
#45 | |
86 Member
#46 | |
Here is a spreadsheet I found in 15 seconds with google. Didn't review it. If you are interested check it out. http://www.smithees-racetech.com.au/...worksheet.html |
#47 | |
Drives: 13 BRZ - 90 Miata - 07 FXT -05 Mini
17x7 Kosei K1-TS w/ 215/45-17 Dunlop Star Specs
Nameless Track Pipe - Strano front sway bar |
| The Following User Says Thank You to Miniata For This Useful Post: | Dadhawk (09-23-2012) |
#48 | |
86 Member
Also a 5-7 lb battery doesn't sound like one you would daily drive with. |
#49 | |
As to the daily-drivability of a small lightweight AGM or lithium battery? They actually work better on daily driven cars than on cars that are parked and only driven every week or two. Not keeping the small batteries charged up is what kills them, not using them daily. I've been using smaller, lighter batteries in daily driven (and rarely driven autocross/track cars) for 10+ years, from Neons to Mustangs to my Miata.
#50 |
Lap time enthusiast
Drives: Asphalt '13 FR-S 6MT
Another thing that helps with weight distribution is the fact that the hood is aluminum, while the trunk lid isn't.
#51 | |
If you move it further out on the rear ARM (moving it towards the rear of the car and further from the COG) the same weight gets amplified and move the the COG much more effectively. As someone above mentioned, its just like a see-saw (basic lever). This is used in experimental aircraft all the time. you can offset a significant portion the weight of a 200lb engine just by putting the battery in end of the tail cone.
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
| Help Removing Rear Seats and Rear Part of Center Console | ZC6BRZ | Cosmetic Modification (Interior/Exterior/Lighting) | 2 | 08-27-2012 04:11 PM |
| curb weight | 7thgear | BRZ First-Gen (2012+) — General Topics | 8 | 07-17-2012 05:05 PM |
| Weight..... | icemang17 | Tracking / Autocross / HPDE / Drifting | 2 | 07-02-2012 07:24 PM |
| Non USDM BRZ oil weight | BMWDavid | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 3 | 06-21-2012 03:55 PM |
| Weight of FT-86? | Levi | Engine, Exhaust, Transmission | 38 | 06-14-2011 11:43 PM |
