Old 09-22-2012, 09:08 AM   #43
SUB-FT86
86 Member
Drives: 2013 Toyota 86 2.0T (Asphalt)
Originally Posted by Miniata View Post
No. Moving the stock battery to the trunk means adding even more weight with cables and a box. A better solution (unless running a big stereo) is putting a small lightweight battery in the stock location. Save 20+ lbs over the front end with few downsides. I have a 2 lb lithium battery for my Miata for autocrossing, and my normal street battery for the Miata is a 7 lb AGM battery.
The cables certainly can't be heavy enough to offset the battery. And part of the cables will lead onto the rear side of the car.
2760 lbs
55% is 1518 and 45% is 1242.
What happens when you shift a 30+ lb battery from front to rear?
54% is 1490.4 and 46% is 1269.6
The balance is increase to 54/46 instead of 55/45.
How much weight does the cable add? Like less than 5 lbs?
SUB-FT86 is offline   Reply With Quote
The Following User Says Thank You to SUB-FT86 For This Useful Post:
ML (09-22-2012)
Old 09-22-2012, 09:36 AM   #44
regal
Drives: Scion FR-S/Toyota Yaris
2760 lbs
No offense but calculating weight distribution is not this simple. The weight distribution change depends on how far the change is from cog which changes when you move the weight around , the constant is the wheelbase. I am sure someone has an excel spreadsheet on the web that will do it for you if you are this concerned about it.
regal is offline   Reply With Quote
Old 09-22-2012, 09:41 AM   #45
SUB-FT86
86 Member
What does the cog have to do with F/R balance? It doesn't make a bit of sense. A car can have a low cog and still have terrible balance F/R.
Old 09-22-2012, 10:08 AM   #46
regal
You are confusing vertical COG with horizontal COG with COG (x,y, and z) just use wikipedia.
Here is a spreadsheet I found in 15 seconds with google. Didn't review it. If you are interested check it out.
http://www.smithees-racetech.com.au/...worksheet.html
Old 09-22-2012, 11:44 AM   #47
Miniata
Drives: 13 BRZ - 90 Miata - 07 FXT -05 Mini
2760 lbs
even if the calculations were that simple (they aren't) you're still adding at least 5 lbs with appropriately sized cables and a box to move a small bit of the weight balance to the rear when you could achieve the same effective result by using a 5-7 lb battery up front and also reduce the overall weight of the car.
17x7 Kosei K1-TS w/ 215/45-17 Dunlop Star Specs
Nameless Track Pipe - Strano front sway bar
Miniata is offline   Reply With Quote
The Following User Says Thank You to Miniata For This Useful Post:
Dadhawk (09-23-2012)
Old 09-22-2012, 06:22 PM   #48
SUB-FT86
86 Member
I guess BMW is retarded for putting a battery in the back then. But then that's one of the reasons BMW cars are known for the 50/50 weight distribution.
Also a 5-7 lb battery doesn't sound like one you would daily drive with.
Old 09-22-2012, 06:46 PM   #49
Miniata
Not retarded at all. Neither is Mazda for putting the battery in the trunk of my Miata - from the factory. I have no issue when manufacturers do it, just don't see it as being necessary to move the battery to the trunk when it didn't come there from the factory, except for specific applications like when a race car is under required weight for its class and ballast is needed, and a big heavy battery in the trunk could be one way to achieve that.
As to the daily-drivability of a small lightweight AGM or lithium battery? They actually work better on daily driven cars than on cars that are parked and only driven every week or two. Not keeping the small batteries charged up is what kills them, not using them daily. I've been using smaller, lighter batteries in daily driven (and rarely driven autocross/track cars) for 10+ years, from Neons to Mustangs to my Miata.
Old 09-22-2012, 06:48 PM   #50
raul
Lap time enthusiast
raul's Avatar
Drives: Asphalt '13 FR-S 6MT
Another thing that helps with weight distribution is the fact that the hood is aluminum, while the trunk lid isn't.
raul is offline   Reply With Quote
Old 09-23-2012, 04:08 PM   #51
It can make a huge difference, easily offsetting the weight of the cables. The battery in the car now sits relatively close to the COG, which means it has minimal impact on COG, at least the horizontal component.
If you move it further out on the rear ARM (moving it towards the rear of the car and further from the COG) the same weight gets amplified and move the the COG much more effectively. As someone above mentioned, its just like a see-saw (basic lever).
This is used in experimental aircraft all the time. you can offset a significant portion the weight of a 200lb engine just by putting the battery in end of the tail cone.
Help Removing Rear Seats and Rear Part of Center Console ZC6BRZ Cosmetic Modification (Interior/Exterior/Lighting) 2 08-27-2012 04:11 PM
curb weight 7thgear BRZ First-Gen (2012+) — General Topics 8 07-17-2012 05:05 PM
Weight..... icemang17 Tracking / Autocross / HPDE / Drifting 2 07-02-2012 07:24 PM
Non USDM BRZ oil weight BMWDavid Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 3 06-21-2012 03:55 PM
Weight of FT-86? Levi Engine, Exhaust, Transmission 38 06-14-2011 11:43 PM
