Old 09-14-2012, 05:29 PM   #15
wootwoot
Drives: FRS
Originally Posted by Zardoman View Post
I like the idea only use it when I need it, keep my gas mileage and daily driving normal.
Does anyone ever really "need it?"
Should be fine if you keep it small.
Old 09-20-2012, 10:17 PM   #16
RWD-boxer
RWD-boxer's Avatar
Drives: Black
Originally Posted by slow_frs View Post
And for those of you talking bout te plastic intake manifold.... That's complete bs, I've ran 125 shot on both my tc,s before going turbo, also on my buddies ls1, so long as the nitrous is only used during WOT and above I'd say 3500 rpms, it will be good also letting off the spray between shifts
http://i172.photobucket.com/albums/w...c/100_1182.jpg
http://i85.photobucket.com/albums/k4...kemanifold.jpg
There is a lot of people that do not know what they are doing and if they see a 50 shot kit for 400$ that's all they think they need.
RWD-boxer is offline   Reply With Quote
Old 09-21-2012, 04:03 AM   #17
ModBargains
ModBargains's Avatar
Drives: FRS, M3
The stock motors should be able to handle at least 50 shot of "nozzzz" easily. However, I would recommend upgrading the internals if you plan to go any higher than that or use it more often. Sure, sometimes people get away with using 150 shot of "nozzzz" on a stock block. But every time you press that button, you better be prepared to shell out money to rebuild the block because there's always that chance.
-Frank
ModBargains is offline   Reply With Quote
Old 09-22-2012, 01:09 AM   #18
Silverdub
Boostin'
Silverdub's Avatar
Drives: FRS-T
I use to own a sohc civic '92 and go through a bottle a week for 3 months straight without any issues but it ends up being expensive... Never had any issues just do it and let us know how much fun you have!!!!!
Silverdub is offline   Reply With Quote
Would Nitrous Oxide System (NOS) work with the BRZ or FRS? MONTEMEX3 Engine, Exhaust, Transmission 94 10-21-2014 03:26 AM
HKS testing NITROUS? how did you miss this slow_frs Engine, Exhaust, Transmission 17 05-29-2012 12:37 PM
Nitrous Oxide/Meth injection JDLM Engine, Exhaust, Transmission 6 12-17-2011 04:23 AM
