Old 09-16-2012, 07:43 PM   #57
dura1198
dura1198's Avatar
Drives: 2015 WRX
Originally Posted by virtual_bob View Post
Hmmm. Maybe it's an East Coast thing but a "please" might serve you well
Awful 'sensitive'...must be a West Coast thing.
dura1198 is offline   Reply With Quote
Old 09-16-2012, 07:57 PM   #58
2forme
Since we're on the topic of transparency, why do the AFR curves look a lot more stable in your most recent post as opposed to the prior posts? Your previous dynos show some curves falling off the chart, others running really lean. On these they look rather flat, which gives the impression that the AFR's weren't really that solid on a consistent basis and/or that you're hand picking which runs to show at which time.
Could you post up ALL the runs with proper scaling on the AFR portion....please.
Old 09-16-2012, 07:58 PM   #59
Drift-Office
Drift-Office's Avatar
Drives: AE86 / FRS / FC3S / GC8 / S14 / R32
No, just an expectation of courtesy. Unless you think forums and communities like this should be devoid of all civic minded attributes - and that I that I owe my living to John Visconti, which I obviously don't.
Drift-Office is offline   Reply With Quote
The Following User Says Thank You to Drift-Office For This Useful Post:
bedabi (06-18-2013)
Old 09-16-2012, 08:00 PM   #60
Drift-Office
Sorry, I shall redo the scaling - what would you prefer to show? 8 - 16 or? Wait, I see most of my dyno charts are 10 - 18, I'll go with that.
LMK.
bedabi (06-18-2013)
Old 09-16-2012, 08:01 PM   #61
gmookher
Ok so I drove the visconti tune today right after getting out of my stock brz tune with a header back exhaust
I cant say it felt different up top, but the midrange torque is noticeable
John you have done well. gem
Old 09-16-2012, 08:10 PM   #62
Hawaiian
That guy
Hawaiian's Avatar
Drives: Ultramarine mt FR-S
LMK.
I just want to say thank you to Bob for being another asset to the community assisting with product transparency.
Ultramarine mt FR-S
P&L stage 1 turbo
Prime Motoring Flex fuel
Jr Tuned 506whp @17psi (e73)
Hawaiian is offline   Reply With Quote
The Following 2 Users Say Thank You to Hawaiian For This Useful Post:
Drift-Office (09-16-2012), Tainen (09-16-2012)
Old 09-16-2012, 08:11 PM   #63
Drift-Office
The scaling issue is just something within the Dynojet software, but here it is rescaled in the interest of* transparency and with an easier to read AFR graph (10 - 18) with cursors for reference...
I'm sure most of you don't know me but most that do know I'm really straight on this, a little bit of a nerd even. So there's no hidden agenda here.
Cheers,
bedabi (06-18-2013)
Old 09-16-2012, 08:29 PM   #64
2forme
Cheers,
Oh, I wasn't being aggressive, just a little bit of a smart ass. I am curious as to why other posts still had AFR's all over the place...
The Following User Says Thank You to 2forme For This Useful Post:
Old 09-16-2012, 08:34 PM   #65
Drift-Office
No no, you're fine. Good catch. I just have to remember to keep everything in check and consistent for reasons like this.
Old 09-16-2012, 09:30 PM   #66
tonystewart
tonystewart's Avatar
Drives: 2013 Scion FR-S Raven
So the leaning effect at 6600 rpm + is the cause for the hp & torques increase between the 2 tunes?
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
tonystewart is offline   Reply With Quote
Old 09-17-2012, 12:10 AM   #67
brichard0625
brichard0625's Avatar
Drives: 2013 Scion Frs(Scarlet)
Also a good observation, but I think you missed the part where FT86SpeedFactory posted the dyno charts in STD correction vs SAE, and that alone would yield you a few more WHP in favor of the STD numbers, especially in the warmer climates.
I would have done the same here but I didn't want to be accused of "inflating values" nor did I want to start a thread about correction factors and have everyone get confused. We should stick to the defacto standard, SAE values.
My 2 cents once again...
I Didnt think about that(not to savy when it comes to dynos but 95% of time i do i see sae corrected values) but i thought regardless standard vs sae the base run was done stardard too so wouldnt the gains be around the same corrected or not...i think someone else did a run with just a filter and saw 3hp and 2tq sae corrected. Either way the intakes that are out dont seem to appealing if a $38 filter(thats what i paid for my hks) is making 2-3hp/1-2tq and a $300 intake is making just 4-6hp/3-4tq(and in airaids case needs a tune to show postive according to op's dyno)...only reason why avo seems appealing to me right now is because its only $149 for inlet pipe and i already have a highflow filter and it actually has a nice positive gain...still waiting for a coldair tho
brichard0625 is offline   Reply With Quote
Old 09-17-2012, 12:31 AM   #68
Visconti
Drives: 05 STi
Drop in HP like that is caused from knock.
Knock Control is turned always turn on with my calibrations
Visconti is offline   Reply With Quote
Old 09-17-2012, 02:54 AM   #69
xAgentzero13
Drives: genesis coupe
with these tunes we gotta see some 0 to 60 times!
xAgentzero13 is offline   Reply With Quote
Old 09-17-2012, 03:09 AM   #70
gmookher
cant you tune that out with higher octane? would love to see a medley of maps
In Annapolis for the weekend - Get your Visconti Tune! Visconti Mid-Atlantic 6 09-16-2012 10:10 AM
CEL with Visconti tune tjdiz92 Issues | Warranty | Recalls / TSB 44 09-16-2012 04:04 AM
A Question for Those of You WITH the Visconti Tune White64Goat Engine, Exhaust, Transmission 22 09-02-2012 05:27 PM
FA20CLUB.com Stage 1 ECUTEK Reflash Results FA20Club.com Engine, Exhaust, Transmission 20 08-25-2012 07:02 PM
1st Auto with Visconti E85 tune! white devil Engine, Exhaust, Transmission 35 08-22-2012 04:22 PM
