Old 09-14-2012, 05:49 PM   #1
White64Goat
Is There A Better Antenna?
I have discovered that the stock antenna is kinda pathetic. Had the FM radio on today on an HD channel and the 'HD' signal kept going on and off and there is a BIG sound difference when it is off. Does anyone make an antenna that gets better reception? Does it need to be a little longer for FM reception?
Old 09-15-2012, 11:28 AM   #2
rmjjensen
rmjjensen's Avatar
Drives: 2013 Subaru BRZ Limited in WRB
I have this problem as well - it's the most annoying thing in the world and I wind up just listening to the XM. The loudness varies way to much to even listen to, and, I doubt "Non-HD" sounds as crappy as it does when "HD" is off. My regular FM radio doesn't sound like an 8 TRACK so why the BRZ?
rmjjensen is offline   Reply With Quote
Old 09-15-2012, 09:49 PM   #3
dnr
dnr's Avatar
Drives: fr-s
i thought something wrong with mine
they sucks..especially in highway..couldnt listen to proper music
dnr is offline   Reply With Quote
Old 09-16-2012, 06:05 AM   #4
Tylub
Tylub's Avatar
Drives: Raven Black FR-S
same with mine, it is normally picking up static a lot. even in open areas with no obstructions. wouldn't mine upping the RC look for better reception. i NEED my radio haha... then again the engine note is always good music to my ears
Tylub is offline   Reply With Quote
Old 09-16-2012, 11:09 PM   #5
KGFRS86
SoCal Asphalt FR-S Owner
KGFRS86's Avatar
Drives: 13' Asphalt FR-S
Do you all have the Shark Fin antenna? I do and I don't have any issues with the radio signal.
KGFRS86 is offline   Reply With Quote
The Following User Says Thank You to KGFRS86 For This Useful Post:
Michael (09-11-2014)
Old 09-16-2012, 11:16 PM   #6
Nitro
Nitro's Avatar
Drives: 2013 Firestorm Scion FR-S
I also noticed poor reception. The station I used to listen to every morning on my last car barely comes in in the FRS.
Nitro is offline   Reply With Quote
Old 09-16-2012, 11:46 PM   #7
DGMBRZ
DGMBRZ's Avatar
Drives: 2013 Subaru BRZ in DGM
Shark Fin antenna is working great for me!
DGMBRZ is offline   Reply With Quote
Old 09-17-2012, 12:11 AM   #8
ahausheer
Re-member
Drives: Toyota camry
Had this issue in my Solara. Turns out the wires to the antenna (hot/ground) were reversed from the factory which negatively affected reception. There was eventually a TSB. Just putting this out there.
Nothing decays like progress, and nothing preserves like neglect.
ahausheer is offline   Reply With Quote
Old 09-20-2012, 02:02 PM   #9
Slartibartfast
Klaatu barada nikto
Slartibartfast's Avatar
Drives: Raven FR-S MT
I've searched the forum and Google and all I find it dress-up antennas.
I have been trying to find something that is a replacement, not a cover-up.
I currently have a Beat-Sonic, but I need Sirius/XM, AM/FM, and GPS. So, I'm sending out info requests to antenna suppliers.
If anyone has more expertise in this area, please PM me back.
So far, I've only found this company, http://g-antetech.en.alibaba.com/
There's got to be more out there.
Where's a Radioshack geek when you need 'em.
I vow to do no harm.
2013 Raven FR-S Manual "Lenore"
1985 Silver RX-7 GSL-SE (Gone and missed)
Slartibartfast is offline   Reply With Quote
Old 09-20-2012, 02:08 PM   #10
zoomzoomers
zoomzoomers's Avatar
I too find this annoying. For this reason I've kept the stock antenna for now. When and if I find something that looks good and increases performance, then I'll jump. For now, I only listen to XM/Sirius.
Old 09-20-2012, 06:26 PM   #11
Chillz
Drives: Asphalt FR-S & S14
I listen to a local AM news station on the way to and from work and HD cuts in and out about 5 times each way. I'd love to find a solution to this as well.
Chillz is offline   Reply With Quote
Old 09-22-2012, 12:16 PM   #12
White64Goat
Does the shark fin work for AM/FM/XM and the nav system? Seems hard to believe that something shorter would work better for AM/FM.....
The Following User Says Thank You to White64Goat For This Useful Post:
tbrocato (09-22-2012)
Old 09-23-2012, 03:43 PM   #13
DGMBRZ
DGMBRZ's Avatar
It does work with the GPS, hd radio, fm/am, and Sirius xm. No problem with reception so far.
Old 03-09-2013, 03:36 PM   #14
White64Goat
Had a few old stainless steel antennas in a pile on the shelf in my garage (forgot they were there) and lo-and-behold I found one that has the same threads as the factory one. Need to shorthen the threads down about 1/2 inch to make it fit right and then test it out to see if it improves the FM reception.
20$ Shark Fin Antenna srt4_night_rider Cosmetic Modification (Interior/Exterior/Lighting) 13 05-08-2013 01:13 AM
Shark Fin Antenna geb2391 BRZ First-Gen (2012+) — General Topics 15 09-09-2012 09:05 PM
LT Short Antenna now available for the 86/FR-S/BRZ/GT-86 lordtakuban Exterior Parts - The Rest 1 07-25-2012 07:22 AM
Got my Beats Antenna before my car ;( haloterence Cosmetic Modification (Interior/Exterior/Lighting) 3 06-13-2012 08:55 PM
Does anyone else not like where they put the antenna? MrFRsLa Cosmetic Modification (Interior/Exterior/Lighting) 41 06-04-2012 07:27 AM
