Old 08-16-2012, 11:18 AM   #43
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
Originally Posted by F1point4 View Post
Haha. I don't have my own garage so I have to carry my gear to one of my work sites. Need to keep it minimum. In the end, jacks and stands allow me to do more than ramps do, that's all.
Ahh, makes sense.
Old 08-24-2012, 06:23 PM   #44
Phaedrus29
Phaedrus29's Avatar
Drives: 2013 Subaru BRZ
Several things I could do to correct the situation
- get a floor jack that could lift higher
- get stands that are smaller (I have tall stands)
- find a thicker block of wood to place between the jack and frame (could be unsafe)
I think I'd try a thicker block of wood next time.
As for sliding the jack under the center jack points, mine doesn't fit either in its resting position. I had to pump and hold the handle all the way down for the jack to clear the front lip. Even in this position I probably had like 1/2" to 1" of space between the jack and the front lip. This is probably why I wont buy a larger floor jack.
If my car was lowered I'm afraid I'd have to buy one of those long flat jacks to lift it.
F1point4
I ended up getting this jack from Harbor Freight: http://www.harborfreight.com/2-ton-l...ump-68051.html
Because the front jack point is back a bit, the raised part of the jack gets much too close to the front bumper for my liking. Especially if the car is lowered, I can't imagine this jack will work. Maybe this one would have been a better option???:
http://www.harborfreight.com/2-ton-l...ump-68050.html
Phaedrus29 is offline   Reply With Quote
Old 08-24-2012, 06:28 PM   #45
F1point4
Photo Specialist
F1point4's Avatar
Drives: 2013 Toyota 86 DGM 6MT
Got the JDM Side Markers on. Did a DIY writeup here
http://www.ft86club.com/forums/showthread.php?t=15560
It looks so much better now that all the lights match
20120824-LolaClearSideMarker-01 by VictorN07, on Flickr
20120824-LolaClearSideMarker-33 by VictorN07, on Flickr
20120824-LolaClearSideMarker-31 by VictorN07, on Flickr
F1point4 is offline   Reply With Quote
Old 08-24-2012, 06:34 PM   #46
F1point4
Photo Specialist
F1point4's Avatar
Agreed, The lip hits the handle on mine so I have to insert the jack with the handle pushed all the way down. When this one breaks, I'll get the super flat jack you listed.
Old 08-24-2012, 09:16 PM   #47
Phaedrus29
Phaedrus29's Avatar
It's not so much the handle for me but rather this part:
UPDATE: I exchanged that jack for this one (http://www.harborfreight.com/2-ton-l...ump-68050.html), and I can report that this one works perfectly with no fitment issues. The Harbor Freight 3ton jack stands also do a nice job of supporting the car on both sides of the pinch welds...they clear the whole pinch weld.
Old 08-30-2012, 09:06 PM   #48
F1point4
Photo Specialist
F1point4's Avatar
JDM Mirror installed.
DIY here http://www.ft86club.com/forums/showthread.php?t=16123
20120830-LolaJDMMirror-00 by VictorN07, on Flickr
20120830-LolaJDMMirror-18 by VictorN07, on Flickr
Old 09-03-2012, 01:38 AM   #49
F1point4
Photo Specialist
F1point4's Avatar
Back for more. http://www.ft86club.com/forums/showthread.php?t=16300
20120831-LolaBlackVue400DIY-01 by VictorN07, on Flickr
On a side note I am currently averaging 29 MPG with 2500 miles on the clock. I am sadface because no matter how careful I am there is swirl marks in my paint. However I suspect that the body shop I used put some on while attempting to clean my car for repair. Guess I will take this as an opportunity to learn paint correction.
Old 09-15-2012, 05:49 PM   #50
F1point4
Photo Specialist
F1point4's Avatar
Did some more interior changes recently. Here is a custom engraved Flossy Shift Knob. Swapped it to save the stock knob from getting marred from use.
It weighs considerably more than the OEM shift knob and makes shifts a little smoother. I believe MTF swap is needed for ultimate smoothness. Install was painful. It took me 20 minutes to screw it on so the picture was aligned correctly.
You already know I like to take photos, artsy photos. Stock knob
20120831-FlossyShiftKnob-3 by VictorN07, on Flickr
Comparison
20120831-FlossyShiftKnob-4 by VictorN07, on Flickr
Final product
20120831-FlossyShiftKnob-5 by VictorN07, on Flickr
Old 09-15-2012, 05:58 PM   #51
F1point4
Photo Specialist
F1point4's Avatar
My legs don't bend the way necessary for heel toe. Decided to swap out for the Sullivan Racing Products Racing Pedals. The quality is quite good and it brings the gas pedal closer to the brake. SRP makes a gas pedal only option that matches OEM fairly close, but I opted for the entire set.
Must slow down with the mods. Staying true to the hellafunctional motto.
Whole set. Milled out of aluminium.
20120914-SRP Racing Pedals-1 by VictorN07, on Flickr
Grid pattern. Not anodized. The brake, clutch, and dead pedal have this texture.
20120914-SRP Racing Pedals-6 by VictorN07, on Flickr
The gas pedal is smooth so your foot can slide
20120914-SRP Racing Pedals-7 by VictorN07, on Flickr
Add the pedals have this finish on the back
20120914-SRP Racing Pedals-4 by VictorN07, on Flickr
Installed!
20120915-SRP Racing Pedals-9 by VictorN07, on Flickr
20120915-SRP Racing Pedals-11 by VictorN07, on Flickr
Old 09-15-2012, 06:29 PM   #52
F1point4
Photo Specialist
F1point4's Avatar
Here are some observations from the racing pedal install.
My car was undriveable for a while
20120915-SRP Racing Pedals-12 by VictorN07, on Flickr
Held on tight
20120915-SRP Racing Pedals-13 by VictorN07, on Flickr
Covered removed and my chosen drill points
20120915-SRP Racing Pedals-14 by VictorN07, on Flickr
Comparison between stock gas pedal and new gas pedal
20120915-SRP Racing Pedals-15 by VictorN07, on Flickr
It's not a perfect fit. I'm okay with it though
20120915-SRP Racing Pedals-16 by VictorN07, on Flickr
Dead Pedal was a bitch. I ended up cutting a hole in the carpet.
20120915-SRP Racing Pedals-17 by VictorN07, on Flickr
Shows how much carpet I took out.
20120915-SRP Racing Pedals-19 by VictorN07, on Flickr
Clips
20120915-SRP Racing Pedals-18 by VictorN07, on Flickr
There was foam behind the pedal. I took that out.
20120915-SRP Racing Pedals-20 by VictorN07, on Flickr
Full fit.
20120915-SRP Racing Pedals-21 by VictorN07, on Flickr
Instead of leaving the foam there, I decided to remove it. The mounting surface for the dead pedal is not rubber, but metal. It was also not black so I ended up using black racing tape so it grey wouldn't show through the pedal.
The kit included 8 self tapping screws and 6 bolts with locking nuts. The gas pedal was plastic so the self tapping screws were perfect for that. I used 4. The brake and clutch pedals were steel so I ended up using the nuts and bolts for those. Used 3 each.
I knew ahead of time I wouldn't be able to use the nuts and bolts for the dead pedal since I can't reach behind. When I found out the mounting surface was metal I knew the self tapping screws provided aren't appropriate but I made them work. The instructions said to drill a 1/16" hole for the dead pedal but the screws wouldn't work unless until I bored out a 7/64" hole. The self tapping screws are also fairly short. Think 1/2". If I used the foam the screws would not reach the metal.
Not aiming to bash SRP. It is a good product. Just wanted to raise awareness.
Old 09-15-2012, 06:30 PM   #53
post_break
Professional Smartass
post_break's Avatar
Drives: White Out FRS
What's the cost on those pedals? In my opinion the brake pedal is about an inch too far right, and the gas as well. Way too close to the wall your leg rests up against.
post_break is offline   Reply With Quote
Old 09-15-2012, 06:36 PM   #54
F1point4
Photo Specialist
F1point4's Avatar
116 with the coupon code "ft86club". They have a black anodized option. I with you on alignment of the stock pedals. The picture shows that plastic piece next to the gas pedal all scuffed up.
I do like that my shoes definitely grip to the brake and clutch with the new pedals' grid pattern.
Old 09-23-2012, 01:01 AM   #55
F1point4
Photo Specialist
F1point4's Avatar
http://www.ft86club.com/forums/showp...9&postcount=68
I like technical data. I like photography. Here is a thread about both. Enjoy
Goals:
Stay Functional
Max Grip
Lower weight than OEM combo.
Went with:
WedsSport TC105N 17x9 +35 square setup (Thanks @RavSpec)
Hubcentric Rings 65mm to 56mm
Dunlop Direzza Sport Z1 Star Spec 245/40R17 (Thanks Discount Tire)
Stock TPMS sensors
Stock Suspension
Factory Geometry settings
The 17x9 +35 in a 5x100 setup is a limited run for the 86. Thus official weight is unlisted on the Weds website. Here is what my human scale told me.
20120921-TC105N_Z1StarSpec-17 by VictorN07, on Flickr
Sports Utility Vehicle. I don't have a picture of when I had the OEM wheels in my car, but they fit dammit
20120921-TC105N_Z1StarSpec-2 by VictorN07, on Flickr
The setup. Discount Tire was cool about letting me be in the garage and learning about what they do. I was super happy to be there cause they almost put on my wheels with impact tools. Nope!
20120921-TC105N_Z1StarSpec-16 by VictorN07, on Flickr
Discount Tire told me they'd dismount the OEM tire and pull the TPMS sensor to transfer to the new setup as part of the deal. Here is a picture of the sensor. It is attached to the valve stem.
20120921-TC105N_Z1StarSpec-14 by VictorN07, on Flickr
20120921-TC105N_Z1StarSpec-15 by VictorN07, on Flickr
I don't know how calibrated my scale was. What was important to me was the difference in weight. Stock wheels are 40.6 lbs. TC105N with Star Specs were 42.4. Damn.... Anyway it is pretty good for what I'm putting on.
20120921-TC105N_Z1StarSpec-18 by VictorN07, on Flickr
20120921-TC105N_Z1StarSpec-19 by VictorN07, on Flickr
Thoughts so far
I drove 200 miles so far on this setup. Haven't taken it to a track yet. It definitely gives me more confidence in what I'm doing. Just grip for miles. Since the wheels now weigh more, I can definitely feel the sluggishness at start. Brakes fine. I figure a headerback exhaust may balance out the unsprung weight gain. The Star Specs do have a different audible characteristic. I find the OEM Michelins to grumble and have a deeper tone. These Star Specs definitely howl, but it's not annoying. I could probably fix some of that with sound deadener. For rubbing, I believe that other people threw on 17x9 +42s and they fit fine so the +35 offset should be good. I haven't felt anything bad in my driving so far.
In terms of looks, the rear looks great. The front sticks out a little bit as the pictures below show. However, stance. I got plenty of that now. Now for photos; please enjoy them as much as I did taking them.
20120922-TC105N_Z1StarSpec-16-Edit by VictorN07, on Flickr
20120922-TC105N_Z1StarSpec-1 by VictorN07, on Flickr
20120922-TC105N_Z1StarSpec-22-Edit by VictorN07, on Flickr
Front
20120922-TC105N_Z1StarSpec-30 by VictorN07, on Flickr
Rear
20120922-TC105N_Z1StarSpec-25 by VictorN07, on Flickr
20120922-TC105N_Z1StarSpec-28 by VictorN07, on Flickr
20120922-TC105N_Z1StarSpec-33-Edit by VictorN07, on Flickr
20120922-TC105N_Z1StarSpec-32-Edit by VictorN07, on Flickr
20120922-TC105N_Z1StarSpec-37-Edit by VictorN07, on Flickr
20120922-TC105N_Z1StarSpec-41 by VictorN07, on Flickr
Questions I have
If anyone would like to help me answer these quick questions, I'd appreciate it greatly
* Since my wheels stick out, I have to add negative camber if I lower it?
* What is the daily driving PSI for this setup? Discount Tire said 35psi, but I have no experience with aftermarket wheels.
* Will a headerback gain balance out the unsprung weight gain? I was just guessing up there.
Last edited by F1point4; 09-25-2012 at 07:36 AM. Reason: Darren moved the thread so updating link
Old 09-23-2012, 02:59 PM   #56
F1point4
Photo Specialist
F1point4's Avatar
Rally Armor Mud Flaps Review
Ordered direct from Rally Armor. They shipped USPS Priority from NY. Wasn't expecting it, but it came in two days. And on it went this morning.
I didn't get pictures of the flaps themselves. They are approximately 1/8" thick, made of urethane, have a shiny finish. They install into the factory clip locations so there isn't any drilling required. Remove the stock clips, install the bracket and plastic tabs for the screws and then screw the flap into place. The are "adjustable width" so they can slide in and out depending on preference. If you do not want to see the Rally Armor logo, you can turn the flaps over and switch sides.
Definitely have the right tools or be able to remove the wheels. I opted to not remove the wheels so I turned the screws using vice grips.
Other than the fact that the screws are silver, the flaps compliment the extra width from the 17x9 245 wheels. Some may say ugly, I think they look great and are hellafunctional. For pure aesthetics, I probably would not have gone with it if I didn't go with wide wheels. I think the color goes well with Asphalt/DGM too.
I brought my Nikon sans memory card so iPhone has to do. Now on to the pictures
Side shot:
21020923-RallyArmorMudGaurd-01 by VictorN07, on Flickr
Front 3/4:
21020923-RallyArmorMudGaurd-08 by VictorN07, on Flickr
Rear 3/4
21020923-RallyArmorMudGaurd-07 by VictorN07, on Flickr
21020923-RallyArmorMudGaurd-02 by VictorN07, on Flickr
Rear Stance
21020923-RallyArmorMudGaurd-04 by VictorN07, on Flickr
Rear ISO View. This is the flap pulled all the way out. Lines up with the wheel very well. I can slide it in about 1/2".
21020923-RallyArmorMudGaurd-03 by VictorN07, on Flickr
Front ISO View. I had the flap all the way in in the front. As you can sort of see, it's not flush with the wheel, but I think all the way out would look off.
21020923-RallyArmorMudGaurd-06 by VictorN07, on Flickr
Front installation. Held on with screws and washers. Wish the screws were black. Four in the front. Note the shinyness.
21020923-RallyArmorMudGaurd-09 by VictorN07, on Flickr
Rear Installation. Three in the back. It doesn't come all the way up to the wheel well liner, but you cannot see the gap from the rear, even if you bend down.
21020923-RallyArmorMudGaurd-10 by VictorN07, on Flickr
Asphalt Scion FR-S aznsensazian FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 21 03-17-2014 02:13 PM
Asphalt FR-S pics Rob_g CANADA 24 09-03-2012 06:01 AM
Asphalt in the snow Double4Free Scion FR-S / Toyota 86 GT86 General Forum 5 06-10-2012 02:56 PM
Asphalt 6MT FR-S Symbiont Southern California 22 06-06-2012 08:47 AM
ant08 Asphalt MT ant08 Member's Car Journals 3 06-04-2012 05:16 PM
