AVOturboworld
Old 09-13-2012, 03:21 PM   #435
gmookher
Originally Posted by cnk View Post
I'm sure you could jack up the engine from the bottom. That's how I did my STi motor mounts on my WRX. Just a couple blocks of wood and a jack. Or even better, someone will figure out an easier way to do it when folks start to change out plugs. I'm always up for buying new tools. lol
just like this
Old 09-13-2012, 03:34 PM   #436
Ironsquid
King of Kiwi Palace
Ironsquid's Avatar
Drives: Faster than you
Originally Posted by gmookher View Post
just like this
Would recommend
Ironsquid is offline   Reply With Quote
The Following User Says Thank You to Ironsquid For This Useful Post:
gmookher (09-13-2012)
Old 09-13-2012, 03:57 PM   #437
Apex Chase
El Presidente
Apex Chase's Avatar
Drives: it like I stole it!
This is the thread about the AVO turbo system, right? Because I read the title but when I got in here it was all wheels and spark plugs.
Apex Chase is offline   Reply With Quote
The Following User Says Thank You to Apex Chase For This Useful Post:
Spartan65 (09-13-2012)
Old 09-13-2012, 04:04 PM   #438
cnk
Drives: '13 DGM BRZ Limited
Not sure about the wheels, but the part about jacking up the engine for spark plugs is also relevant for a turbo installation if you are going to replace the front pipe as well due to the need to jack up the engine in order for the flange to have enough clearance to be removed.
Old 09-13-2012, 04:12 PM   #439
Ravenlokk
Ravenlokk's Avatar
Drives: 2013 Raven FR-S
Factory Exhaust/Overpipe?
Hey,
I read through the thread- but don't remember if it was asked, or stated:
Will this kit work with the factory exhaust and/or overpipe placement?
I ask because i was initially planing on replacing the exhaust, and frontpipe. I was contemplating if i'd get a frontpipe/overpipe replacement but wanted to make sure whatever i replace will be compatible with this kit down the road.
Basicly if the exhaust port on the turbo is in the same place that the stock manifold bolted to the overpipe then that's gold. It looked like the stock overpipe was retained in the OP picture... but i just wanted to be sure before shelling out cash for a piece and having to replace it later on.
Thanks again, and im super excited for this kit . But i'll probably have to wait a year before the wife lets me spend this kind of money on the FRS...
Ravenlokk is offline   Reply With Quote
Old 09-13-2012, 04:22 PM   #440
gmookher
I'm guilty as charged of thread jacking. /end jack
The Following User Says Thank You to gmookher For This Useful Post:
ngabdala (09-15-2012)
Old 09-13-2012, 11:20 PM   #441
RAYSSPL
Drives: bicycle
is there an option for equal length headers?
RAYSSPL is offline   Reply With Quote
The Following 2 Users Say Thank You to RAYSSPL For This Useful Post:
ngabdala (09-15-2012), stevo_12v (10-15-2012)
Old 09-14-2012, 07:41 PM   #442
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
Not trying to continue the thread jack, but thats not true. If you remove the heat shield on the over pipe (assuming thats what you meant), you can get the over pipe out without raising the engine.
But if you did mean the front pipe, theres absolutely no reason to raise the engine as that pipe is behind the steering rack and runs along the transmission.
Parting out HERE
civicdrivr is offline   Reply With Quote
Old 09-14-2012, 07:53 PM   #443
gmookher
the replacement over pipe is a greater diameter than the original so liftin the engine is necessary
Old 09-14-2012, 08:24 PM   #444
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
I installed a larger over pipe. It took some wrangling, but there is no need to lift the engine.
Parting out HERE
Old 09-14-2012, 08:42 PM   #445
mike2100
mike2100's Avatar
Drives: 23 BRZ
I think it depends on whose overpipe you buy. gmookher has the one from Perrin, which follows the bends of the stock overpipe. If you have an overpipe with the same bends as stock and is bigger diameter, it's basically the same size as the stock one with heat shields in place (on the outside anyway).
SRT straightened their overpipe out a bit to improve flow, so it's easier to maneuver. I found the SRT extremely easy to install, no engine jacking required. The downside, as we've seen is that as currently designed it doesn't clear auto transmissions. Some slight tweaking should cure that, without losing much, if any of the straightening.
I think Nameless were actually the first to straighten out the overpipe, and they made it considerably straighter.
mike2100 is offline   Reply With Quote
The Following User Says Thank You to mike2100 For This Useful Post:
civicdrivr (09-15-2012)
Old 09-14-2012, 09:24 PM   #446
subatoy
subatoy's Avatar
Drives: subatoy
Theres plenty of other turbo kits with that.This kit is for the people that want a good sounding boxer engine.
subatoy is offline   Reply With Quote
The Following 3 Users Say Thank You to subatoy For This Useful Post:
bimmerboy (09-15-2012), rupert (09-14-2012), Sportsguy83 (09-15-2012)
Old 09-14-2012, 09:47 PM   #447
AVOturboworld
The Following 4 Users Say Thank You to AVOturboworld For This Useful Post:
civicdrivr (09-15-2012), Lawnik (09-14-2012), ngabdala (09-15-2012), Sportsguy83 (09-15-2012)
Old 09-14-2012, 09:47 PM   #448
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
Lol they all sound good to me.
accelerated performance, avo turbo kit, avo turboworld, avoturboworld turbo kit, brz forum, brz forums, brz turbo, brz turbo kit, fr-s turbo, fr-s turbo kit, frs turbo, frs turbo kit, scion fr-s turbo, scion fr-s turbo kit, scion fr-s turbocharger, scion frs fi, scion frs turbo, scion frs turbo kit, scion frs turbocharger, subaru brz fi, subaru brz forum, subaru brz forums, subaru brz turbo, subaru brz turbo kit, subaru brz turbocharger
PC Build Thread WingsofWar Off-Topic Lounge [WARNING: NO POLITICS] 126 01-22-2017 09:59 PM
FT-86 SpeedFactory - Firestorm Red - Build Thread FT-86 SpeedFactory Member's Car Journals 38 02-26-2015 02:42 PM
JoeBoxer FR-S build thread JoeBoxer Member's Car Journals 112 04-08-2013 01:19 AM
Compression ratio 12.5:1. Bye-bye Super charger & Turbo build? fred_boosted Engine, Exhaust, Transmission 215 12-12-2011 07:23 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 10:13 AM
