Old 08-27-2012, 12:16 AM   #43
ABQautoxer
ABQautoxer's Avatar
Drives: 2021 Supra / 2022 Tundra
This is from last weekend. Car was bone stock other than front crash bolts. I'm at 5500ft above sea level so if the car seems even slower than normal, thats why:
[ame="http://www.youtube.com/watch?v=qSKigm746uQ"]8-19-2012 RGRSCCA BRZ fun run - YouTube[/ame]
Overall my impression is that steady state really isn't bad but transitions seem to put this thing on its bumpstops immediately. Couple that with its ability to really transfer weight quickly and you can really pitch this thing into a drift without trying. Add to that the stock tires are just beyond the worst tire I can ever remember autocrossing on. Even 3000rpm launches at my altitude spin the tires a ways and a mild shift mid turn really upsets the car though I was sloppier than usual after driving the WRX all day. I still hate the brake pads. I ordered some Stoptech street performance pads and a Nameless Performance muffler delete from Stranoparts.com and should have fresh Star Specs before the next time I run it. Also I learned I need to lower the video camera a bit so the outside isn't so washed out. Dataacq was done with an AIM Solo and Dashware since I get asked this a lot.
TomR
ABQautoxer is offline   Reply With Quote
Old 09-02-2012, 04:13 AM   #44
Filipino Royale
Got Rice?
Filipino Royale's Avatar
Drives: 37J BRZ-L
Crash bolts, that does void any warranty right? Can the dealers can install them. Thanks!
Be a Leader, Be a Friend, Be at Service. -AɸΩ
Filipino Royale is offline   Reply With Quote
Old 09-02-2012, 10:16 AM   #45
xwd
It's in the factory repair manual so it shouldnt void any warranty on the car. The dealer would probably install them if they do alignments.
Old 09-13-2012, 12:40 AM   #46
simpleisbest
Senior Citizen
Drives: Scion FR-S
I know that a oil catch can is allowed under the rules for Stock class, but what about an oil/air separator (as in Crawford Performance's unit)
http://store.crawfordperformance.com/store/products/652
Pricey vs some OCC options out there, but is it class legal?
simpleisbest is offline   Reply With Quote
Old 09-13-2012, 09:29 AM   #47
celica73
Why use one at all? I really don't think these cars have a major oil blow by problem.
If the rules don't say that you can, then you can NOT.
Old 09-13-2012, 09:32 AM   #48
Spartan65
USMC Veteran Semper Fi
Spartan65's Avatar
Drives: 2010 WR Blue STi
Originally Posted by ABQautoxer View Post
Local dealer sold me mine for $6ea plus tax.
Was that Garcia?
Spartan65 is offline   Reply With Quote
Old 09-13-2012, 09:46 AM   #49
ABQautoxer
ABQautoxer's Avatar
Originally Posted by Spartan65 View Post
Was that Garcia?
Yes
Catch cans are legal in stock class, read the rule book.
TomR
Old 09-13-2012, 11:40 AM   #50
xwd
Crawford posted some pictures of a torn down engine with like 5K miles on it (not a failure, they tore it down for development) and the pistons showed a lot of black deposits on them which they attributed to PCV crap in the combustion chamber. AVO also maybe had some evidence of oil condensed in the throttle body when they removed the stock intake tube and put their silicone hose on.
http://store.crawfordperformance.com...ploads/800.jpg
So now everyone is racing out to buy catch cans. There are a few guys who have installed catch cans and have seen no oil in them even after track days, so it's not blowing oil like a turbo Subaru but PCVs do put crap back into the intake. The Crawford is an air/oil separator so it will condense the crap in the vapors as well.
The rule is:
"The installation of oil catch tanks is allowed provided the function of the PCV system is not altered." So as long as you are just plumbing things inline, then it's legal. You can't dump the outlet under the car. AOS would be legal as well, it does function as a catch tank, it just happens to drain back into the engine. Rule doesn't say anything about drains...
The Following 3 Users Say Thank You to xwd For This Useful Post:
PoorMansRacing (01-27-2014), Scooby South (09-23-2012), whataboutbob (09-13-2012)
Old 09-13-2012, 11:50 AM   #51
ABQautoxer
ABQautoxer's Avatar
For those who didn't know:
13.10 ENGINE AND DRIVE TRAIN
G. The installation of water expansion tanks is allowed. The installation
is not altered.
TomR
The Following 2 Users Say Thank You to ABQautoxer For This Useful Post:
Old 09-13-2012, 11:56 AM   #52
xwd
It appears the BRZ version of the Crawford AOS keeps the PCV valve, I'm pretty sure the WRX/STi one blocks it off.
Old 09-13-2012, 02:23 PM   #53
simpleisbest
Senior Citizen
Drives: Scion FR-S
Thanks guys! So it appears legal, since its a closed system and allows for the PCV system to function (Smog legal too, according to Crawford).
Old 09-13-2012, 10:57 PM   #54
Fonzie517
Autocrosser
Drives: Asphalt 6-speed FR-S
Could a wheel with a 40mm offset be machined to 42mm, allowing it to be run in stock categories?
Fonzie517 is offline   Reply With Quote
Old 09-13-2012, 10:58 PM   #55
ABQautoxer
ABQautoxer's Avatar
Yes this has been done. However be careful, not all wheels can have this done without seriously compromising it's construction beyond safe limits.
TomR
Old 09-13-2012, 11:11 PM   #56
Fonzie517
Autocrosser
I would imagine that machining 2mm from the hub area could lead to either too thin of a mounting surface or a wobbly wheel. Is there anything else I should consider before buying a set of wheels and having them machined?
2012 BRZ/FR-S Stock Class Autocross Discussion EMguy Tracking / Autocross / HPDE / Drifting 183 01-04-2013 03:17 AM
What SCCA autocross class will the FRS be most competitive SVThis Tracking / Autocross / HPDE / Drifting 5 07-30-2012 04:29 PM
Share/discuss (this mornin) 86 Newsletter... RebootWindows AUSTRALIA 6 07-19-2012 04:15 PM
SCCA Solo Car Class for the FR-S/BRZ? MrVito Scion FR-S / Toyota 86 GT86 General Forum 31 06-15-2012 10:03 AM
Discuss.... carbonBLUE Off-Topic Lounge [WARNING: NO POLITICS] 12 02-11-2012 12:55 PM
