| FR-S / BRZ vs.... Area to discuss the FR-S/BRZ against its competitors [NO STREET RACING] |
#1317 | |
Drives: Firestorm FR-S (MT)
#1318 |
86 Member
Drives: 2013 Toyota 86 2.0T (Asphalt)
I have never seen a review that came up with that conclusion. The weight difference between the two is 600 lbs and the size difference is about 21 inches. I think the Z might be closer to a V6 FRS/BRZ in that it's faster but because it has a heavier engine it doesn't have the finesse as the 4 cylinder.
#1319 |
Drives: Toyota Auris
Shagaliscious: He keeps talking about how the tires MUST (as in RFC 2119) not be changed, because people SHALL NOT be allowed to ask e.g. "factoring out the tires, how good is this car?".
#1320 |
Drives: S2000
I love the BRZ/FRS and all, but you can't compare to 370Z. BRZ is an entry level sports car where the 370Z is sitting on a level higher.
#1321 | ||
Low CG + light weight + wide track width + good tires = very impressive lateral grip. Quote:
The great thing is, if you want to hoon around and have fun on the street, the stock tires work great. But if you want to get serious on the track, all you have to do is throw on a good set of summer tires (and upgraded pads/fluid) and you've got a car that will devour corners with the best of them. The FR-S is very versatile in that way. |
#1322 | |
it isnt. the problem is that by doing the exact same thing as others, im somehow wrong. my only point was that changing something on a car means the car has changed and changing things for a comparison is a slippery slope |
#1323 |
My point is that you're trolling, but you're the one proving it. Because it's impossible not to understand such a simple thing.
DarkSunrise, that's precisely why I like this car: it has a "real" chassis, instead of trying to solve everything through stiffness and electronics. |
#1324 | ||
#1325 |
Glorious BRZ Master Race
Drives: Subaru Libird
It's not that this car sets supercar-like precedences in performance numbers but that it achieves supercar-like excellence. The excellence lies in that it one of the most natural, organic extensions of a driver's body available. Isn't that exactly what a driver's car should be, after all? Randy Pobst ranked the BRZ second behind the 911 and above the GT-R for this reason. The Elise achieves similar excellence, is faster than the FR-S, but the inherent snap oversteer/twitchiness tendency of a mid-engine layout and lack of LSD means control sensitivities are dialed way up whereas the FR-S offers a more forgiving window for correction whilst effectively communicating what's happening as you break traction. But why hasn't the Z been invited to this conversation?
The Z is not exactly praised for these delicate types of qualities but for other types of qualities. This thread is like trying to compare how well an Olympic gymnast (poised, balanced, coordinated, controlled) wrestles against and Olympic wrestler (brute, powerful, grabs by scruff of neck, still poised and controlled but not to the point where it racks the nerves due to intense concentration on delicate balance of movements). Of course, the gymnast will lose. But what happens if each athlete performs a set on the balance beam? Both cars excel at what they were intended to do. Based on my perception of how professional drivers have evaluated each car, the FR-S is a gold medalist in its event and the Z is a silver medalist in its event (IMO). Or you can subjectively argue they are equally excellent. Then it becomes a matter of preference; not a matter of which one is holistically "better" than the other. Sorry I had to make an abstract analogy lol but you can't compare 2 different athletic breeds of cars and expect a definitive conclusion. Don't waste time theoretically swapping ECUs, tires, brakes, or comparing numbers stock-for-stock. You need to compare how all components function in synergy as a package, at the top level where those lower component-level comparisons become trival. Instead of speculating how they compare on a forum in a bench race, ya either gotta drive the things. Or consider this man's opinions: [ame="http://www.youtube.com/watch?v=JUhLXvxlQR4"]Toyota GT86 / Scion FR-S v Nissan 370Z v Used Porsche Cayman S - CHRIS HARRIS ON CARS - YouTube[/ame]
#1327 |
Enjoy it, destroy it.
Drives: Datsun Racing Hen
The problem is, they didn't release a version that can really show off straight from the factory.
The FR-S needs some sort of "sport package" or "track package" option with bubblegum tires, bigger brakes, no backseat, stiffer sways, etc. Now THAT car would probably impress me -- and the FR-S can be that car (with further room to grow, I'm sure), but Toyota isn't selling it. Even the priciest factory version of the FR-S needs assistance to really show what it can do. Out of the box, it leaves too much to be explored by an aggressive tuner. Put another way, it shouldn't improve that much from tires -- that means the car is set up with components that hold it back. Why would you sell a sports car set up like that? I suppose that's cool from the standpoint of keeping costs on the initial purchase down, or the excitement of tuning, but a real bummer if you were hoping for a better starting point (i.e., I'd prefer to have bigger calipers on day one and just worry about pads and SS lines than all three). I'd rather have some of the good stuff already on the car at time of purchase, but that's just me. At least the LSD is stock. Last edited by Jordo!; 09-06-2012 at 03:17 PM. |
#1328 |
If you're referring to the validation of chassis comparisons by using similar tires across the board, then you've clearly missed the countless discussions before these last 3 pages. Only this time numbers have been stated (impressive ones at that). But when you reduce the argument down to numbers, naysayers will say you fail to describe the dynamics as it reaches and leaves that corner and beg the question of suspension architecture and if it can power out of the corner through straights (since corners aren't the full picture) which has already been beaten dead. And round and round we go.
Anyway, was a conclusion reached in the last 3 pages? If not, I haven't missed anything.
#1329 | |
I think the problem is that everyone thinks the car was built to be a great handling car, which I don't think is entirely true. I think it was built to be a great drifting car, which just happens to equate to a really good handling car. Well balanced, light weight, etc. |
| The Following User Says Thank You to Shagaliscious For This Useful Post: | fatoni (09-06-2012) |
#1330 |
But what's so wrong in asking for "the validation of chassis comparisons by using similar tires across the board"? (nice, succinct description, switchlanez).
Of course listing the tires would be mandatory for every car (because you need to know what tires were used). And obviously it's not the same if you start changing e.g. the suspensions or pretty much anything else (one of fatoni's BS claim). But he can't, or better said he refuses to understand that people are asking for a very specific thing which is meant to reduce variability (grip differences due to tires), and not add to it (random car changes). So he's repeating the same BS strawman each time people are asking for this specific thing. All because "our way" would make the GT 86 to good for his liking. switchlanez: Chris Harris is something... very passionate, a lot of feeling, I like watching him. |
| Tags |
| fanboi, lame |
| Nissan 370Z thread | S2KtoFT86 | Other Vehicles & General Automotive Discussions | 116 | 04-07-2017 10:40 PM |
| FT 86 & 370Z similarities | blur | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 11 | 10-05-2010 12:39 AM |
