#15 |
Vortech Supercharged
Drives: WRB BRZ 6MT LTD
That's awesome. Any plans for 3" piping on an exhaust like the Magnaflow?
#16 |
987 Motorsports
Drives: '13 WO FR-S
3" is too much for a car of this nature. unless it's FI.
sounds awesome!!!
#17 |
We will have 3" available for the turbo kit builds.
#18 |
Drives: BRZ WRB
sounds mean!
is that 2,5" OD tube version? to which HP you estimate this exhaust when going FI till it gets restrictive? I mean when do one will definitely need 3" OD pipes? |
#19 | |
987 Motorsports
Drives: '13 WO FR-S
with the N/A motor, no.
#20 |
Drives: BRZ WRB
sorry to be nerdy, but your black'n'whiteness sounds a bit rough
having FI doesn't mean your exhaust is choking your engine, it just promts you to ask "when do I need a bigger exit door?" I know the gas velocity physics and thermodynamic stuff around pretty well, that was the reason me asking when is the brakepoint for the tubing becoming a restrictive exit for the exhaust gases, generated by the motor? let's say I have 2,5" tubing all around from the turbo, to the exhaust tips, so when do I start seeing choke signs and wanting to switch to 3"? For example, AP BRZ-300 kit shows ~300whp, which is nearly doubling stock power, staying 2,5" in exhaust piping Even more, you may stick with a stock mid-and-rear sections, which are hella restrictive being bendy and 2.1" OD Last edited by MSTiFK8R; 09-05-2012 at 02:22 PM. |
#21 |
987 Motorsports
Drives: '13 WO FR-S
wouldn't it really relate to what kind of turbo you're dropping into the car? what goes in...must come out.
#22 | |
I Love custom Turbo kits
Drives: Limited BRZ
Don himself has said that up to 300 HP the stock exhaust was good on his setup. Adding an exhaust system to replace stock did not net any significant gains. I'd say you NEED and exhaust for sure if you go over 300 WHP.
| Stock resonator removal? | jm1681 | Engine, Exhaust, Transmission | 33 | 10-11-2019 06:58 PM |
| Intake resonator?? | DIE1000DEATHS | Engine, Exhaust, Transmission | 16 | 12-03-2014 08:17 PM |
| Brz/frs video. Bleeped version! | nytfury | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 1 | 08-30-2012 12:01 AM |
| Exhaust baffle/ box structure between cat and resonator? | ahausheer | Engine, Exhaust, Transmission | 14 | 04-25-2012 01:57 PM |
| Subaru Version (video) | #87 | BRZ First-Gen (2012+) — General Topics | 7 | 10-31-2009 01:44 AM |
