Old 09-01-2012, 11:52 PM   #1
F1point4
Photo Specialist
F1point4's Avatar
Drives: 2013 Toyota 86 DGM 6MT
DIY Blackvue DR400G-HD/Power Magic Pro Dashcam
20120831-LolaBlackVue400DIY-01 by VictorN07, on Flickr
Back again. This time we will cover how to install the Blackvue DR400G-HD combined with the Power Magic Pro monitoring system. Thanks to @DarrenDriven for his DIY covering just the camera install. http://www.ft86club.com/forums/showthread.php?t=15167
Please note you will learn the skills required to hardwire any sort of device (sat nav, radar detector, lights) safely to the vehicle.
This will be very picture heavy. Enjoy.
**UPDATE** Added a bit about where to buy everything. http://www.ft86club.com/forums/showp...5&postcount=23
The Kit
20120831-LolaBlackVue400DIY-02 by VictorN07, on Flickr
20120831-LolaBlackVue400DIY-03 by VictorN07, on Flickr
20120831-LolaBlackVue400DIY-04 by VictorN07, on Flickr
20120831-LolaBlackVue400DIY-05 by VictorN07, on Flickr
20120831-LolaBlackVue400DIY-06 by VictorN07, on Flickr
20120831-LolaBlackVue400DIY-07 by VictorN07, on Flickr
20120831-LolaBlackVue400DIY-08 by VictorN07, on Flickr
Tools Required
You may need different size fuses depending on the choice of circuits tapped into.
20120831-LolaBlackVue400DIY-09 by VictorN07, on Flickr
20120831-LolaBlackVue400DIY-10 by VictorN07, on Flickr
Preparation
Click for huge
20120831-LolaBlackVue400DIY-13 by VictorN07, on Flickr
20120831-LolaBlackVue400DIY-11 by VictorN07, on Flickr
20120831-LolaBlackVue400DIY-12 by VictorN07, on Flickr
Harness Setup
20120831-LolaBlackVue400DIY-14 by VictorN07, on Flickr
20120831-LolaBlackVue400DIY-15 by VictorN07, on Flickr
20120831-LolaBlackVue400DIY-16 by VictorN07, on Flickr
20120831-LolaBlackVue400DIY-17 by VictorN07, on Flickr
20120831-LolaBlackVue400DIY-18 by VictorN07, on Flickr
20120831-LolaBlackVue400DIY-19 by VictorN07, on Flickr
20120831-LolaBlackVue400DIY-20 by VictorN07, on Flickr
20120831-LolaBlackVue400DIY-21 by VictorN07, on Flickr
20120831-LolaBlackVue400DIY-22 by VictorN07, on Flickr
20120831-LolaBlackVue400DIY-23 by VictorN07, on Flickr
20120831-LolaBlackVue400DIY-24 by VictorN07, on Flickr
Last edited by F1point4; 09-06-2012 at 03:28 PM. Reason: Added clarity around choice of fuses specced
F1point4 is offline   Reply With Quote
Old 09-01-2012, 11:52 PM   #2
F1point4
Photo Specialist
F1point4's Avatar
Software
I found most of the software and manuals by reading some of this link. http://forums.redflagdeals.com/merge...-18-a-1147913/
**Update - Configuration settings http://www.ft86club.com/forums/showp...8&postcount=39
20120831-LolaBlackVue400DIY-25 by VictorN07, on Flickr
20120831-LolaBlackVue400DIY-26 by VictorN07, on Flickr
20120831-LolaBlackVue400DIY-27 by VictorN07, on Flickr
Dissasembly
20120831-LolaBlackVue400DIY-28 by VictorN07, on Flickr
20120831-LolaBlackVue400DIY-29 by VictorN07, on Flickr
20120831-LolaBlackVue400DIY-30 by VictorN07, on Flickr
20120831-LolaBlackVue400DIY-31 by VictorN07, on Flickr
20120831-LolaBlackVue400DIY-32 by VictorN07, on Flickr
20120831-LolaBlackVue400DIY-33 by VictorN07, on Flickr
20120831-LolaBlackVue400DIY-34 by VictorN07, on Flickr
20120831-LolaBlackVue400DIY-35 by VictorN07, on Flickr
20120831-LolaBlackVue400DIY-36 by VictorN07, on Flickr
20120831-LolaBlackVue400DIY-37 by VictorN07, on Flickr
Identification
20120831-LolaBlackVue400DIY-38 by VictorN07, on Flickr
Remove the fuse box cover.
20120831-LolaBlackVue400DIY-39 by VictorN07, on Flickr
20120831-LolaBlackVue400DIY-40 by VictorN07, on Flickr
20120831-LolaBlackVue400DIY-41 by VictorN07, on Flickr
20120831-LolaBlackVue400DIY-42 by VictorN07, on Flickr
Last edited by F1point4; 09-14-2012 at 11:47 AM. Reason: Inserted pictures and added a link for config settings
Old 09-01-2012, 11:53 PM   #3
F1point4
Photo Specialist
F1point4's Avatar
Wiring and Testing
I spec'd out three 7.5 A and one 15 A fuse. The "stop light" has a 7.5A fuse, and each power outlet uses a 15 A fuse.
Combine that with two 7.5 A fuses to hook up the power magic pro, you get the four I spec'd out.
If you decide to use different circuits you may need different sized fuses.
20120831-LolaBlackVue400DIY-43 by VictorN07, on Flickr
20120831-LolaBlackVue400DIY-44 by VictorN07, on Flickr
20120831-LolaBlackVue400DIY-45 by VictorN07, on Flickr
20120831-LolaBlackVue400DIY-46 by VictorN07, on Flickr
20120831-LolaBlackVue400DIY-47 by VictorN07, on Flickr
20120831-LolaBlackVue400DIY-48 by VictorN07, on Flickr
20120831-LolaBlackVue400DIY-49 by VictorN07, on Flickr
Reassembly
20120831-LolaBlackVue400DIY-50 by VictorN07, on Flickr
20120831-LolaBlackVue400DIY-51 by VictorN07, on Flickr
20120831-LolaBlackVue400DIY-52 by VictorN07, on Flickr
20120831-LolaBlackVue400DIY-53 by VictorN07, on Flickr
20120831-LolaBlackVue400DIY-54 by VictorN07, on Flickr
Tuning and Results
20120831-LolaBlackVue400DIY-55 by VictorN07, on Flickr
20120831-LolaBlackVue400DIY-56 by VictorN07, on Flickr
Thoughts after some use
Overall the camera works very well. There isn't much to set and most of it happens automatically. Pro Tip: once you are set on the angle of the camera use a permanent marker to mark the position so if you remove the camera you know where to reinsert it.
+ The unit will always start with normal mode. It will record everything.
+ After the ignition is cut, if there is no movement/event for 10 minutes it enters parking mode. It will only record when there is movement or an event.
+ When the ignition turns on, the unit reenters normal mode after about 10-20 seconds of driving.
+ @1080p you can record about 4-5 hours of video before it loops on itself
+ Having a power button via the power magic means I can turn off the camera without having to unplug the wires.
+ The video I get is on par with all the other videos posted on the internet. It is a good dash camera
+ The alternate viewer software is awesome. Plots on map, speed, times for scrolling.
~ The microphone isn't very sensitive.
- You need the original Blackvue viewer to configure the device
- The unit does run extremely hot. See the picture below.
20120901-LolaBlackVue400DIY-57 by VictorN07, on Flickr
Update:
Wanted a more stealth look. I moved the camera higher on the windshield (picture to come) and I Aperture Science the LED ring.
Used racer's tape for science. Left a little opening so I can still see the camera status.
Blackvue Sticker by VictorN07, on Flickr
Last edited by F1point4; 09-04-2012 at 10:23 PM. Reason: Added more clarity around the fuses, Aperture Science
Old 09-04-2012, 11:47 AM   #4
DarrenDriven
NW Region Moderator
DarrenDriven's Avatar
Drives: FR-S No More
Great topic, I am replacing the link to my installation in the DIY directory with this one.
DIY Directory
http://www.ft86club.com/forums/showthread.php?t=7365
My old installation topic:
Old 09-04-2012, 01:47 PM   #5
Rossman
Rossman's Avatar
Drives: '22 BRZ, '17 BRZ (prev '13 FR-S)
What a great DIY, thanks!
Just got my Blackvue from Korea today so we'll see how it goes!
Rossman is offline   Reply With Quote
Old 09-04-2012, 02:07 PM   #6
kwood9000
kwood9000's Avatar
Drives: Limited WRB AT6 BRZ
Great write up!
kwood9000 is offline   Reply With Quote
Old 09-04-2012, 02:17 PM   #7
Hawaiian
That guy
Hawaiian's Avatar
Drives: Ultramarine mt FR-S
Great work, and a quality DIY. If you were closer I would pay you to do this for me!
Ultramarine mt FR-S
P&L stage 1 turbo
Prime Motoring Flex fuel
Jr Tuned 506whp @17psi (e73)
Hawaiian is offline   Reply With Quote
Old 09-04-2012, 04:22 PM   #8
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
I notice with the add-a-circuit you cannot close the cover all the way. Doesn't our fuse box have useable but non-used circuits that don't require the use of an add-a-circuit (like a fuse for heated seats that aren't in the FRS for example)?
Would like to close fuse box cover all the way that is all.
Also:
Low Profile add-a-fuse:
http://www.ebay.com/itm/LATEST-LOW-P...item4abb89b83e
Old 09-04-2012, 04:47 PM   #9
F1point4
Photo Specialist
F1point4's Avatar
Also:
I didn't test the empty slots. The concern is how to secure the wire into the empty slots. There is only mm of clearance under of the lid. Most hardwire installs will present a challenge in closing the lid.
Every fuse that is marked in the manual and fuse box lid has a fuse installed, regardless of if that feature is present in the car (heated seats in frs)
The low profile add-a-circuit is great! Still won't let the box close though.
Old 09-04-2012, 10:23 PM   #10
F1point4
Photo Specialist
F1point4's Avatar
For science
Old 09-04-2012, 10:28 PM   #11
BRZranger
Because of your diy post, i stopped procrastinating, and dropped $250 for camera and power pro.
The blackvue camera I bought is a "session 2" version, which supposedly addresses the overheating issue.
Thanks for this great post.
BRZranger is offline   Reply With Quote
Old 09-05-2012, 05:54 PM   #12
Rossman
Rossman's Avatar
Installed mine today, just ran to the glove compartment 12V power for now. Quality of the recordings is amazing but they are large files!
The only thing I wish they would change is the camera should be black and not silver. As it stands, it's a little more noticable from outside the car than I would like.
Otherwise a good buy!
Can you let us know how hot yours gets? You might be the first person here with a Season II version!
Old 09-05-2012, 08:39 PM   #13
makalaka
makalaka's Avatar
Drives: 2013 Sonic, 2013 BRZ ltd
Mind sharing where you purchased it from?
makalaka is offline   Reply With Quote
Old 09-06-2012, 10:27 AM   #14
Rossman
Rossman's Avatar
Only place I've seen the "Season II" models is on ebay.
blackvue, dashcam, diy, dr400g-hd, power magic pro
Dash Cam Installation (BlackVue DR400G-HD) DarrenDriven DIY (Do-It-Yourself) Guides 93 05-01-2018 09:54 PM
R-Magic & Rasty build 86 toxicdrift FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 23 08-10-2012 12:24 AM
R Magic Parts List quik1987 Engine, Exhaust, Transmission 9 07-30-2012 01:55 PM
R-Magic Demo Car (Exhaust video too!) ttknf Engine, Exhaust, Transmission 5 06-06-2012 02:20 AM
