Drives: FR-S (Asphalt)
How many of you actually drifted your 86/FRS?
I'm not talking about 2 inch powerslides or chicano u-turns.
Well?
#2 |
Drives: Scion FR-S
i dont have anywhere close that i can try.... sure there is a couple turn arounds/dead ends in a industrial park which isnt dangerous late at night but there is always obstacles around that are dangerous to my cars health for someone who never really drifted.
#3 |
AutoX-10/10ths every run
I did last weekend here:
http://www.sdr-scca.com/solo2/schedu...2012-08-25.pdf Tons of fun. This car is very easy to control in a 4 wheel slide.
#4 | |
Drives: Scion FR-S
how did i not know about this
#5 |
There's still a few more events, come out!
http://www.sdr-scca.com/solo2/schedule/ Last weekend was my first event ever. |
| The Following User Says Thank You to whataboutbob For This Useful Post: | travace (08-31-2012) |
#6 |
Drives: FR-S Whiteout
Nothing awesome, but just some cones in a parking lot and keeping it in first and second. Just to feel how she holds in the corners.
#7 |
Boosted
Drives: Sideways
I've done some drifting, the Prius tires definitely help it get sideways. Not to mention the retarded factory -1.5 camber in the rear.
It's alright but only if you're staying under 15mph. Just not enough power. And 15mph isn't real drifting. Give me a couple weeks and I'll have you a REAL drift video with my recent power upgrade.
Nismo 370Z 300whp -> FR-S Turbo 450whp on E85 -> Z06 Corvette 500whp
#8 | |
Kouki-Monster
Rich Anderson
EMPOWER AUTO |
| The Following User Says Thank You to empower-auto For This Useful Post: | Guff (08-31-2012) |
#9 |
Drives: B9 S4/ND2
If anything the factory camber will make the car understeer.....
#10 |
Drives: Raven Scion FRS
![]() We've been known to get a little sideways... |
#11 |
Boosted
Drives: Sideways
I forgot to mention the front camber, which is set to ZERO. Proper drift setups always run more camber in the front than the rear. Toyobaru obviously gave the rear more negative camber from the factory so it could break traction easier.
If I ran a high speed drift setup it would probably end up being somewhere around -4F/-2.5R. But that's just a guess. But then again, the FR-S wasn't supposed to have a drift setup from the factory.
| The Following User Says Thank You to Synack For This Useful Post: | Guff (08-31-2012) |
#12 | |
Random Internet dad
Drives: 2013 FRS and 2010 Mini Cooper
My FR-S slides just as well on 18x8s running Hankook Ventus tires which have substantially more grip than the prius tires, and more HP to the wheels You do NOT need "crazy HP" or a turbo, so stop preaching about your lack of ability without power. That's your preference, and your style. It's not a requirement to drift. Many others have no issues drifting in this car, long sustained drifts too, by finding the balance points, and keeping speed. The AE86 is FAMOUS for drifting and is 250% driftable at stock. Hell with just coilovers and an LSD you can drift it even better, no extra power required. This car is the same way.
| The Following User Says Thank You to denkigrve For This Useful Post: | imravenit (09-03-2012) |
#13 | |
Boosted
Drives: Sideways
Seems like you have a lot of bottled up anger from other people posting about how they need mass amounts of raw power to drift. I didn't mention that anywhere in my posts, only that I believe that it needs more. Personally I'll be running upwards of 300whp which is WAY MORE than enough for drifting. But drifting isn't the only thing I do with the car. Your average Toyobaru driver isn't an expert drifter and might need more power to learn how to drift. Nobody is an pro right off the bat it balancing speed, power, body roll, suspension, etc etc. Can we please keep the drift purist conversation out of this casual thread? There doesn't need to be any hating going on in here. On a side note: I applaud you for drifting a 100hp vehicle with an open differential. That takes skill.
#14 | ||||
Random Internet dad
