#323 | |
Drives: subatoy
I will NEVER pay $5k for a turbo kit plus installation. I'm aiming to have $5k as a budget with the kit installed. Last edited by subatoy; 08-29-2012 at 09:50 AM. |
#324 |
Drives: Scion FR-S
All said and done, you're probably not going to be under 5k with this one either. (tuning, install, etc.)
#325 | |
Drives: 2013 raven black fr-s
I'd throw that budget out the window. Anyone that plans on spending xxx amount of dollars on a kit, and doesn't understand what adding more power does to vehicles. Things are going to break when extra parts are added. Just keep this in mind |
#326 | |
Boosted
Drives: Sideways
1. Having a turbo 2. Getting warranty work 3. Having a warranty at all 4. Passing emissions in cities Are you just going to remove the entire turbo kit and reflash a stock tune every time something bad happens? Good luck, I've never seen anyone work that hard or pull it off. Not to mention if they are trying to warranty something big like powertrain related, they'll search the flash-counter. And if you are t-charged, then your counter is likely to be a sky high number from tuning.
Nismo 370Z 300whp -> FR-S Turbo 450whp on E85 -> Z06 Corvette 500whp
#327 | ||
#328 |
Boosted
Drives: Sideways
My point is, you can only fool the dealership for so long.
#329 |
#330 | |
Drives: subatoy
so you are ALREADY starting with $1,400 on your pocket vs all other kits that cost $5k. I've either purchased turbo cars or turbocharged them all my life. Installation wise if you know the right people then it's cheap. tuning is another story. |
#331 | |
Drives: subatoy
thats why you look for the msot realiable option out there. running 430whp IS NOT reliable on a tiny engine with such high compression. this is why I want to stay at 5psi. |
#332 | |
King of Kiwi Palace
Drives: Faster than you
I agree somewhat, I mean if you look at it from other cars. Take a corvette for example the base model has 430hp. Double that with some slick turbo setup and you're looking at 860hp. That's crazy and probably not reliable. So doubling the output from any car is crazy, if you can do this safely with the FRS, give maybe a 1 year parts warranty, I'd be sold.
#333 | |
Drives: 2013 SWP BRZ
Until someone pops a motor, it's moot. Even then, there are many factors that will play into what made it blow. It's too early to tell. I wish it wasn't though, lol. |
#334 |
987 Motorsports
Drives: '13 WO FR-S
like modding any car, the stock block is only going to last so long.
#335 | |
Drives: subatoy
#336 |
| PC Build Thread | WingsofWar | Off-Topic Lounge [WARNING: NO POLITICS] | 126 | 01-22-2017 09:59 PM |
| FT-86 SpeedFactory - Firestorm Red - Build Thread | FT-86 SpeedFactory | Member's Car Journals | 38 | 02-26-2015 02:42 PM |
| JoeBoxer FR-S build thread | JoeBoxer | Member's Car Journals | 112 | 04-08-2013 01:19 AM |
| Compression ratio 12.5:1. Bye-bye Super charger & Turbo build? | fred_boosted | Engine, Exhaust, Transmission | 215 | 12-12-2011 07:23 PM |
| Team build thread; PROJECT.STH | trueno86power | Other Vehicles & General Automotive Discussions | 0 | 03-02-2010 10:13 AM |
