Old 08-27-2012, 11:28 PM   #15
xjohnx
Grip>Slip
xjohnx's Avatar
I actually ran the first day at Mid Ohio with stock springs and the second day with Eibach Sportlines
Impressions!?
Old 08-28-2012, 11:30 AM   #16
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Originally Posted by xjohnx View Post
Impressions!?
Working on the review. Sadly my data logger battery died after 1 lap with the sportlines.
However based on video it looks like 2-3 seconds on average faster and 1.5 seconds diff between the fastest lap with both.
However, there is some variance there as I was 1,100 miles from home in a brand new car for the first time on Mid Ohio. My lines seemed decent enough (not perfect but not bad for learning it on my own in a couple of sessions) but I was NOT pushing 10/10ths.
Car was in VSC sport and TC flashed like crazy, even though it almost never cut in. It flashes like crazy under braking and when hitting the curbing. I left in in VSC Sport for the same reasons I wasn't driving 10/10ths. It'll be good to get some time with the car on a track I know well, like CMP, Sebring, etc.
Here's a couple of laps: [ame="http://www.youtube.com/watch?v=q2RrZ26sM6Y"]2 laps at Mid-Ohio Sports Car Course in a Subaru BRZ - ITR Expo 2012 - YouTube[/ame]
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
The Following 2 Users Say Thank You to Dave-ROR For This Useful Post:
p911gt3 (08-29-2012), whataboutbob (08-28-2012)
Old 08-28-2012, 11:38 AM   #17
jadewbj
jadewbj's Avatar
Wow, that is a ton of stuff. That is crazy that it all fits.
jadewbj is offline   Reply With Quote
Old 08-29-2012, 09:21 AM   #18
Cornerman
Drives: 2013 WRB BRZ
Great video, Dave. Thanks for posting it. Smooth driving!
Taking mine to Mid Ohio in a couple of weeks for the PCA DE, and I've got a few setup questions:
I'm using stock size Pilot Super Sports on 8" wide PF01s - what would be good cold and hot tire pressures?
Planning to run max available neg camber with camber bolts - good idea? How much rear toe in with that (in degrees)?
Ive ordered pre-bedded XP10/XP8s to run on dedicated Centric Premium blanks - before I install them, is this a good combination for this chassis?
Everything else on the car is stock (except for the brake fluid).
The Beauty of Rear-Wheel Drive
2013 WRB BRZ Semi-automatic
2011 WRB WRX Sedan (sold)
Cornerman is offline   Reply With Quote
Old 08-29-2012, 11:56 AM   #19
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Thanks!
I was running about 32-33 cold, never checked hot since I was too busy (working the event) to do back to back sessions anyways. I'd probably start lower next time though, probably 30 or so is what I'll try next. Some of the guys that have tracked these a lot already like Matt Andrews would probably be able to answer this better.
I didn't run the camber bolts (had them, just couldn't find them at the time to install them), my alignment was:
L R
Front Camber
-1.0 -1.2
Front Toe
0.01d 0.02d (.03 total)
Rear Camber
-2.7 -2.3
Rear Toe
.12d .12d (.24 total)
I requested 0 front and .12 each in the rear.
With this setup the car did push a little, it wasn't bad and I made it conservative on purpose due to Mid Ohio's more dangerous nature and my unfamiliarity with the car and the new springs.
That's what I ran, except without new rotors and not pre bedded. They worked well, although the rears did not get very hot. I suspect an EBD bias issue there and I'm not sure if running a more, or less, agressive rear pad would be better. Not enough experience yet, but with those pads and ATE Super Blue fluid (or better) I ran into zero brake problems.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 08-29-2012, 12:30 PM   #20
Cornerman
Thanks dave, good info. Mid Ohio looks like a fun track - I've wanted to run there for years.
I have seen several people post that the rear brakes run cool - maybe the best setup is to use the lightweight unvented JDM rotors...
Old 08-29-2012, 12:39 PM   #21
Rampage
Senior Member/Old Fanboi
Rampage's Avatar
Drives: 2000 2ZZ-GE MR2 Spyder HT
WTF? MIniVan?
So many modders have more cents than sense!
Rampage is offline   Reply With Quote
Old 08-29-2012, 12:50 PM   #22
r15mohd
Drives: GS300 Solara V6 5spd SE-R (VVL)
take out everything but the yuengling and cooler...those are the only essentials needed!
r15mohd is offline   Reply With Quote
Old 08-29-2012, 10:28 PM   #23
Opie
Opie's Avatar
Drives: 2020 GMC Canyon Denali Diesel
Geez...buy the beer once you arrive! And for that matter...install the springs before you go! LOL
2020 GMC Canyon Denali Duramax, 2021 Forester Sport, 2000 Subaru Legacy B4 RSK 5MT (JDM Import) and random 86 chassis rebuilds....
Opie is offline   Reply With Quote
Old 08-30-2012, 12:08 AM   #24
Hamza7
Drives: MiniVan
Damn, that thing is packed. Good work making the most of what you have and need.
Hamza7 is offline   Reply With Quote
Old 08-30-2012, 01:15 AM   #25
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Beer was given to me there and the springs were delivered there too
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 08-30-2012, 09:28 AM   #26
Hanzo
Hanzo's Avatar
Drives: Waiting for the ND Miata
You know what you are missing? Better beer.
Hanzo is offline   Reply With Quote
Old 08-30-2012, 09:35 AM   #27
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
You might get banned if you keep that up.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
The Following User Says Thank You to Dave-ROR For This Useful Post:
forwallblakmail (08-06-2013)
Old 08-30-2012, 09:17 PM   #28
Turbowned
Turbowned's Avatar
Lol that's about the amount of crap I bring to an auto-x! Except in place of beer I bring an EZ-up and folding chairs so we can all chill in the shade when in between runs and course work. Yay for the MR2 having two trunks, but I bet the BRZ is even better!
I've never had Yuengling, I've heard it's only really "just OK" but it's a regional thing. Kind of like when I go to PA I get Iron City; it's not "good" by any means but you can only get it in the PA/OH area. New England is full of amazing breweries so I can count myself lucky for that
OK, back on topic! *Goes off to pour a glass of Opa Opa Raspberry Wheat*
DIY? Or bring it to the dealer? ArKiTeCkT Issues | Warranty | Recalls / TSB 8 08-19-2012 10:48 PM
Getting sticker crap off paint dgtlmn Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 3 08-18-2012 06:37 PM
Don't bring a knife to a gun fight... RRnold Off-Topic Lounge [WARNING: NO POLITICS] 9 03-15-2011 09:46 PM
