Old 08-23-2012, 10:19 AM   #1
Turbowned
Turbowned's Avatar
Understanding the BRZ/FR-S/86 Occupant Detection Sensor
Hey guys,
I just began training as a sales rep for a Subaru dealer, and I remember reading a few people complaining about the ODS (Occupant Detection System) for the passenger seat being too sensitive. While I have not experienced this first-hand, I just thought I'd share this tip that I got in my training, so that you can all understand how the sensor works and why it does what it does. Have a look:
August 2012
Understanding Occupant Detection System (ODS) on Impreza & BRZ
Federal Motor Vehicle Safety Standards, require the use of an Occupant Detection System (ODS). This system is designed to determine if a person is seated in the front passenger seat*, and, more importantly, if the person is of adequate size to be protected in the event of the deployment of the front passenger seat airbag (SRS) in a moderate to severe frontal collision.
Most Occupant Detection Systems measure the weight of the front seat passenger, to determine if the front passenger seat airbag should deploy.
All 2012 and 2013 Impreza and 2013 BRZ models use a new type of Occupant Detection System called Electrostatic Capacitance Sensor ODS. This system does not use weight to determine whether to turn the Occupant Detection System ON and OFF. It is important that you understand the operation of this system so that you can explain its operation and precautions to your customers.
Electrostatic Capacitance Sensor ODS uses electrostatic capacitance to determine passenger airbag status. Electrostatic capacitance represents a material’s capability of storing an electrical charge. Have you ever been shocked when walking across a carpeted floor and touching a doorknob? This demonstrates your ability to store an electrical charge in your body.
When anyone is seated or when anything is placed on the front passenger seat, there is a change to that capacitance value. This change in capacitance value is what the Electrostatic Capacitance Sensor ODS uses to determine whether the front passenger seat airbag (SRS) will be ON or OFF.
Everything that is placed on the seat will affect a change in capacitance value. The system can determine whether to change the OFF status of an airbag to ON depending on what is on the passenger seat which in turn causes a change in capacitance value. Some examples:
  • A proper sized passenger will change the OFF status of an airbag to ON
  • Plastic, metals and other substances, even if at a heavy weight, will not change the OFF status of an airbag
  • A false electrical charge, for example, those caused by laptops that are processing data, cellphones that are on or even an electric device connected to a car charger can cause the airbag status to switch to ON
  • When water or anything with high moisture content is spilled on the front passenger seat cushion, the airbag is designed to remain OFF until the seat cushion is dry. This will also be the case if the passenger has moisture on their clothing, such as rain-soaked pants or rain gear. In each of these situations, the airbag status may remain OFF even if a passenger is seated
Presentation tips to share with your customers:
  • “The Electrostatic Capacitance Sensor ODS on 2012 and 2013 Impreza and 2013 BRZ models uses a low level electrical charge to determine what is on the front passenger seat. (Explain to the customer that this low level charge will not result in an electrical shock)
  • Advise the passenger not to sit in the front passenger seat if the seat cushion is wet or if their clothing is wet
  • The best way to ensure proper operation is to keep everything off the front passenger seat except a passenger
  • For more detailed information, stress to your customer the importance of reading and understanding the Owner Manual
Hope this helps, guys and gals!
The Following 5 Users Say Thank You to Turbowned For This Useful Post:
@Art_Mighty (09-11-2012), BabaYaga (02-22-2016), Bonburner (08-23-2012), Guff (08-23-2012), Hawaiian (08-24-2012)
Old 08-23-2012, 11:58 AM   #2
number1Tango
Drives: Silver FRS
That explains why my iPhone turns the airbag on when laying on the seat. Interesting technology
number1Tango is offline   Reply With Quote
Old 08-23-2012, 12:08 PM   #3
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
thanks for this littl blurp, explains a lot
Old 08-23-2012, 12:18 PM   #4
Kairos
Drives: 2013 Whiteout Scion FR-S
Am I the only one who thinks that's ridiculous? "Honey its raining, the airbag won't work, get in the trunk!"
Kairos is offline   Reply With Quote
The Following 4 Users Say Thank You to Kairos For This Useful Post:
Bonburner (08-23-2012), F-Bomb (08-23-2012), FRSjeff (08-27-2012), Guff (08-23-2012)
Old 08-23-2012, 12:23 PM   #5
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
yeah I'm not a fan .. especially considering how Heavy these seats are
Old 08-23-2012, 07:17 PM   #6
BlueRZ
Drives: BRZ Limited M/T GBS
does that really mean no airbags for passengers when it is raining?
wouldn't that be a big liability issue for Subaru/Scion?
BlueRZ is offline   Reply With Quote
Old 08-24-2012, 12:55 AM   #7
Pscylo
Pscylo's Avatar
Drives: Raven FR-S
So to keep my phone from setting it off, I need a seat condom, or a spray bottle to keep the seat damp
Pscylo is offline   Reply With Quote
The Following User Says Thank You to Pscylo For This Useful Post:
Old 08-24-2012, 03:19 AM   #8
Memphis
Memphis's Avatar
Drives: Scion FantasticRoad-Sex
Great post
Memphis is offline   Reply With Quote
Old 08-26-2012, 07:34 PM   #9
Synack
Boosted
Synack's Avatar
Drives: Sideways
This is stupid, should've stuck with existing technology that already WORKED.
Don't fix what isn't broken.
Nismo 370Z 300whp -> FR-S Turbo 450whp on E85 -> Z06 Corvette 500whp
Synack is offline   Reply With Quote
Old 08-27-2012, 12:48 PM   #10
dura1198
dura1198's Avatar
Drives: 2015 WRX
Must be a radioactive banana I put on my seat that set the thing off.
dura1198 is offline   Reply With Quote
The Following User Says Thank You to dura1198 For This Useful Post:
Old 08-27-2012, 10:55 PM   #11
tonyho18
Drives: 2006 lexus is250
Im going to have to agree with this, Im sure there is some reasoning which makes this new technology useful. But I cant think of one thing, everyone and their mother uses a smart phone, and quite often I drive to work with my ipad on the passenger seat of my car.
tonyho18 is offline   Reply With Quote
Old 08-27-2012, 11:03 PM   #12
Synack
Boosted
Synack's Avatar
Drives: Sideways
It could be cost-savings; that's the only legitimate excuse I can think. Otherwise, the customer is getting the bad end of this.
Old 08-27-2012, 11:08 PM   #13
tonyho18
We constantly have problems with the old set up right now. People that are heavy set, and people that carry a ton of crap on the passenger seat generally set off the airbag light.
There's too many variables in the "New" setup.
I'm sure there we be some recall on this anyway.
-Toyota service writer- If you feel your dealer is giving you the run around shoot me a message and Ill see if I can help.
TonyHO.
Old 08-27-2012, 11:58 PM   #14
Synack
Boosted
Synack's Avatar
Drives: Sideways
By "set off" you mean turn on?
Fuel pump and speed sensor Tt3Sheppard Issues | Warranty | Recalls / TSB 28 04-20-2017 02:54 PM
Gearflag PRK902 8 sensor parking system DIREWOLF Cosmetic Modification (Interior/Exterior/Lighting) 3 08-21-2014 01:49 AM
TPMS Sensor Part Number or Compatibility civicdrivr Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 15 11-07-2012 02:06 PM
How to fool airbag sensor? track_warrior Scion FR-S / Toyota 86 GT86 General Forum 3 07-13-2012 12:46 AM
Stock O2 Sensor d1ck Engine, Exhaust, Transmission 1 07-11-2012 08:16 AM
