Old 08-27-2012, 11:14 AM   #141
Opie
Opie's Avatar
Drives: 2020 GMC Canyon Denali Diesel
Originally Posted by WTF View Post
I think a plug would be a 'dodgy fix'. The water should not be allowed to get into the hats AT ALL. I suggest the strut tops are insufficiently sealed.
If the water pools in there, then it means foul odour can enter the car, or when the boot/trunk gets hot, the water will evaporate and potentially cause other damage.
As mentioned, that pic was after 60km of driving, literally the morning after I bought the car, we pulled the suspension out. You can only imagine after a month of driving in the rain, how much moisture can get in there.
And yet the BC mounts have no seal at all....so they will let even more water up there...
Can someone measure the diameter of the hole? In mm, I'm trying to match the plug up...the D40 plug shows in the Subaru lookup....but it isn't anywhere near those holes....
2020 GMC Canyon Denali Duramax, 2021 Forester Sport, 2000 Subaru Legacy B4 RSK 5MT (JDM Import) and random 86 chassis rebuilds....
Opie is offline   Reply With Quote
Old 08-27-2012, 11:37 AM   #142
Zgrinch
Zgrinch's Avatar
Drives: 2013 Limited DGM BRZ
Subscribing to this thread. Living in rainy Florida this concerns me.
BRZGrincherhood
Zgrinch is offline   Reply With Quote
Old 08-27-2012, 12:03 PM   #143
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
I can later. Or you can when I bring the car in for an oil change
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 08-31-2012, 09:59 PM   #144
neurokinetik
neurokinetik's Avatar
Drives: 2013 Scion FR-S Firestorm
Probably the best thing to do would be to get some gasket material, and cut it to fit the top strut mounts. That would stop the water from getting in.
neurokinetik is offline   Reply With Quote
Old 09-02-2012, 05:46 PM   #145
russv
First 86
russv's Avatar
Drives: Scion FRS Argento Automatic
Originally Posted by cyde01 View Post
he even has toyota part numbers.
Thanks for the part number. Will order one.
Life is short...NO BORING CARS
russv is offline   Reply With Quote
Old 09-03-2012, 04:18 PM   #146
switchlanez
Glorious BRZ Master Race
switchlanez's Avatar
Drives: Subaru Libird
Originally Posted by whataboutbob View Post
Just got back from the dealer who found the plugs for the holes in the trunk above the struts.
Here's photos of the grommet in place, and the bag that it came in with the part numbers.
2012-07-25_11-44-41_548 by adventures with bob, on Flickr
2012-07-25_11-43-45_82 by adventures with bob, on Flickr
I understand these plugs are not part of PDI. Are these installed from the factory or is everyone missing these plugs on their cars because they are not installed from the factory and people are just adding these afterwards just because a part like this exists?
Old 09-04-2012, 04:21 AM   #147
DaJo
FT86Club Vancouver
DaJo's Avatar
Drives: BRZ Sport-Tech; Drove: MR-S, AE86
Just checked today, and I don't have these plugs on top of the strut mounts.
1984 AE86 BT 20V 5MT 2007-2012
2000 MR-S 5MT
2010-2012
2013 BRZ Sport-Tech 6AT
Since '12 (OEM+ STI tS Build)
2015 Lexus IS250 AWD F-Sport 2 2015-2018
2018 Lexus NX300 F-Sport 3 Since '18
DaJo is offline   Reply With Quote
The Following User Says Thank You to DaJo For This Useful Post:
switchlanez (09-04-2012)
Old 09-05-2012, 03:24 AM   #148
DaJo
FT86Club Vancouver
DaJo's Avatar
Because I am reeeeeeaally curious as if these are suppose to be factory installed (in Canada?) or if they're important enough to be ordered...considering the roads will be salted here...
2000 MR-S 5MT
2010-2012
Old 09-05-2012, 09:12 AM   #149
MattR
Running in the 90s
MattR's Avatar
Drives: 2014 Scion FR-S Monogram
Just went out to the garage to measure. They are roughly 1.5 inches, which is 38mm. D40 would be a tight fit but would work. I imagine the dealer had them on hand and used them as a best option if the diagram isn't showing anything there.
I've ordered a couple D40 plugs from the local Subaru dealer but that was two weeks ago and I haven't heard anything yet.
藤原とうふ店(自家用)
MattR's Tofu Runner
MattR is offline   Reply With Quote
Old 09-05-2012, 11:35 AM   #150
russv
First 86
russv's Avatar
I ordered these yesterday. Parts guy knew of no recall or TSB. Only $5 but this bothers me that it wasn't installed at the factory, especially since they can be ordered. During wet weather the trunk area could be a mess.
Many thanks to whataboutbob for part numbers.
Old 09-05-2012, 07:45 PM   #151
russv
First 86
russv's Avatar
Got a call back from dealer, seems they are back ordered for a month. Sounds like maybe lots of people ordering them.
Old 09-05-2012, 08:05 PM   #152
DaJo
FT86Club Vancouver
DaJo's Avatar
Just called Subaru and the damned Parts guy kept saying "if it didn't come with the car then I won't have a listing for it"
He didn't even bother to look it up.
Does anyone have the Subaru parts number for that strut mount grommet?
2000 MR-S 5MT
2010-2012
Old 09-06-2012, 10:14 AM   #153
xcelir8brz
Drives: 2013 BRZ Limited
Ordered mine here for my BRZ Limited: http://www.toyotapartszone.com/oem/t...003-03038.html
xcelir8brz is offline   Reply With Quote
Old 09-06-2012, 10:34 AM   #154
MattR
Running in the 90s
MattR's Avatar
The Toyota part number is a few posts above this. Alternatively, just ask the parts guy for a "Plug D40". That's how the Subaru dealer and myself found it in the system.
藤原とうふ店(自家用)
MattR's Tofu Runner
Basic tech info: spring rates, rear suspension, motion ratios, and you. Racecomp Engineering Suspension | Chassis | Brakes -- Sponsored by 949 Racing 77 07-08-2022 03:56 PM
water temp driver01 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 30 04-11-2013 03:57 AM
Impressive boot space! BD AUSTRALIA 14 08-24-2012 05:30 AM
Fatal FRS Flaw!! Skin Scion FR-S / Toyota 86 GT86 General Forum 4 07-12-2012 05:21 PM
Pics of rear passenger area with plastic removed JRitt Cosmetic Modification (Interior/Exterior/Lighting) 20 06-12-2012 09:17 AM
