Old 08-22-2012, 05:12 PM   #1
yomny
yomny's Avatar
Drives: 2013 FRS Whiteout
Thinking of spacers, thoughts!
Hello, as the title suggests i was thinking of adding some spacers to the stock wheels to push them out a bit. I dont think they're so bad looking and with a bit more fender flushness they could look nice. I've read several bad things about spacers, but i was planning on using the ones that replace the studs comepletely from the hub, not the ones that have studs attached and a nut for the oem studs. I was thinking any where from 12-17mm spacers, haven't measured yet. What do you guys think, has anyone done this here? Thanks a bunch.
GTX2867R, moto-tuned , tomei op , motiv fp , Invidia Q300 ti , Rota titan 17x9 +42 , nt555 255/40 , ST coilovers w/cascam , Hotchkis sways
yomny is offline   Reply With Quote
Old 08-22-2012, 06:00 PM   #2
Rawdog
Drives: 4.5in jeep
Yea I was wondering the same thing
Rawdog is offline   Reply With Quote
Old 08-22-2012, 06:18 PM   #3
yomny
yomny's Avatar
I think the car would look pretty darn good, i measured a few minutes ago and the tire sits just under 1" inside of the fender, with 17m spacers which is about .66" that would make it near perfect and allow full tilt outward under hard cornering without rubbing anything. Thats with stock camber, if more negative camber is added then you could go with a bigger spacer. I guess i may give this a shot and see how it works out.
Old 08-22-2012, 06:34 PM   #4
yoshiharadesign
Actually those are not spacers, they are spacer/adaptors. Depends on the quality of the part you purchase. minimal adaptor / spacer thickness for safety would be at 1 inch or 25.4mm to ensure strength. wouldnt recommend less than that. You could put on normal spacers, I think h&r sells 12mm ones but not sure if there are enough threads on ur studs. They do also sell extended studs. The safety for thread turn is 7-10 turns.
yoshiharadesign is offline   Reply With Quote
Old 08-22-2012, 06:46 PM   #5
yomny
yomny's Avatar
Damn, had me confused because they say spacers on the site, same as the H&R. They come with extended studs to guarantee safety and correct fitment. Check out the site and let me know, thanks!
Old 08-23-2012, 12:33 AM   #6
FRS8SIX
Drives: 2013 hot lava FR-S
I recently changed out all of my studs and added spacers.... ill take some pics tomorrow.
FRS8SIX is offline   Reply With Quote
The Following 2 Users Say Thank You to FRS8SIX For This Useful Post:
Rawdog (08-23-2012), yomny (08-23-2012)
Old 08-23-2012, 10:53 AM   #7
Rawdog
Drives: 4.5in jeep
would there be any negatives to this besides pontential tire rubbing? Like bad oversteer/understeer?
Old 08-23-2012, 11:05 AM   #8
yomny
yomny's Avatar
The tire would only rub if you add a huge spacer 30mm or more. People are fitting 9.5" wheels on these cars without rubbing. The handling is supposed to he improved dour to wider stance/track but with such a small change you won't notice anything. The handling won't change at all unless you adjust camber or add bigger tires.
Old 08-23-2012, 11:12 AM   #9
Rawdog
Drives: 4.5in jeep
cool now somebody needs to post some pics!
Old 08-24-2012, 01:48 AM   #10
FRS8SIX
:happy0180:
Old 08-24-2012, 06:26 PM   #11
TIMMAH!
Drives: Silver 350Z
So what's it look like with the wheels back on?
TIMMAH! is offline   Reply With Quote
Old 08-24-2012, 10:05 PM   #12
Mister_Sir
Mister_Sir's Avatar
Drives: 2013 Scion FRS
Originally Posted by frs86.tea View Post
:happy0180:
What size spacers are these? Is it hard to install?
Mister_Sir is offline   Reply With Quote
Old 08-25-2012, 12:53 AM   #13
jeebus
I've run spacers on a number of cars and I never had a problem. However, I ran them on BMWs, which have lug bolts instead of studs, so it's really easy to add a spacer...just add longer bolts and you're good
jeebus is offline   Reply With Quote
Old 08-27-2012, 11:24 AM   #14
Mister_Sir
Mister_Sir's Avatar
Bump.. pics of the wheels back on? lol
5mm spacers and hub rings. zooki Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 04-05-2013 10:57 PM
FS: 3/4" PVC Speaker Spacers/Adapters for the BRZ/FR-S phenryiv1 Audio/Visual, Electronics, Infotainment, NAV 1 08-22-2012 05:03 PM
spacers for 5x114 in australia derka-derka Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 0 06-30-2012 10:03 AM
H&R Wheel Spacers! vividracing Wheels and Tires 3 06-19-2012 05:11 PM
Spacers with Stock Wheels Starscream15 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 06-05-2012 01:31 PM
