Old 08-23-2012, 12:57 AM   #15
ABQautoxer
ABQautoxer's Avatar
Drives: 2021 Supra / 2022 Tundra
Local dealer sold me mine for $6ea plus tax.
TomR
ABQautoxer is offline   Reply With Quote
Old 08-23-2012, 12:57 AM   #16
ayau
Drives: Some rust bucket
anyone experience any chunking on the oem or other street tires?
Old 08-23-2012, 01:05 AM   #17
ABQautoxer
ABQautoxer's Avatar
You can on OEM and all season tires, even some summer tires if you don't manage the heat and get your camber dialed in. Did let them get very hot? Are you spraying them down with water between runs?
TomR
Old 08-23-2012, 01:48 AM   #18
ayau
didn't get any real chunking. i got some some small cracks here and there. maybe small pieces of rubber missing in some spots. i didn't water them down when i ran, but i will in the future. i suppose i'm not complaining about toasting the oem tires too much as i plan to get star specs once they're done.
Old 08-23-2012, 10:05 PM   #19
Simmons
Simmons's Avatar
Drives: 2024 GR86/ 2015 FRS
I put my BRZ on the scales tonight, no spare, tools, cover, floor mats, cup holder, Gas light just came on. Still has full stock exhaust, stock wheels/tires.
2,645 lbs
Simmons
2024 GR86 71 STR/ 2015 FRS 71 STX
Sponsors Xero-Limit//Karcepts
Simmons is offline   Reply With Quote
Old 08-23-2012, 10:27 PM   #20
des
des's Avatar
2,645 lbs
Wow, that's light. I got a fat one!
I weighed mine stock except for 235 Dunlops at the SoCal Divisional, right after I got the car; it came in at 2,720. Kevin Taylor's FR-S, with exhaust cutoff, lightweight wheels and 225 RS3s, was 2,675 if I recall correctly.
I'm sure scales skew a few pounds one way or another, but I thought the FR-S was supposed to have a little less heft.
des is offline   Reply With Quote
Old 08-23-2012, 10:32 PM   #21
iLuveKetchup
My VTEC fluid is full
iLuveKetchup's Avatar
Drives: EFF JAY
I got a stupid question.. Is it against stock rules if I get a BRZ premium and add the OEM trunk spoiler?
iLuveKetchup is offline   Reply With Quote
Old 08-23-2012, 10:33 PM   #22
Evil86
Evil86's Avatar
Drives: Monkey-butt red FR-S
Mine, weighed at the Super Regional, came in at 2675, sans spare, tools, mats (all of them), light wheels, owners manual, muffler delete pipe, and 215 RS3s.
Evil86 is offline   Reply With Quote
Old 08-23-2012, 10:34 PM   #23
Evil86
Evil86's Avatar
Yes. Also expensive because you have to install the entire trim along with the spoiler. Plus the spoiler is heavy.
The Following User Says Thank You to Evil86 For This Useful Post:
iLuveKetchup (08-23-2012)
Old 08-23-2012, 10:57 PM   #24
ABQautoxer
ABQautoxer's Avatar
I actually would disagree, locally at least. I don't believe there is any performance advantage so unless you win nationals, I would say this could fall under comfort and convenience on a regional level.
Simmons,
Thanks for the weight, its encouraging! My car should only be 14lbs heavier and you still have the 20lbs of wheel weight to lose, possibly more. Do those scale usually measure pretty accurately?
TomR
The Following User Says Thank You to ABQautoxer For This Useful Post:
Evil86 (08-24-2012)
Old 08-23-2012, 10:58 PM   #25
Simmons
Simmons's Avatar
On the same scales my STX Rx8 weighed 2,810
Simmons
Old 08-23-2012, 10:59 PM   #26
Simmons
Simmons's Avatar
Simmons,
Yes they are accurate. I weighed my other cars on these and SCCA scales with the same results.
Simmons
Old 08-23-2012, 11:10 PM   #27
ABQautoxer
ABQautoxer's Avatar
Cool, thanks again, good info. On your alignment, did you have to wiggle anything in the rear to get your settings? Seems like the rear is pretty good compared to some I had seen. We could probably talk about this at Nats but probably other people are curious.
TomR
Old 08-23-2012, 11:42 PM   #28
xwd
Gas Is pretty heavy and would explain some of the differences I can't remember anyone weighing the car with the light on.
57/43 weight distribution but that's not surprising. The bulk of the weight loss is in the rear of the car. With some lighter wheels and tires and a muffler delete pipe you could get awfully close to 2600 lbs. I was shooting for 2650 in my limited. There is a good 6-7 lbs if you drain the washer fluid.
Of course I could probably stand to lose a few lbs myself.
2012 BRZ/FR-S Stock Class Autocross Discussion EMguy Tracking / Autocross / HPDE / Drifting 183 01-04-2013 03:17 AM
What SCCA autocross class will the FRS be most competitive SVThis Tracking / Autocross / HPDE / Drifting 5 07-30-2012 04:29 PM
Share/discuss (this mornin) 86 Newsletter... RebootWindows AUSTRALIA 6 07-19-2012 04:15 PM
SCCA Solo Car Class for the FR-S/BRZ? MrVito Scion FR-S / Toyota 86 GT86 General Forum 31 06-15-2012 10:03 AM
Discuss.... carbonBLUE Off-Topic Lounge [WARNING: NO POLITICS] 12 02-11-2012 12:55 PM
