#29 |
Drives: '12 370Z Monterey Blue
Yes, I've seen the moisture collect around the 3rd brake light. Makes rear-visibility a little tougher but I saw similar issues with my old RX-7 and 300zx. Might just be the lack of square footage in the car + us breathing. Least of my worries right now, since mine won't even idle stable.
| The Following User Says Thank You to alrashwa For This Useful Post: | Godzilla35 (08-08-2012) |
#30 |
Señor Member
Drives: 2013 SSM DZE BRZ
You should add my thread to the list as I've had several reports from other users of the same or a similar problem. http://www.ft86club.com/forums/showthread.php?t=10986
| The Following User Says Thank You to Subie For This Useful Post: | imravenit (08-23-2012) |
#31 |
Waited 5 years for this
Drives: '18 MX-5 Club
Can you add mine too if you can?
Rear Deck "popping/clicking/tapping/ticking" noise |
| The Following User Says Thank You to Sigh-on-Rice For This Useful Post: | imravenit (08-23-2012) |
#32 |
Sarcastic SOB
The moist triangle wouldnt really be a defect. I am quite sure it is caused by the tenperature of the glass directly above the centre mount brake lamps on a hot day when the a/c is on. It is condensation as a result of temperatures merging at the glass.
#33 |
Drives: 2018 Golf R
I dont have the moist triangle issue, or at least Ive never noticed it.
Parting out HERE
#34 |
Drives: Scion FRS (RAVEN)
Just checked under my car and its leaking water? can anyone else relate? its on the passenger side its clear liquid leaking iono what it is could be the AC?
#35 |
#36 |
Drives: 2013 FR-S - Whiteout
i have a white FRS and the lines at the fenders and windows comes from the protective coverings,,,i had lines also. they come out when u wash and wax.
#37 |
Thanks my first new car lol
#38 |
Drives: Scion FRS 2013
Hi everyone!! I just purchased an black FRS automatic from Toyota in SF, but I do have an very sad story about my car.
My car was purchased on Sunday the 12th and I only had it for 24 hours. What had happened was when I was driving the car, I had heard something rattling in the car while just driving down the street, I pulled over to make sure it wasn't anything major...then I noticed as I'm pulled over their is oil all over the floor. I get the car towed to the dealership that evening to find out the results the next day.... Supposedly, their was a loose bolt behind the steering wheel that had shot into my motor while driving which pretty much shredded my entire motor destroying the transmission head valve. Toyota and Scion corp. came down and inspected my car to make sure I didn't do any wreckless driving, but obviously I wouldn't be able to because I only had the car for one day! I just wanted to share this story to just make sure you test drive it thoroughly! They did order me a new car and I should be receiving it at the end of this month, I'll let you guys know how it goes! |
#39 |
Drives: '13 DGM BRZ Limited
I'm confused. How does a loose bolt on the steering wheel get "shot" into the engine?
| The Following User Says Thank You to cnk For This Useful Post: | Mr. (03-23-2013) |
#41 |
| The Following User Says Thank You to Yuck For This Useful Post: | civicdrivr (08-20-2012) |
| Early problems - speaker rasp and long turnover | Hawaiian | Issues | Warranty | Recalls / TSB | 44 | 08-30-2013 04:39 PM |
| Initial Issues / Problems | JDMSushi | AUSTRALIA | 56 | 09-30-2012 10:21 PM |
| Problems with detailing | Nezz | AUSTRALIA | 23 | 06-28-2012 09:08 AM |
| Forum Problems | TRD-X | Site Announcements / Questions / Issues | 2 | 05-29-2012 10:45 AM |
| Do you think this car is going to have some problems? | Huss | Scion FR-S / Toyota 86 GT86 General Forum | 45 | 03-21-2012 01:48 PM |
