Old 08-14-2012, 06:34 PM   #29
Jackson
Jackson's Avatar
Drives: E46 M3 (daily) / EG Civic (track)
Originally Posted by JoeBoxer View Post
I wasn't trying to offend or anything i for one have never blown a shock due to a lowering spring. I know on lots of forums you will get blasted for putting any drop spring without changing the shocks but its possible he had a bad shock from the start also.
Oh, I didn't take it that way. No worries. I just used your post as an example because I want people to know things like motion ratio, shock limits, etc when using a lowering spring.
Jackson is offline   Reply With Quote
Old 08-14-2012, 06:39 PM   #30
chulooz
Registered you sir
chulooz's Avatar
Drives: 99 impreza coupe
1.4" drop blowing stock struts is no surprise, especially under heavy use.
chulooz is offline   Reply With Quote
Old 08-14-2012, 07:13 PM   #31
empower-auto
Kouki-Monster
empower-auto's Avatar
Surprise to me. I ran crappy Skunk2 springs on a Mazda 3 stock struts for 80k miles without a hiccup. It settled to be about a 2.5" drop
Rich Anderson
EMPOWER AUTO
empower-auto is offline   Reply With Quote
Old 08-14-2012, 07:37 PM   #32
alexmotrix
rookie drifter
Drives: 1987 ae86, 1985 celica gts
I will soon report to all of you but I'm at 2000 miles mark with stock springs and my girlfriend told me our Frs now feels like her civic when she had Monroe shocks( no one should ever to this, I got to replace them for KYB shocks 1 year later) so I will see with my dealer what they can do about it before I install my Tein H-TECH... Even the VSC is engaging since the front end is too soft... So don't put the blame on eibach that fast, you should remember this car is a subaru with all the reliability problems that come with it...
alexmotrix is offline   Reply With Quote
The Following User Says Thank You to alexmotrix For This Useful Post:
Jackson (08-14-2012)
Old 08-14-2012, 08:12 PM   #33
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Originally Posted by Memphis View Post
The sportlines were bought off of tirerack.com. They are not knock-offs by any means :p
Unless tirerack sells fakes....
They show them as available next month. As far as I know Sportlines haven't hit the streets yet outside of the prototype car(s?) (Pekingduck, and others?) who is now on coilovers.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 08-14-2012, 08:13 PM   #34
Memphis
Memphis's Avatar
Drives: Scion FantasticRoad-Sex
Originally Posted by Jackson View Post
We put hundreds of miles of testing on all of our spring kits. Not to mention we reverse engineer the factory dampers and we KNOW the limits of what the factory shocks can handle. Eibach springs don't blow shocks, bad road conditions blow shocks.
More details of how the OP's friend "busted" his factory shocks and got a set of Sportline springs before we even manufactured them would be great.
The PROKIT were bought off of Tire Rack. He got them specifically for the FR-S and does have the reciept and pictures of the box as well as picture of the car.
He is sending them to my email and I will post them ASAP.
Shocks are leaking bad.
And now that I think about it, his kit sure as hell sits a lot lower than a Prokit should. Its about where a Sportline kit would sit :p
Last edited by Memphis; 08-14-2012 at 08:21 PM. Reason: Chris said he meant PRO-Kit
Memphis is offline   Reply With Quote
Old 08-14-2012, 08:36 PM   #35
Jackson
Jackson's Avatar
That makes more sense that it's a Pro-Kit and not the Sportline. The Pro-Kit is a 1" drop and our engineers say there is no way that our springs would cause the factory dampers to leak.
What happened? There's a couple of things. I'm by no way discrediting your friend or Toyota technicians. I am simply posting this information for others to see so they do not make a common mistake with installing our spring kit or other spring kits.
We found out the hard way that if you zap off the factory top nut with an impact gun that you can actually spin the shaft internally causing it to click. If you spin the shaft too far this will cause the shaft to come disassembled internally and could, over time, cause the shock to leak. There is a special tool that needs to be used to lock the shaft from spinning when assembling and disassembling the front suspension.
If the special tool was not used and something else was used to hold the shaft, this could cause scoring on the shaft that could damage the internal seals, thus causing the damper to leak.
Has your friend called Eibach directly so our techs can help diagnose what is going?
The Following 7 Users Say Thank You to Jackson For This Useful Post:
03Z33 (08-15-2012), Bristecom (11-04-2012), DAEMANO (07-24-2013), Guff (08-20-2012), ill86 (08-14-2012), Memphis (08-14-2012), ultra (08-15-2012)
Old 08-14-2012, 08:44 PM   #36
Memphis
Memphis's Avatar
Old 08-14-2012, 08:46 PM   #37
Memphis
Memphis's Avatar
Thats a good question I will ask.
Old 08-14-2012, 08:49 PM   #38
Memphis
Memphis's Avatar
After reading this to him he thinks thats what happend.
The Following User Says Thank You to Memphis For This Useful Post:
Old 08-14-2012, 08:52 PM   #39
Memphis
Memphis's Avatar
How do you change the thread title? :P
Old 08-14-2012, 08:53 PM   #40
Memphis
Memphis's Avatar
I will say the car does ride a lot rougher with those springs. They are not anywhere near as friendly going over bumps and stuff as the factory ones.
Are the sportlines going to be even rougher?
Or is this again a problem with his shocks?
Old 08-14-2012, 09:01 PM   #41
20valvewynn83
20valvewynn83's Avatar
Drives: 2013 FRS/01 Tacoma
Heh he works for a Toyota dealership in sales. They know what he has done to his car. Depends on how much they like him I guess.
Truthfully Toyota has guidelines for shocks and if a tech replaces them and its not within the guidelines they will charge the dealership. Now unless he has a cool ass manager that doesn't care, then he is good. It has to be leaking all the way down and all around with stains on the shock housing.
20valvewynn83 is offline   Reply With Quote
Old 08-14-2012, 09:04 PM   #42
Memphis
Memphis's Avatar
They are replacing them from what I understand.
Actual Spring difference BRZ vs FRS Motopythons Suspension | Chassis | Brakes -- Sponsored by 949 Racing 66 05-13-2015 11:12 PM
Lowest quality spring? Synack Suspension | Chassis | Brakes -- Sponsored by 949 Racing 15 07-26-2012 01:00 PM
Suspension Installation Warning!!!! Don@Accelerated Suspension | Chassis | Brakes -- Sponsored by 949 Racing 15 07-20-2012 07:44 PM
Weird GT 86 factory spring rates in GT5? Spec-Al Suspension | Chassis | Brakes -- Sponsored by 949 Racing 36 03-27-2012 03:30 PM
FR-S to be priced at $22k and coming in Spring of 2012? vh_supra26 Scion FR-S / Toyota 86 GT86 General Forum 92 10-25-2011 10:06 PM
