Old 08-14-2012, 12:46 PM   #29
Furtive
Furtive's Avatar
Drives: 13' SSM BRZ
Originally Posted by old greg View Post
As a low-budget, seasonal solution, you could replace the rear dampers with ones from a late model Outback Sport (lifted Impreza) and add 1-1.5" spacers between the front strut tophats and the chassis.
which one will work?
Furtive is offline   Reply With Quote
Old 08-14-2012, 01:08 PM   #30
smbrm
smbrm's Avatar
Drives: Scion FRS Ht Lva(AT)
Originally Posted by Staticfrost View Post
You want more clearance... what do you have to clear? a 4x4 track? as it stand it already looks 4x4 stock. ROFL!
Depends on where you live some places have weird residential curb entries to houses. I cannot back straight out because when the front wheels drop down the sharp ramp, the momentum bounce is enough to bottom the car. I have to back out one front wheel at a time. Then its OK, but another inch in the snow can be useful on streets that don't get plowed, except for the bus routes!
smbrm is offline   Reply With Quote
Old 08-08-2013, 06:55 PM   #31
BigFatFlip
sleep, drive, eat, repeat
BigFatFlip's Avatar
Drives: '13 BRZ, '12 Outback
Very old thread to resurrect, but I figured this is the most appropriate place for it. I'm also looking for a way to slightly increase my ride height since I live in a not so low car friendly neighborhood. I've done quite a bit of research on height adjustable after market coil overs but all of them seem to be lower than stock at the highest setting.
Old 08-08-2013, 07:09 PM   #32
KKaWing
KKaWing's Avatar
Drives: Nissan Versa
I'm not too sure but HSD's were able to raise the Gen Coupe above stock height-ish (at least it looked monster truck-ish). You might want to ask the vendors.
KKaWing is offline   Reply With Quote
Old 08-08-2013, 07:24 PM   #33
BigFatFlip
BigFatFlip's Avatar
Thanks for the suggestion, looked them up, but no BRZ/FRS application so far.
Old 08-08-2013, 08:20 PM   #34
KKaWing
KKaWing's Avatar
Apparently HKS can too by about +20mm
Edit: Oh wait nvm... factory height is HKS factory preset height =_=; Srry...
Old 08-08-2013, 08:31 PM   #35
Suberman
Drives: Subaru BRZ Sport Tech Satin White
I think the BRZ has a ground clearance of 5.9 inches which is pretty normal for a passenger car. It only looks low, it's actually pretty normal height.
Suberman is offline   Reply With Quote
Old 08-08-2013, 09:37 PM   #36
troek
troek's Avatar
Drives: 2012 Toyota 86
haha i got a kick ouf the the guys telling the dude from alaska about winter driving. good stuff. thanks for resurrecting this
troek is offline   Reply With Quote
Old 08-08-2013, 11:55 PM   #37
BigFatFlip
BigFatFlip's Avatar
Yeah, thanks for checking, I remember looking at HKS a while back. I did find these from Subtle solutions:
I've used a set of these on my wrx in the past with little trouble (to get that little bit of extra height to survive those ruts from weekend rallyx's). Haven't heard of anybody using them here or in other forums. Seems like they just took their wrx and outback kits.
Agreed, but in my case, regular passenger cars (like my brother's civic) still scrape. Basically, my driveway dips down to my garage, which is below my house. I slightly high-center/scrape my mid pipe going over the sidewalk on my way down to the garage.
Old 08-08-2013, 11:59 PM   #38
Turdinator
Señor Member
Turdinator's Avatar
You could always get a sleeve kit welded on the stock struts/shocks...
Something like THIS.
1974 TA22 Celica
2013 86 GT
Old 08-09-2013, 12:10 AM   #39
azian_advanced
*****istrator
azian_advanced's Avatar
Drives: 2013 Scion FR-S 10-Series M/T
i personally wouldn't get coilovers since their damper settings are likely to be much stiffer than stock and the ride quality simply goes out the door! for a place like alaska, i'd guess you would want to avoid wheel hop after hitting a bump while keeping as much weight on the tires to maintain maximum traction.
i would look at alternative (taller) springs from other cars that fit the stock shocks/struts to get the added ride height, while keeping the stock dampers. also, those top strut mount spacers are a good idea.
SC10N FR-S #435 of 2500
azian_advanced is offline   Reply With Quote
Old 08-09-2013, 01:10 AM   #40
BigFatFlip
BigFatFlip's Avatar
Hmmmm...interesting, I've never heard of these, will look into them.
Yeah, been looking into taller front (wrx) and rear (outback) springs and maybe struts, but like you said, I'm pretty sure that will greatly affect the characteristics of the car. Seems like the spacers are the best/least expensive options so far, just was hoping to do an upgrade to "better" stuff in the process.
Old 08-09-2013, 01:21 AM   #41
Turdinator
Señor Member
Turdinator's Avatar
These are quite common on older cars where off the shelf coilover setups aren't available. If you kept the same spring rates as stock you would essentially have a stock ride with height adjustability.
1974 TA22 Celica
2013 86 GT
Old 07-08-2014, 04:25 AM   #42
Baramzisyan
turbo turtle
Baramzisyan's Avatar
Drives: exit GT86 enter STI
Bump! any solution with coilovers with extra height or stock road height?
Baramzisyan is offline   Reply With Quote
RS*R Sports-i Coilover system installed (pics) R0ME0 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 139 02-05-2015 03:38 PM
BRZ/FR-S Trunk Height? ngabdala Scion FR-S / Toyota 86 GT86 General Forum 1 05-24-2012 01:41 PM
Stock ride height or lower? StevenDavisPhoto Suspension | Chassis | Brakes -- Sponsored by 949 Racing 156 01-31-2012 10:58 AM
Lower ride height in NYC? blur NY / NJ / CT / PA 9 01-19-2012 06:31 PM
quick question about the height.. VenomRush Scion FR-S / Toyota 86 GT86 General Forum 13 12-22-2009 10:42 PM
