Old 08-09-2012, 01:11 AM   #43
Coheed
Coheed's Avatar
Drives: DGM BRZ Limited
Nice! the rods look beefy for factory, def look 400whp capable. The off center connecting rods are something I've waited to see in production cars for a long time. Cracked caps too, instead of cut. The off-center rods are similar to what a lot of OEMs are moving too. Strange, its a design used in lawnmowers, as well as high end high hp applications. Interesting they would use this design. What do you guys think?
Coheed is offline   Reply With Quote
Old 08-09-2012, 01:15 AM   #44
Coheed
Coheed's Avatar
These rods have withstood over 500whp without failure. I wouldn't push it though. Just goes to show you. These rods are from a k20a2, 86x86mm construction as well.
Old 08-09-2012, 01:51 AM   #45
Crawford
Crawford's Avatar
Drives: 2013 Subaru BRZ
Originally Posted by serialk11r View Post
Whoa what is the EJ257 rod length? The FA20 rods look to be not that much shorter!
5.135" on the EJ
Crawford is offline   Reply With Quote
Old 08-09-2012, 01:53 AM   #46
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
It appears a subsequent underlying theme here for the FA20 is: More power, thicker oil, keeps crank happy.
Any oil engineers lurking around?
Old 08-09-2012, 08:00 AM   #47
Chewie4299
Spaceman
Chewie4299's Avatar
Drives: 2013 Firestorm Scion FR-S
I like this thread. I know a lot about bolt-ons and some about FI (made myself learn when I bought an Evo) but just about nothing about engine internals aside from what the primary parts are.
Threads like this are going to be helpful in planning my modding route.
Sent from my Galaxy Nexus using Tapatalk 2
Chewie4299 is offline   Reply With Quote
Old 08-09-2012, 08:06 AM   #48
Coheed
Coheed's Avatar
On a turbo FA20, 5w40 rotella will do just fine.
Old 08-09-2012, 10:27 PM   #49
3MI Racing
Pro Subie Engine Nerd
3MI Racing's Avatar
Drives: empty spot for an FR-S/BRZ
Originally Posted by Crawford Performance View Post
If you wanted to be creative, you could put a 86mm FA crank into an EJ motor... now see if you can sleep tonight! Lol...
You sir are a wicked, wicked man. Do you have the deck height yet so I can start tossing numbers around?
3MI Racing is offline   Reply With Quote
Old 08-10-2012, 12:00 AM   #50
OrbitalEllipses
Drives: Attitude
Like feeding crack to an addict.
Old 08-10-2012, 02:58 AM   #51
noAE86
Drives: ae86, etc..
btw, love this thread,
as coheed said, very courious as to what people think about the rods, when i first saw pictures of them i had horrid flash backs to mini cooper engines,,, then i thought about the exotics now using them too,
noAE86 is offline   Reply With Quote
Old 08-10-2012, 03:34 AM   #52
20valvewynn83
20valvewynn83's Avatar
Drives: 2013 FRS/01 Tacoma
they make the rod bearings smaller to increase stroke and they strengthen the main bearings to make it stronger at higher horsepower and higher compression rate. yes it is heavier but all that means is you need more to spin it so it may not be the quickest at the light but when you get it moving the thicker counter weights will help it to move faster. This is why all the power is made at top RPM levels. This may also be why replacing the crank pulley an flywheel make such a big difference on this engine.
My opinion: I wouldn't be surprised if we are able to take this to +8k RPM's with out damaging the engine.
Yes i know i put "lagre" instead of "large" to lazy to fix lol
20valvewynn83 is offline   Reply With Quote
Old 08-10-2012, 04:15 AM   #53
Turdinator
Señor Member
Turdinator's Avatar
Subscribed.
Will be keeping mine NA so interested where this thread goes.
1974 TA22 Celica
2013 86 GT
Old 08-10-2012, 07:54 AM   #54
noAE86
Drives: ae86, etc..
my brain explodes everytime i look at subie oil systems and there cranks,
forged light weight I beam rods and pistons with knife edged crank will be the order for NA, im looking for built 20valve revs,
do subies eat oil pumps at all? im not very clued up on boxer tech,
Old 08-10-2012, 08:32 AM   #55
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
Subaru Oil pumps are pretty solid. They also move a LOT of oil. With 5w-30, oil pressures over 100psi are the norm on the EJ engines, especially 07+. The 07+ oil pumps are common upgrades.
I don't know what the FA engine is like, but I wouldn't be surprised if it's also over 100psi at full song.
Old 09-12-2012, 07:04 PM   #56
Crawford
Crawford's Avatar
Sorry... been away tinkering with motors and turbo kits for these cool rides!
FA20 Dimensions Matador Engine, Exhaust, Transmission 9 07-31-2013 12:45 AM
Which oil filter for the FA20? ft86Fan Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 58 07-09-2012 12:21 PM
FA20 Interference... phm14 Engine, Exhaust, Transmission 3 07-02-2012 06:18 PM
ej20 swap possible? jordydiaz Engine Swaps 4 06-13-2012 11:16 AM
HKS s/c FA20?? Rome Scion FR-S / Toyota 86 GT86 General Forum 6 04-04-2012 12:13 PM
