Old 08-08-2012, 09:14 PM   #1
Skorov
Skorov's Avatar
Drives: 86 GTS White
Where to put 6x9s?
Hey folks,
I've got a pair of 6x9s that I've taken out of my old car and I can't seem to decide whether to keep them for my 86 or just sell them. The way I see it, I have 2 options:
1. Sell them and replace the stock rear speakers with something better. The issue here is that I'm scared the sound might take a serious quality hit.
2. Find a place to put them in the rear. Maybe convert the stock housing if it's deep enough for 6x9s or build custom housings and put them somewhere. The downside here is obviously the housing. I'm kind of scared to cut a massive oval hole in my interior. Has anyone fitted 6x9s to their car? How did you do it?
I guess an overall picture of my setup would help. I'll put 6-inch speakers in the doors, tweeters in the dash and a 10-inch sub in the boot all running off 2 amps.
Suggestions please!
Skorov is offline   Reply With Quote
Old 08-08-2012, 10:12 PM   #2
Gir
Gir's Avatar
Drives: 86 GT Manual - Sonic Blue
Sell them if you're running a sub.
If you're not running a sub, sell them and buy a sub.
Gir is offline   Reply With Quote
The Following 4 Users Say Thank You to Gir For This Useful Post:
2pt5RS (08-10-2012), Calum (08-09-2012), denverizzles (08-09-2012), DIE1000DEATHS (08-09-2012)
Old 08-08-2012, 10:16 PM   #3
digital_assassin
digital_assassin's Avatar
Drives: 2013 FR-S Matte Orange
2nd
digital_assassin is offline   Reply With Quote
Old 08-08-2012, 10:31 PM   #4
mashal
DADA
mashal's Avatar
Drives: 2013
Well considering no one really answered you, Ill give it a try.
I would not put in the 6x9s they are way too big , if they are good quality im sure you can sell them for a fair price to be able to purchase some speakers to fit in the rear.
I have JL 4inch c2's in there right now, and they make a big difference .. The fill is perfect
mashal is offline   Reply With Quote
Old 08-08-2012, 11:02 PM   #5
Skorov
Skorov's Avatar
Yea... I'm starting to think that replacing the 6x9s with 4inch speakers would be the most practical option, even if the sound does suffer a bit. Hopefully it won't be too noticeable.
Thanks for the input guys.
Old 08-09-2012, 01:00 AM   #6
cruzinbill
Drives: Argento 6spd FR-S
you would be better off replacing your front doors with a nice set of 6.5s before wasting your time with replacing the rear 4", which are deck powered btw so they have even less power than the fronts.
cruzinbill is offline   Reply With Quote
Old 08-09-2012, 01:07 AM   #7
Skorov
Skorov's Avatar
Of course. Already have 6s to put in the doors.
Old 08-09-2012, 02:51 AM   #8
cruzinbill
Oh, in that case if your happy with your current low end then sure do the rears if you like, if not a small sub would be better money spent.
Old 08-09-2012, 05:46 PM   #9
Flat Black VW
Flat Black VW's Avatar
Drives: 2013 Subaru BRZ
just FYI, you absolutely could fit the 6x9s in the rear. I dont remember who it was but someone on here took a picture showing there was enough room to fit a 10in shallow sub back there. However to get the full sound from the speakers you would need to cut the interior panel and that just seems like a bad idea.
Flat Black VW is offline   Reply With Quote
Old 08-09-2012, 06:29 PM   #10
Skorov
Skorov's Avatar
Already got a 10inch sub waiting. Haha. Read the last paragraph of my OP.
Is that right!? You mean in the space where the stock 4inchers sit? Good to know that that's an option, but yea... cutting into the interior scares me a alot.
@ GuyThatFlatBlackVWIsReferingTo: If you happen to read this, please link me to your photos. Thanks!
Old 08-09-2012, 09:28 PM   #11
Flat Black VW
Just pop the panel off and check it out. It comes off pretty easily. Behind the panel it's very empty and the 4" speaker is just mounted in the middle of a big empty gap on some metal brackets. I'm on my phone now but tomorrow at work I'll try to find some pictures for you.
Old 08-09-2012, 10:49 PM   #12
wheelhaus
wheelhaus's Avatar
I vote don't even bother with trying to fit 6x9's in the rear at all. Instead- A: Keep the stockers; B: just don't use them, or C: remove them altogether. Sell them for some cash or another small upgrade somewhere... Some sound deadening will add minimal weight and make substantial improvements in SQ.
I recommend: Stick with the rest of your plan to do a good 6.5" component set up front with a 10" sub in the back. You get a clean front sound stage without the extra noise coming from the 6x9's behind you. A lot of people like extra speakers because it makes the music sound "richer" and "more speakers must be better", but in the end it just causes listener fatigue by scattering the detailed sound. Surround sound is different, it needs the zones, but this is just stereo L+R. Crossover and EQ everything as best you can, (and time align it if possible) and the overall sound quality will be better than with the extra rear speakers.
If you absolutely NEED sound from the back, keep the gain low and use them only for fill, maybe just enough to barely hear them. Dial back the high frequencies if possible to keep the detail and focus on the primary (front) drivers that are creating the sound stage.
Old 08-10-2012, 02:13 AM   #13
Skorov
Skorov's Avatar
Very well said! I never thought of it like that.
Sound deadening is definitely on my todo list. I've never actually had any before, but I've read nothing but good things. Will most probably go in when I add my speakers. Just in the doors should be fine yea?
Old 08-10-2012, 11:50 AM   #14
wheelhaus
wheelhaus's Avatar
The doors are the most important because they directly share the air space of the speakers. If you only plan to do a little bit, definitely focus here because this is the most sensetive area.
Other areas to look for would be any body panel that seems to rattle or resonate when you tap on it. Most of the interior panels will be relatively easy to pop loose to access the skin. The roof skin is a tricky one; it's exposed to the sun and the deadener can droop and sag from the heat, maybe leave it alone... For most of these noisy panels you only need to use a patch of deadener big enough to kill the resonation. You want a sort of dead thud when you tap it. For the doors, feel free to do as much as you like, you can even use some metal sheeting (like a punched mesh or something lightweight) to cover the openings in the inside door structure, and layer deadener over top of it. The more you add here the more acoustically solid the door will be. I've heard door speakers that have a REALLY impressive thump and midrange clarity that didn't exist before adding deadening. Check out a mobile audio site such as www.DIYmobileaudio.com for more ideas. Some of those guys are obsessive!
For installation, clean the surfaces well (finish with isopropyl alcohol) and use a roller or something to finish the application. Try to avoid air bubbles, its not critical but helps it last longer since the air will try to expand/contract from temp changes. Several small pieces are just as effective as one large piece. Overlapping and layering helps as well, and will improve the deadener effect. Aluminum tape is best for a long lasting finish over edges and other bits that need to be taped down. Overall it's not hard, just takes time.
