Old 08-08-2012, 04:05 PM   #71
Spd229
Spd229's Avatar
Drives: Ultramarine FR-S AT
This is pretty great stuff.
Hoping to hear some info on things of this sort for the automatic.
Spd229 is offline   Reply With Quote
The Following User Says Thank You to Spd229 For This Useful Post:
blackfireball5 (08-08-2012)
Old 08-08-2012, 04:16 PM   #72
blackfireball5
blackfireball5's Avatar
Drives: Scion FRS Firestorm
This.
blackfireball5 is offline   Reply With Quote
Old 08-08-2012, 04:25 PM   #73
20valvewynn83
20valvewynn83's Avatar
Drives: 2013 FRS/01 Tacoma
I havent sat down to read 4 pages of info but i see you almost take your redline to 8k rpms is it safe to adjust the rev that high or did you do something to support a high redline
20valvewynn83 is offline   Reply With Quote
Old 08-08-2012, 04:28 PM   #74
Coheed
Coheed's Avatar
Drives: DGM BRZ Limited
That is awesome. Good runs, car sounds like its running healthy. And that mileage is awesome. It makes me wonder who did the tuning on the OEM side of things. I wonder if they were trying to balance cat efficiency with mileage or something.
Coheed is offline   Reply With Quote
Old 08-08-2012, 04:32 PM   #75
serialk11r
Drives: '06 AM V8V Coupe
Cat lifespan I think, which tells you a lot about OEM priorities because emissions>>>fuel economy and running extra rich increases emissions :O
Old 08-08-2012, 04:54 PM   #76
Bg8780
Bg8780's Avatar
Drives: '13 Black Subaru BRZ Limited
I'm curious of this as well. I'm sure Subaru would have made the engine rev to 8k if it would have been safe and warranted more performance. Is there anymore power outside of 7400?
Bg8780 is offline   Reply With Quote
Old 08-08-2012, 04:58 PM   #77
eikond
Wish Nissan made one
eikond's Avatar
Drives: '13 WRB BRZ Premium
Originally Posted by brichard0625 View Post
Lets all also remember that i stopped the test once the gas light came on..i actually pulled over on the side of the highway and took a picture. Thats why the hazards are on in the picture. If i were to let the needle hit E i would easily get another 30 miles and my MPG would be at around 39mpg.
What are you talking about? You clearly need to re-think your understanding of what miles per gallon means and how it's calculated.
If you would have driven another 30 miles you would have use another gallon of gas (a little under).. You can't just keep driving and then use the same calc for your miles per gallon average.
You need to stop putting so much faith in the dash display and start measuring with real life variables..
Here's a proper way to measure gas mileage.
-Fill tank.. allow pump to stop when it reaches pressure level and shuts off automatically.. consider this "full"
-reset one of the trip meters to zero before you leave the gas station.
-Drive car until you are low on gas (at least under 1/4) or until the light comes on.. depends on preference.
-Go to gas station, fill gas tank until pump automatically shuts off. Consider this full.
-Now calculate.. number of miles on trip meter / gallons filled. This is your miles per gallon.
repeat cycle at least three time to get an accurate average.
I put very little stock in the on-board trip computer. I'm normaly surprised if it's within 2 mpgs of reality.
Still, having said that.. 36mpg or anything within 2 of that is a very good result..
I have no doubt the tune improved how the engine runs. I'm sure it's smoother, has more power, and is more fuel efficient.. But I put zero faith in your measurements at this point. Please do them properly and report back to us.
eikond is offline   Reply With Quote
The Following 2 Users Say Thank You to eikond For This Useful Post:
20valvewynn83 (08-08-2012), Bg8780 (08-08-2012)
Old 08-08-2012, 05:01 PM   #78
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
For those with turbos there is a lot of power north of 7400 it seems. So these tunes could be huge.
If the tune nets my car 10+ wheel hp for 800-900 dollars I would pick it up. I ordered a SRT header back exhaust and plan on running an intake as well - so if I net 20hp at the wheels I would be quite happy (exhaust is dyno'd to add between 8-12 whp depending on rpm)
Old 08-08-2012, 05:11 PM   #79
20valvewynn83
I wanted to say this but i was too lazy to type it thanks
:happy0180:
Old 08-08-2012, 05:14 PM   #80
Visconti
Drives: 05 STi
I've been a little busy so I haven't been reading every post but during this testing it has been discussed and expected that gas milage is calculated with hard math - like quoted above. Anything short of that is useless.
When I get home I'll read thru everything.
John
Visconti is offline   Reply With Quote
Old 08-08-2012, 05:18 PM   #81
mike2100
mike2100's Avatar
Drives: 23 BRZ
Mods, can we get an "MPG/Fuel Efficiency" sub-forum created? I keep coming back to this thread looking for performance information, but make a sad face every time.
mike2100 is offline   Reply With Quote
Old 08-08-2012, 05:26 PM   #82
brichard0625
brichard0625's Avatar
Drives: 2013 Scion Frs(Scarlet)
Whoa buddy lets relax and slow down. Nobody said i was done with the test! I did one run today for everybody as promised(reason why i said 1 run in the video post) and i parked my car. Nobody was going by the dash and if you read all my comments i think it was stated at least 3 times! And i think i did state that i pulled over to the side and took a picture when the gas light came on and didn't drive to E. As you can see in the video im still on E. I just did the calculation when i filled up until i finished. Havent gotten a chance to hit the gas station and will do that for everybody. ill record me filling up if it will make u happier.
brichard0625 is offline   Reply With Quote
Old 08-08-2012, 05:37 PM   #83
brichard0625
Maybe i should have said im done with my tank instead of done with the test. Im still going to do at least 3 more tests. Doing another test driving the same and then after that a test while i drive a little more spirited.
Old 08-08-2012, 05:45 PM   #84
eikond
eikond's Avatar
Great! I'm glad you plan to take direct measurements from gas station fill ups..
I was just worried when I read the part where you said that driving an extra 30 miles would increase your mpgs from 36 to 39.. hopefully that was a mis-type or accident or something.
No offense meant.. I'm glad your testing things out and I'm really happy to hear about all the positives from the tune.
Visconti Tuning - Latest BRZ Flash Info Visconti Software Tuning 6530 12-24-2013 11:18 PM
86/FRS/BRZ Tuning Guide ESBjiujitsu Engine, Exhaust, Transmission 18 05-30-2012 07:42 PM
Anyone into DIY ECU tuning? Saibot Engine, Exhaust, Transmission 26 04-25-2012 02:16 PM
BRZ/86 HKS Tuning Parts superhappyfunfun BRZ Photos, Videos, Wallpapers, Gallery Forum 11 04-23-2012 06:44 PM
Tuning Jordo! Engine, Exhaust, Transmission 54 09-05-2010 06:29 PM
