Old 08-08-2012, 07:33 AM   #1891
denverizzles
being that this thread is so damn long, i'm sure it's been asked, but does the turbo placement have any issues when driving in snow or water? being that it's exposed in the undercarriage of the car, i'm worried that in chicago's 10 inch winter snow, that the turbo can get damaged. Any thoughts?
denverizzles is offline   Reply With Quote
Old 08-08-2012, 07:35 AM   #1892
lordtakuban
lordtakuban's Avatar
Drives: 2013 FRS - Whiteout
There seems to be a lot of focus on the final number. To me, the dyno plot looks fantastic. It's smooth and linear and adds about 50% to the stock output. For usable power, it's more about how much power it makes in the low to mid RPMs than at redline. Very well done. If that can run safely in a daily driven car, that would be precisely what this car needs.
This thread is quite long. But I'm assuming that the only modifications aside from the turbo kit are a full exhaust? Were there any other parts that have been changed (injectors, pistons, etc?)
2013 FRS - Whiteout - Slightly modified
2001 MR2 Spyder - Super White - Heavily modified
lordtakuban is offline   Reply With Quote
Old 08-08-2012, 07:48 AM   #1893
Visconti
Drives: 05 STi
Stock Motor
Stock Header
Turbo back exhaust
BRZ-300 Turbo Kit
EcuTek Flash
OMNI 4 bar Map Sensor
Visconti is offline   Reply With Quote
Old 08-08-2012, 07:53 AM   #1894
TSLRich
Drives: FJ Cruiser
Originally Posted by Don@Accelerated View Post
Final Numbers to which we are going to test the car at. Not the highest hp and tq figures we have done, but we feel this is a nice spot to stop to test. I feel this is a good area for pumpgas users.
Don
WOW!... this is fantastic.
TSLRich is offline   Reply With Quote
Old 08-08-2012, 07:58 AM   #1895
Don@Accelerated
Don@Accelerated's Avatar
Originally Posted by KamalT View Post
Now all we need is one for the RHD drive market. Not buying coilovers and mags and going to use that money to boost this. Also bought a GT instead of GTS, for the same reason
I have a RHD distributor is who going to do the upfitting.
Don
Don@Accelerated is offline   Reply With Quote
Old 08-08-2012, 07:59 AM   #1896
Don@Accelerated
Originally Posted by Coheed View Post
You guys running into knock issues @ 10psi? Or is the lack of injector cc the reason you're backing off a bit. I know its a fresh motor and you don't wanna blow it up.
We are not running into knock.
Old 08-08-2012, 08:01 AM   #1897
Don@Accelerated
Originally Posted by serialk11r View Post
A good clue would be how much boost there is at highway cruising engine speeds. Now since their dyno run starts at ~2500rpm it's a little hard to tell, since the transient response of the turbo is an issue, but it looks like the turbo doesn't really "spool up" until you hit well over 3500rpm.
Any fuel economy loss at steady low load cruising conditions will be due to the turbine adding restriction to the exhaust, which doesn't seem like it's going to be a big deal. Most turbo engines "spool" well before this one does.
Under normal acceleration, engine efficiency will drop a little bit when you use boost, but again it appears there is very little boost below 3000rpm so probably not going to impact fuel economy much.
Best if they can tell you how much boost it builds in the lower engine speed ranges, and if they have any exhaust pressure readings (probably not going to be a significant increase).
Previously I had 4psi at 2800rpm. The dynojet 24" roller does not have the weighr resistance like the car. We are actually allowing the turbo to come on a bit smoother so that we do not have to much torque down low on the stock engine. All I would need to do is put a 10psi wastegate spring in it and it would come on much harder. I want to know what this will do reliably. We could always crank on it, but its not what we were after. I could post up a final run count, but i'm sure its around 170 Dyno pulls now since turbo.
Don
Old 08-08-2012, 08:03 AM   #1898
Deebeaux
Deebeaux's Avatar
Drives: i walk the streets.
Bang for the buck this kit looks damn good. It gets more and more tempting every day you guys post here. Each time there's a new post from Don or John I my want for boost creeps a bit more toward outweighing my want for warranty.
Any guess on how long the clutch will tolerate this?
--- Deebeaux
--- Former '13 FR-S Turbo Owner
Deebeaux is offline   Reply With Quote
Old 08-08-2012, 08:05 AM   #1899
os86
Drives: 2jz
Don
Please pm more detail on the distributor in Australia
os86 is offline   Reply With Quote
Old 08-08-2012, 08:11 AM   #1900
Don@Accelerated
Still working on the details. Should be able to let you know in a few weeks.
Don
The Following 2 Users Say Thank You to Don@Accelerated For This Useful Post:
os86 (08-08-2012), sticky (08-08-2012)
Old 08-08-2012, 08:12 AM   #1901
Spd229
Spd229's Avatar
Drives: Ultramarine FR-S AT
This is looking really awesome.
Granted it will be quite some time before I divert any funds to this...but I am definitely looking forward to seeing how reliable this turbo / tune is along with the gas mileage.
Really fantastic work guys.
Spd229 is offline   Reply With Quote
Old 08-08-2012, 08:26 AM   #1902
Visconti
Drives: 05 STi
I've spent a lot of time on this calibration to make sure it's spot on.
Today we'll take Don's car on the street and continue to tweak it - WOT Performance isn't the only thing on my mind.
When all said and done this car will have my latest MPG tricks in it
-John
Old 08-08-2012, 08:36 AM   #1903
os86
Drives: 2jz
-John
John. Good work on the tuning side. Very impressive in the short time frames. Lots of other tuners are hiding numbers but hats off to you and Don for sharing all this info with the broader community.
Now..at some stage down the track will you or @don consider a stand alone ecu as the stock ecu may be limited to further enhance the tune. Mainly in relation to the DI system
Old 08-08-2012, 08:41 AM   #1904
TSLRich
Drives: FJ Cruiser
-John
I can't wait to see some more street videos in its current state... the way it ripped 2nd gear @ 4psi, I can't wait to see 10 psi.
we definitely need to see some sort of 1/4 mile run too.
accelerated performance, brz forum, brz forums, brz turbo, brz turbo kit, fr-s turbo, fr-s turbo kit, frs turbo, frs turbo kit, scion fr-s turbo, scion fr-s turbo kit, scion fr-s turbocharger, scion frs turbo, scion frs turbo kit, scion frs turbocharger, subaru brz forum, subaru brz forums, subaru brz turbo, subaru brz turbo kit, subaru brz turbocharger
Accelerated Performance 2013 BRZ Intake Dyno Testing Video Don@Accelerated Engine, Exhaust, Transmission 109 05-17-2013 11:24 AM
Accelerated Performance 2013 BRZ Exhaust Systems Don@Accelerated Engine, Exhaust, Bolt-Ons 135 09-03-2012 11:24 PM
Accelerated Performance 2013 BRZ/FRS Exhaust Systems Don@Accelerated Engine, Exhaust, Bolt-Ons 24 07-07-2012 07:05 AM
Hello from Accelerated Performance! Don@Accelerated Announcements, Contests, Giveaways 5 07-04-2012 08:14 PM
