Old 01-29-2023, 03:59 PM   #155
Teseo
Drives: frs
Did I need a retune if I install aftermarket overpipe or frontpipe?
Old 01-29-2023, 06:21 PM   #156
tomm.brz
Drives: brz 2017 hksv2
if switching to a catless fp, it will throw a bit off the afr and change the knock resistance, definitely worth to take a look at logs and adjust
Old 01-30-2023, 04:58 AM   #157
gonzo
Drives: frs
steve99 was unfortunately banned. You can find him on the OFT FB group if you use FB. There are others here that can probably answer your question. I haven't touched any of that stuff since I had my car tuned but there are others who are very knowledgeable who may chime in and answer for you.
Reason for ban? Curious.
gonzo is offline   Reply With Quote
Old 01-30-2023, 05:25 AM   #158
Teseo
Drives: frs
Some asshat complained. Woke forum
Old 01-30-2023, 07:22 AM   #159
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
Wouldn't say the forum is woke.
Shit there's alot of shit I wanna say that is way more non PC that the shit I type and what I do now is non PC to woke people.
Old 10-13-2026, 04:38 PM   #160
callisto
Drives: 2019 Subaru BRZ
U01A (20JP) tweaks to tip-in enrichment tables
OFT Tune Tweeks and Information
Tweak to smooth low down Throttle response - alter the tip-in enrichment tables
The standard tip-in does not activate till 1.5% throttle delta AND the minium tip-in pulse width of 2.4ms is exceeded this means no tip-in till aprox 8% throttle delta. Changing the minimum pulse width activation to 1.5ms and a tweak to the enrichment tables will get the tip-in started at about 4% throttle delta. Smooths out low end throttle response and takeoff.
U01A (MY 20JP) uniquely among every version I've decoded reduces Minimum Tip-in Enrichment Activation to 1.2ms, beyond the 1.5ms recommended generally; so it seems that Subaru agrees with that change and takes it a step further. While they don't alter the enrichment tables as above, U01A does also add a unique alteration to Tip-in Enrichment Compensation B/C (ECT) that increases cold and decreases hot enrichment above 50% port injection, which seemed worth noting:
Tip-In Enrichment Compensation B, row 1.0 (100%): 40°C = -20%; 50° = -60; 60°–110° = -70.
Tip-In Enrichment Compensation C, row 1.0 (100%): -40°–0°C = 60%; 10° = 50; 20° = 40; 30-50° = 30.
callisto is offline   Reply With Quote
Old 10-14-2026, 07:28 AM   #161
makinen
makinen's Avatar
Drives: Toyota 86
The A01G definition has no Port Injection Ratio index in those tables, then those Tip-in Enrichment Compensation B/C (ECT) can't be ported, or can we?
/* Custom underbody panels and diffuser
Custom electric water pump and PWM controller
makinen is offline   Reply With Quote
Old 10-14-2026, 04:19 PM   #162
callisto
Not without modifying the underlying code, no. That change was post-K00G (MY17-20) and isn't as simple as table hacking.
If you have the tools to unbrick your ECU — it involves both soldering and having an image of the first 8kb for pre-facelift, which I do supposedly have — or don't mind a 10-20%, in my personal experience to date, chance of your ECU being bricked because of an oversight or error on my part, then it's actually pretty easy to customize into an ECU. But it's only simple in theory, as in practice it costs 0-2 ECUs to get right, and while I'm pretty great at getting these right the first time, I'm not perfect at doing so.
Old 10-14-2026, 09:27 PM   #163
makinen
makinen's Avatar
Drives: Toyota 86
I don't think those efforts are worthwhile.
Anyway, thanks for your hybrid works.
Old Yesterday, 03:14 AM   #164
Compelica
Compelica's Avatar
Drives: 86 GT
In what circumstances that tables B and C are referenced?
DIY stuff at Compelica Works
Compelica is offline   Reply With Quote
Drift Office Tune vs Visconti Tune mechaghost Engine, Exhaust, Transmission 109 07-03-2014 12:57 AM
Top Gear Solutions| OpenFlash Tablet Tune| Stage 1 Tune, Stage 2, Custom and E85 TopGearSolutions Engine, Exhaust, Bolt-Ons 90 04-14-2014 08:15 PM
difference between vortech tune and perrin tune? Frs32907 Forced Induction 7 12-05-2013 02:49 PM
Information I did not want to know. K2 Great Lakes 19 07-23-2012 08:18 AM
