Drives: 2013 FRS's (Hot Lava/GMetal Grey)
Installing a New ECU Question
I have a 2013 FR-S that has been tripping P000A, and P0016 codes, after replacing all the cam phasers (did them all to be on the safe side), timing chains/tensioners, oil control valves, and cam position sensors, I'm still getting the P000A. P0016 codes.
After doing some research on this it seems like the next step would be to replace the ECU. My question is if I purchase a new OEM ECU, is it a direct "plug & play" deal, or does the new ECU need some programming to get up and running again? |
#2 |
Full Throttle!
Drives: 17 CBSP Limited PP
At the very least, I'm pretty sure your keys will need to be programmed to it, but hopefully someone more in the know will have a definitive answer.
#3 |
Drives: 2019 Subaru BRZ
The exact part number printed on your ECU will, if bought from a dealer, come with the exact software you have now. You’ll still need to go through the ECU replacement immobilizer process, though. It may be lower risk for you to pay someone to do this for you.
#4 |
Thanks for your response/input
#5 |
Yeah! I'm sorry, I think I was having a bad day, I'm looking at that and I owe you a better reply —
If you look up on the forum for the ECU immobilizer pairing process, it is essentially "jumper two OBD pins and put your keyfob in front of the engine start button for a hard minimum of 30 full minutes", and it does work reliably enough that many of us have DIY'd it due to bricking our ECUs over time through tuning etc. |
| ECU flash ecu definition file? | toyota_86 | GR86 General Topics (2nd Gen 2022+ Toyota 86) | 0 | 06-13-2023 05:54 AM |
| Replacing a Bricked damaged or faulty ECU with new or used ECU FRS BRZ GT 86 | steve99 | Software Tuning | 110 | 03-12-2023 04:43 PM |
| Replacing BRZ ECU's with 86 ECU's | krauterz | Issues | Warranty | Recalls / TSB | 4 | 04-08-2021 07:49 AM |
| Ecu swappable? Potentially locked ecu | kill3rwill | Software Tuning | 3 | 03-02-2016 09:44 PM |
| BRZ 86 FRS ECU Information - ECU Type Flashing Learning Resetting | steve99 | Software Tuning | 46 | 08-19-2015 07:13 PM |
