Old 02-10-2026, 09:45 PM   #267
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Originally Posted by RT-BRZ View Post
Wheel studs are a piece of cake. You don't need no stinking lift either.
Just too tedious for me! I'm not that hard core
RT-BRZ (02-11-2026)
Old 02-24-2026, 08:55 PM   #268
spcmafia
spcmafia's Avatar
Drives: 2018 Subaru BRZ
Adding on to the parts list;
-ARP Studs
-949 Racing Lug Nuts
spcmafia is offline   Reply With Quote
The Following User Says Thank You to spcmafia For This Useful Post:
autoracer86 (02-25-2026)
Old 02-25-2026, 03:47 AM   #269
autoracer86
autoracer86's Avatar
Drives: Toyota GT86
-ARP Studs
I been running those lugs for many years across multiple cars. They do work great! Just keep an eye on the tq as they heat and cool and remember to replace them every year or so
autoracer86 is offline   Reply With Quote
Old 03-13-2026, 01:06 PM   #270
spcmafia
spcmafia's Avatar
Well I thought that the STI bushings would be relatively easy to install. Fuck that. Have to drop the diff, saw, hammer.
Whiteline inserts it is.
The Following 4 Users Say Thank You to spcmafia For This Useful Post:
new2subaru (03-20-2026), RT-BRZ (03-13-2026), Spuds (03-14-2026), Teseo (03-14-2026)
Old 03-21-2026, 04:25 PM   #271
spcmafia
spcmafia's Avatar
Alright. Installed the STI mounts for engine and transmission. Whiteline LSD inserts, restored the control arms back to stock, which I am pretty sure they were installed wrong by the last shop I brought the car to because the steering was finally smooth and not slightly pulling to the right. Whiteline subframe inserts got installed too. Even knocked a quick oil change at 76,000 miles.
Didnt get to do the steering rack inserts nor the ARP studs. I was pretty whipped by then.
Now, the car feels fantastic. Effortless acceleration although I can hear the initial 1-2-3 shift in the box. Slight whining but nothing particularly annoying. But it just goes, it barely needs gas to get up to speed and accelerating on the highway in 6th requires zero effort. Doesn’t matter if I am in a hill.
Car also has a quick response on the slalom, maybe too much, but it needs a more aggressive camber, currently at -2 on the front until autox starts.
Code Monkey (03-29-2026), Spuds (03-22-2026), Stonehorsw (Yesterday), villainous_frx (03-22-2026)
