| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
#29 |
Drives: 2023 BRZ
While that might explain some of the discrepancies, it doesn't explain all of them. I've still seen meaningful differences between sensors on the same vehicle at a fixed altitude.
Also, explaining the difference is altitude doesn't really fix the problem. It's still a problem many people have to account for if they want accurate readings. I don't understand why people are so reluctant to check tire pressures manually. It takes almost no time or effort.
Director of Rocky Mountain 86CUP
#30 | |
Drives: Crapcan
#31 | |||
Drives: 2022 GR86
We would all really appreciate it if you could just share the exact request / response protocol. I'm going to add it to my GitHub anyways, but you can just save everyone some time ![]() I promise to read more into the details of how Multi-Frame Messages work! I find "learn by studying an example" to be more effective than "learn by first solving a puzzle that requires you to already know what you want to learn to solve it". Also curious if you've confirmed if the same message format is working on the 2022 cars. Quote:
Interesting data! Quote:
even though the same pressure gauge measured the same pressure from both tires. So "0.5 psi resolution" doesn't necessarily mean "0.5 psi precision". But again, as long as you can see the general trend... This is perhaps even more interesting to log! |
#32 | |
Drives: 2022 GR86
If only doing one, using a high quality pressure gauge is probably more precise, as long as you fly into the pits at full speed, and your assistant quickly checks all four tires while they're hot. |
#33 | |
Drives: MR2, Sliver BRZ
Interesting thing to find about two tires being at different temps / pressures but same ambient temp. it was a conundrum that only happen at daytime but not at night. i ended up finding out with this that a parked car whos tires face the sun warm up so much it can use a super noticeable difference in PSI. by resolution i mean yes by .5. but so far ive tested with a backup manual check of my in the valve stem and for me they been all accurate with 1psi. But i do have the oem sensors. im not 100% sure if the accuracy is maintained if using aftermarket sensor though as its just a added variable in accuracy. also for what use is for simplicity. not saying you should rely on the sensors. but knowing the temp and psi help out a ton. i even did some measurements when heating the front tires when braking repeatedly with heavy breaking. Looking at the sensors and sure enough you can see the difference. let me dig up the code and and il ask my business partner if i can release the info!
Always looking to tinker with something..
#34 | ||||||||
Drives: 2022 GR86
I FIGURED IT OUT!
To read tire pressures Request 1: Quote:
To get the second frame, we need to send a "Continue to send request": Quote:
I believe the encoding is: Quote:
However it's worth noting that ScanGauge seems to use a different formula: Quote:
To read tire temperatures Similar thing, just slightly different bytes: Quote:
Thanks so much @BRZyJ for letting me play with his ScanGauge! |
#35 | |
And to get relative pressure then X+32)/4 - 14.5so you understand how extended frames work!
#36 | |
22R
Drives: 2012 Camry SE 2017 Toyota 86
Nice Website and equipment. 22R |
#37 |
Drives: 2022 GR86
Looks like Autel is using ((X * 0.25) - 7.5) for psi,
which maps to ((X * 1.724) - 51.7) for kPa.
Follow the build thread for my GR86!
#38 |
Drives: 2022 GR86
2024 update:
#39 | |
Drives: 2017 GT86
Totally a moot point, but I think changing the 14.5 to 14.6 would align things with Techstream. It puzzles me though that it's not 14.7 instead. This was on my gen1, over a range of pressures from 28 to 36PSI, and temperatures from 58-64F. I don't know if the fractional parts may vary outside this window. Pressures didn't exactly match my pressure gauge, but I have more faith in the TPMS sensors than my gauge. |
| New TPMS Sensors - Car Not Reading Them | Bluesman62 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 7 | 11-27-2016 01:41 AM |
| SOLD - Set of 315MHz TPMS - $125 OBO - Tire Pressure Sensors | badamowski | Wheels and Tires | 0 | 07-16-2014 10:07 PM |
| Tire Pressures | mike the snake | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 1 | 04-21-2014 04:03 PM |
| Tire Rack tpms sensors | TimR | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 4 | 10-27-2013 12:12 PM |
| WTB: Tire Pressure Monitoring Sensors (TPMS) | RYU | Wheels and Tires | 6 | 09-18-2012 12:52 PM |
