Old 10-20-2022, 12:15 PM   #141
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Necroed this to show cavitation in this video.
https://youtube.com/shorts/xM6zdim0yk4?feature=share
Sick video
Old 11-21-2022, 06:57 PM   #142
Leviathan83
Leviathan83's Avatar
Drives: GT86
Hello everyone,
hope you can help me, because I'm a newbe in engine building. I found a lot of infos in this thread, and I recently work on the timing cover to improve oil performance on FA20. I
- opened the oil galleries' covers
- ported oil galleries
- cleaned
- used an anaerobic sealent (Loctite 518) before reinstalling the covers and a threadlocker for the bolts
- installed an high volume oil pump kit
- used an engine lube to prime the new oil pump
Now I notice a little lube leak in the rotor of oil pump, after installing the cover... If I spin a little, some lube came out (see attached picture)... Maybe it's normal, I don't know.
Do I have to worry?
Rotor with cover installed and lube leak (this is the inside view on the timing chain cover):
Oil pump primed before installing the cover
Leviathan83 is offline   Reply With Quote
Old 11-21-2022, 08:47 PM   #143
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Do I have to worry?
The only thing sealing the pump in the cover is a slight amount of friction. It's normal.
Old 11-21-2022, 10:48 PM   #144
Think about it this way. It has to leak a little in order to lubricate itself.
Old 11-22-2022, 11:28 AM   #145
Leviathan83
Drives: GT86
Perfect! Thanks!
I thought about that, but I wasn't sure... Thanks!
Old 11-22-2022, 12:43 PM   #146
Most welcome! Good luck with your build.
Old 07-25-2025, 06:46 PM   #147
sweetfrs
sweetfrs's Avatar
Drives: 2013 FRS
Tracked my car for 30k miles on stock engine it finally spun a bearing in 2019. car sat for years in my shop then finally last winter we did a fully forged low compression engine with ported heads everything really nice. At the track last week it seized haven’t taken it apart yet. But I think I added the oil cooler and starved it
sweetfrs is offline   Reply With Quote
Old 07-25-2025, 08:49 PM   #148
DarkPira7e
DarkPira7e's Avatar
Damn, this hurts to hear. Was it all new components or was anything reused? There are filter screens and things that are so easy to overlook if you don't know Subarus. Sucks, I'm sorry
Old 07-27-2025, 10:38 AM   #149
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
What oil cooler did you add and what were your oil pressure and temps? The Jackson Racing dual rad has been known restrict oil flow.
Old 07-29-2025, 10:20 PM   #150
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Seized? Or just won’t turn over? Usually when I think seized I think piston/rings. Oil starve will kill the #2 or #3 rod bearing long before it will seize anything.
Old 07-30-2025, 09:12 PM   #151
blsfrs
blsfrs's Avatar
My FA20 "seized" because of a broken piston.
Old 07-30-2025, 09:28 PM   #152
new2subaru
Weight Weenie
Drives: 15 FR-S
That's broken alright!
Old 08-01-2025, 09:16 AM   #153
Eaton PSI
Drives: 2013 86
On the positive side, it may not have spun any bearings which would be a pleasant change for an FA20
2014 GT86, 2.2L big bore, harrop supercharged
Eaton PSI is offline   Reply With Quote
Old 08-01-2025, 09:51 AM   #154
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
FA20 Engine Oiling, Bearings, and Starvation Element Tuning Engine, Exhaust, Transmission 776 04-20-2024 04:25 AM
VVT Problems: 100$ reward for a solution!! Exhaust targets all 0, intakes no response bren5279 Forced Induction 12 03-14-2017 07:34 AM
Buddy Club Race Spec Coilover Problems on Problems on Problems mpross Suspension | Chassis | Brakes -- Sponsored by 949 Racing 48 09-04-2016 11:18 PM
An alternate solution to Drone problems 86-tundra Engine, Exhaust, Transmission 1 09-26-2013 02:50 AM
Question about oiling filters showbe Engine, Exhaust, Transmission 7 10-25-2012 09:50 PM
