Drives: '23 BRZ
Accusump oil level?
Successfully installed Accusump, thanks Ansix Auto!
I may have overfilled though, I'm seeing +1/4 quart overfill at 100psi and +1.25 qt overfilled at 20psi! OK to track or not? Kind of assuming that any overfill will be dealt with by PVC but let me know if I need to take oil out before tracking at Mosport in a few days. Thanks! |
| The Following User Says Thank You to ZDan For This Useful Post: | smoltz (06-25-2025) |
#2 |
Drives: 2013 frs base
Have you looked up Boyles Law yet? I found it helpful to calculate the amount of oil in the accumulator at a given pressure.
I'm not a fan of the electronic switches. When deactivated, they still allow oil flow into the accumulator. On a cold start with 100+ psi you push a lot of oil into the accumulator. Also, they are slow to react to a drop in OP. From what I have seen, the drop in OP is momentary. By the time the switch would activate, the pressure is already coming back up. I use a manual valve with a PTO cable. When the engine is warm, I open the valve, hold rpms so the OP is around 70 psi and then close the valve. I then top off the oil in the engine. |
#3 | |||
Drives: '23 BRZ
#4 | |
Drives: Toyota GT86
Thanks
SpareRoomRacing Youtube: https://www.youtube.com/@spareroomracing3168/featured Build Thread: https://www.ft86club.com/forums/showthread.php?t=153004
#5 | |
Drives: '23 BRZ
First track days with it Monday/Tuesday. I am 100% relying on the testing of others on this. Ansix Auto (great deal on the whole kit btw), 900BRZ, BTR Justin, etc. There's lot's of great test info out there. From everything I can tell, the Accusump greatly reduces pressure drops and recovers from them sooner. From Ansix:
#6 |
Correct me if I am wrong, (my wife does it all the time) but the electronic valves allow the accumulator to fill with oil even when "off".. Yes? It makes it harder to get to correct oil level in the engine.
Years ago, I graphed pressure vs volume. It seems to follow a slope not a straight line. |
#7 | |
Drives: '23 BRZ
Yeah I have a hard time reading oil levels anyway, one side of dipstick says full, other side says 1/2-qt overfilled… |
#8 |
Sorry, my last trig class was many moons ago so my grasp of terminology is foggy at best. If you plot the volume v pressure the line is curved not straight. Parabolic might be what I'm trying to describe.
| The Following User Says Thank You to blsfrs For This Useful Post: | ZDan (06-28-2025) |
#9 |
Drives: '23 BRZ
P1V1 *should* = P2V2. I doubt the dipstick scale is linear...
| The Following User Says Thank You to ZDan For This Useful Post: | blsfrs (06-29-2025) |
#10 | |
Full Throttle!
Drives: 17 CBSP Limited PP
Is there a consensus on this? Average out the 2 sides? Always go by the lower? The higher? Keep adding till it comes out the breather? |
#12 |
Full Throttle!
Makes sense. Ill make sure to check my Lunar calendar before I schedule a oil check next time.
| The Following User Says Thank You to smackrel For This Useful Post: | blsfrs (07-01-2025) |
#13 | |
Drives: 13 Viper; 14 BRZ; 90 Miata; 18 AMG
Of course it's going to be high at low pressures- the accusump is pumping in oil! Prior to accusump we ran with about a quart over full and it was fine.
2014 BRZ: WRL Build (GP2) Gutted, caged, coilovers, AP enduro, etc-
2014 FRS: Similar WRL Build. Back up / parts / practice race car. 2013 Viper GTS : Tractive Coilovers, ACR sway bars, aero, carbon, exhaust, etc. 1992 NA Spec Miata: 1.6 + 1999 NB Spec Miata: 1.8 w/ all the goodies. 2022 CT5 Blackwing: Stock. |
#14 |
Drives: '23 BRZ
I am running it on track with the electronic valve open all the time. For "normal" usage, I'll open the valve before startup, then close it after it has warmed up a bit.
| Ansix Auto's Accusump Back to Back Track Testing | Ansix Auto | BRZ Second-Gen (2022+) — General Topics | 1 | 10-14-2023 11:41 AM |
| Ansix Auto FA24 BRZ/GR86 Accusump Oil Pressure Drop Testing Results | Ansix Auto | GR86 General Topics (2nd Gen 2022+ Toyota 86) | 49 | 09-14-2023 09:35 PM |
| 2qt Accusump, -10 AN line, fittings, bracket, remote operating cable | Joesurf79 | Engine, Exhaust, Bolt-Ons | 29 | 02-24-2023 02:04 PM |
| Accusump install | LS1M | Engine, Exhaust, Transmission | 62 | 10-11-2018 12:21 PM |
| Accusump Operation | wizzo | Engine, Exhaust, Transmission | 15 | 03-24-2016 06:20 PM |
