Old 06-11-2025, 09:01 PM   #1
hessay
Drives: Red 2014 FR-S
FRS brake system warning light
I've noticed for the past couple of days that occasionally when braking the parking brake light comes on, and the owners manual says it's also a brake system warning light.
I checked the brake fluid and it's not quite low, but not really full either so I'm not sure if that would be the cause. I read on another thread that it could be sensors, but I think that car had been in some accidents and mine is pristine
Is it worth just replacing the fluid, throwing new brake pads on, upgrading the brake lines while I'm at it, and hoping the problem gets resolved?
I don't think any brake maintenance has been done, so it's probably due anyways (2014 frs).
Any advice is welcome
hessay is offline   Reply With Quote
Old 06-12-2025, 01:41 AM   #2
LancePower
Drives: 2020 BRZ tS
Yes, low fluid will trigger the light.
LancePower is offline   Reply With Quote
Old 06-14-2025, 09:16 AM   #3
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
Low fluid can trigger a light. As pads wear down the fluid level can drop a bit as pistons press out father.
DIY:Valenti 3rd/4th Brake Light Mod-Separate Brake light Triangle-2 Options -Video continuecrushing DIY (Do-It-Yourself) Guides 44 11-23-2020 07:17 PM
17+ Taillights, 4th Brake Light, Valenti Brake Light Harness, PPF & More kashmir Exterior Parts (Aero, Lighting, Etc.) 7 12-11-2019 03:42 AM
DIY: Valenti 4th brake light wiring for no blink brake light. (Triangle) BirdTRD DIY (Do-It-Yourself) Guides 17 11-06-2017 09:42 PM
Valenti 4th brake light vs Valenti Style brake light? JGalp Electronics | Audio | NAV | Infotainment 9 03-24-2016 06:48 PM
Redline360: Brake Lines, Brake Rotors, Brake Pads for BRZ/FRS Redline360 Brakes, Suspension, Chassis 12 01-05-2013 11:20 PM
