Old 02-18-2025, 08:02 PM   #1
Nagol41
Drives: 2015 BRZ
Timing issue after changing all timing components
I wanted to reach out and ask to see if any of you have any advice on a FA20 motor.
I just replaced all cam sprockets, timing chains, tensioners and guides.
I am Taking logs with ECUtek all VVT Angles are at 0 except for one exhaust cam, it hovers around 12-13.9 degrees till vvt kicks on. Once vvt enables they all are within spec. I have a code pop up (p0019). When the p0019 code pops up vvt turns back off and I believe it is in limp mode and all cams hover around 0 degrees. Does it sound to be one tooth off? Before I tear back into it.
Nagol41 is offline   Reply With Quote
Old 02-19-2025, 12:54 AM   #2
Yes. Quit running the engine before the ECU adjusts the initial position value too far out of whack. The ECU only adjusts one way and won't be able to find its way back if it's gone too far. It goes through a calibration cycle each time the engine is started.
Old 02-19-2025, 02:05 AM   #3
tomm.brz
Drives: brz 2017 hksv2
here some helpful info but yes wrong timing probably 1 tooth off
https://ecutek.atlassian.net/wiki/sp...CAM+Activation
Old 02-19-2025, 02:08 AM   #4
tomm.brz
ecutek can provide a stock base rom with vvt checks disabled eventually
it s dangerous if the timing chains are misaligned but if everything is in place, that rom helps as it turns vvt immediately on and can help relearn new initial values
actually i m running such a tune for 1 year, just lazy waiting for it to activate as i reflash often
The Following 3 Users Say Thank You to tomm.brz For This Useful Post:
callisto (02-19-2025), NoHaveMSG (03-08-2025), Ultramaroon (02-19-2025)
Old 02-19-2025, 02:24 AM   #5
Interesting! If only the same tweak could be performed on an open rom. Always a pleasure to hear your perspective.
callisto (02-19-2025), tomm.brz (02-19-2025)
Old 03-08-2025, 10:26 PM   #6
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I’ve actually heard from some other Subaru guys that some scanners like Autel can put the ECU in a test mode that allows it to relearn the IPV’s.
Ultramaroon (03-09-2025)
2013 FRS timing issue jonho Engine, Exhaust, Transmission 52 12-22-2022 11:59 AM
Issue With Inlet Camshaft Timing Distributor (reference from Reddit post) MJones_RB Issues | Warranty | Recalls / TSB 9 08-22-2019 05:00 PM
Cam position - timing issue. cab33 Engine, Exhaust, Transmission 3 07-01-2018 12:52 PM
Don't know how to set timing. MJferg Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 1 12-27-2016 10:36 PM
Timing chain issue? Hardpack Issues | Warranty | Recalls / TSB 14 01-11-2016 12:25 AM
