Drives: 2015 BRZ
Timing issue after changing all timing components
I wanted to reach out and ask to see if any of you have any advice on a FA20 motor.
I just replaced all cam sprockets, timing chains, tensioners and guides. I am Taking logs with ECUtek all VVT Angles are at 0 except for one exhaust cam, it hovers around 12-13.9 degrees till vvt kicks on. Once vvt enables they all are within spec. I have a code pop up (p0019). When the p0019 code pops up vvt turns back off and I believe it is in limp mode and all cams hover around 0 degrees. Does it sound to be one tooth off? Before I tear back into it. |
#2 |
Yes. Quit running the engine before the ECU adjusts the initial position value too far out of whack. The ECU only adjusts one way and won't be able to find its way back if it's gone too far. It goes through a calibration cycle each time the engine is started.
#3 |
Drives: brz 2017 hksv2
here some helpful info but yes wrong timing probably 1 tooth off
https://ecutek.atlassian.net/wiki/sp...CAM+Activation |
#4 | |
it s dangerous if the timing chains are misaligned but if everything is in place, that rom helps as it turns vvt immediately on and can help relearn new initial values actually i m running such a tune for 1 year, just lazy waiting for it to activate as i reflash often |
| The Following 3 Users Say Thank You to tomm.brz For This Useful Post: |
#5 | |
#6 | |
Drives: Crapcan
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | Ultramaroon (03-09-2025) |
| 2013 FRS timing issue | jonho | Engine, Exhaust, Transmission | 52 | 12-22-2022 11:59 AM |
| Issue With Inlet Camshaft Timing Distributor (reference from Reddit post) | MJones_RB | Issues | Warranty | Recalls / TSB | 9 | 08-22-2019 05:00 PM |
| Cam position - timing issue. | cab33 | Engine, Exhaust, Transmission | 3 | 07-01-2018 12:52 PM |
| Don't know how to set timing. | MJferg | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 1 | 12-27-2016 10:36 PM |
| Timing chain issue? | Hardpack | Issues | Warranty | Recalls / TSB | 14 | 01-11-2016 12:25 AM |
