Old 01-15-2025, 09:23 PM   #1
Jesse1292
Jesse1292's Avatar
Drives: Black 2013 BRZ Limited M/T
Headlight issues
Hello everyone, I’m in need of some help with one of my headlights. My passenger side randomly went out one day and today I was attempting to change the bulbs thinking that was the issue but I noticed something else in the bulb housing Not sure if I’m able to replace that part alone or if I need a brand new headligh. Not sure what that part would be called also so any help is appreciated thanks! I attached some pictures of the drivers side and passengers side bulb housing.
Jesse1292 is offline   Reply With Quote
Old 01-15-2025, 11:42 PM   #2
T-Steve
Drives: 2014 BRZ
I think you are looking at the high beam shutter (or whatever it's called in there).
The replacement D4S lamp should be all you need, unless the ballast is bad. And it's not inside the headlight.
T-Steve is offline   Reply With Quote
Old 01-16-2025, 09:18 AM   #3
Jesse1292
Jesse1292's Avatar
Yea I bought new bulbs and was about to change them since it’s not the first time one of them has gone out. But when I opened it it seemed like the area where the bulb slides into with the notches it has seemed like it had melted. Not sure if it was caused by the bulb since it was cracked when I was gonna replace it.
Old 01-17-2025, 01:43 PM   #4
Opie
Opie's Avatar
Drives: 2020 GMC Canyon Denali Diesel
You are going to need a new headlight assembly. While you may be able to install a bulb in that damaged assembly, it will likely continue to have issues. Not sure what would've caused that....were you running aftermarket bulbs?
2020 GMC Canyon Denali Duramax, 2021 Forester Sport, 2000 Subaru Legacy B4 RSK 5MT (JDM Import) and random 86 chassis rebuilds....
Opie is offline   Reply With Quote
V-Land headlight issues y2kcane Scion FR-S / Toyota 86 GT86 General Forum 6 10-19-2022 10:07 AM
OLM Headlight issues FineVisionz Cosmetic Modification (Interior/Exterior/Lighting) 5 11-18-2021 02:43 PM
Winjet headlight signal issues Demotic Cosmetic Modification (Interior/Exterior/Lighting) 0 09-22-2015 12:03 AM
Monogram headlight issues Simon Cosmetic Modification (Interior/Exterior/Lighting) 8 10-28-2014 11:48 AM
HID Headlight Issues KkSc Cosmetic Modification (Interior/Exterior/Lighting) 5 02-10-2014 05:23 PM
